Loading [MathJax]/jax/input/TeX/config.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Rips_complex/example_one_skeleton_rips_from_points.cpp
#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits> // for std::numeric_limits
int main() {
// Type definitions
using Point = std::vector<double>;
std::vector<Point> points;
points.push_back({1.0, 1.0});
points.push_back({7.0, 0.0});
points.push_back({4.0, 6.0});
points.push_back({9.0, 6.0});
points.push_back({0.0, 14.0});
points.push_back({2.0, 19.0});
points.push_back({9.0, 17.0});
// Init of a Rips complex from points
double threshold = 12.0;
Rips_complex rips_complex_from_points(points, threshold, Gudhi::Euclidean_distance());
Simplex_tree stree;
rips_complex_from_points.create_complex(stree, 1);
// Display information about the one skeleton Rips complex
std::clog << "Rips complex is of dimension " << stree.dimension() <<
" - " << stree.num_simplices() << " simplices - " <<
stree.num_vertices() << " vertices." << std::endl;
std::clog << "Iterator on Rips complex simplices in the filtration order, with [filtration value]:" <<
std::endl;
for (auto f_simplex : stree.filtration_simplex_range()) {
std::clog << " ( ";
for (auto vertex : stree.simplex_vertex_range(f_simplex)) {
std::clog << vertex << " ";
std::clog << ") -> " << "[" << stree.filtration(f_simplex) << "] ";
std::clog << std::endl;
return 0;
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:15 for GUDHI by Doxygen 1.8.13
