Gudhi::Toplex_map Member List
This is the complete list of members for Gudhi::Toplex_map, including all inherited members.
contraction(const Vertex x, const Vertex y)Gudhi::Toplex_map
insert_independent_simplex(const Input_vertex_range &vertex_range)Gudhi::Toplex_map
insert_simplex(const Input_vertex_range &vertex_range)Gudhi::Toplex_map
maximal_cofaces(const Input_vertex_range &vertex_range, const std::size_t max_number=0) constGudhi::Toplex_map
maximal_simplices(const std::size_t max_number=0) constGudhi::Toplex_mapinline
maximality(const Input_vertex_range &vertex_range) constGudhi::Toplex_map
membership(const Input_vertex_range &vertex_range) constGudhi::Toplex_map
num_maximal_simplices() constGudhi::Toplex_mapinline
num_vertices() constGudhi::Toplex_mapinline
remove_simplex(const Input_vertex_range &vertex_range)Gudhi::Toplex_map
remove_vertex(const Vertex x)Gudhi::Toplex_map
Simplex typedefGudhi::Toplex_map
Simplex_ptr typedefGudhi::Toplex_map
Simplex_ptr_set typedefGudhi::Toplex_map
Vertex typedefGudhi::Toplex_map
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13
