This is one of a scaling functions used to weight points depending on their persistence and/or location in the diagram. The scaling given by this function to a point (b,d) is Euclidean distance of (b,d) from diagonal.
| GUDHI Version 3.4.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13 |
