SimplicialComplexForAlpha.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2016 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_H_
12 #define CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_H_
13
14 namespace Gudhi {
15
16 namespace alpha_complex {
17
23  typedef unspecified Simplex_handle;
25  typedef unspecified Vertex_handle;
27  typedef unspecified Filtration_value;
28
30  std::size_t num_vertices();
31
33  int dimension(Simplex_handle simplex);
34
36  int assign_filtration(Simplex_handle simplex, Filtration_value filtration);
37
40  void insert_simplex_and_subfaces(std::vector<Vertex_handle> const & vertex_range, Filtration_value filtration);
41
44
46  void prune_above_filtration(Filtration_value filtration);
47
51  typedef unspecified Simplex_vertex_range;
52
54  Simplex_vertex_range simplex_vertex_range(Simplex_handle const & simplex);
55
59  typedef unspecified Boundary_simplex_range;
60
62  Boundary_simplex_range boundary_simplex_range(Simplex_handle const & simplex);
63
67  typedef unspecified Skeleton_simplex_range;
70  Skeleton_simplex_range skeleton_simplex_range;
71
74  typedef unspecified Insertion_result_type;
75
82  typedef unspecified Simplex_key;
85  Simplex_key null_key ();
89  Simplex_key key ( Simplex_handle sh );
91  void assign_key(Simplex_handle sh, Simplex_key n);
93 };
94
95 } // namespace alpha_complex
96
97 } // namespace Gudhi
98
99 #endif // CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_H_
Data stored for each simplex.
Definition: SimplicialComplexForAlpha.h:82
void insert_simplex_and_subfaces(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in th...
Simplex_vertex_range simplex_vertex_range(Simplex_handle const &simplex)
Returns a range over vertices of a given simplex.
Simplex_key null_key()
Returns a constant dummy number that is either negative, or at least as large as the number of simpli...
Definition: SimplicialComplexForAlpha.h:14
Definition: SimplicialComplexForAlpha.h:25
The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial...
Definition: SimplicialComplexForAlpha.h:21
Iterator over the boundaries of the complex, in an arbitrary order.
Definition: SimplicialComplexForAlpha.h:59
Returns a range over the simplices of the skeleton of the simplicial complex, for a given dimension...
Definition: SimplicialComplexForAlpha.h:70
Iterator over the simplices of the skeleton of the complex, for a given dimension.
Definition: SimplicialComplexForAlpha.h:67
Return type of an insertion of a simplex.
Definition: SimplicialComplexForAlpha.h:74
Definition: SimplicialComplexForAlpha.h:23
Iterator over vertices of a simplex.
Definition: SimplicialComplexForAlpha.h:51
Simplex_key key(Simplex_handle sh)
Returns the number stored for a simplex by assign_key().
Boundary_simplex_range boundary_simplex_range(Simplex_handle const &simplex)
Returns a range over boundaries of a given simplex.
Definition: SimplicialComplexForAlpha.h:27
Store a number for a simplex, which can later be retrieved with key().
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:15 for GUDHI by Doxygen 1.8.13
