Persistence_representations/persistence_landscape.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Persistence_landscape.h>
#include <iostream>
#include <vector>
#include <utility>
int main(int argc, char** argv) {
// create two simple vectors with birth--death pairs:
std::vector<std::pair<double, double> > persistence1;
std::vector<std::pair<double, double> > persistence2;
persistence1.push_back(std::make_pair(1, 2));
persistence1.push_back(std::make_pair(6, 8));
persistence1.push_back(std::make_pair(0, 4));
persistence1.push_back(std::make_pair(3, 8));
persistence2.push_back(std::make_pair(2, 9));
persistence2.push_back(std::make_pair(1, 6));
persistence2.push_back(std::make_pair(3, 5));
persistence2.push_back(std::make_pair(6, 10));
// create two persistence landscapes based on persistence1 and persistence2:
Persistence_landscape l1(persistence1);
Persistence_landscape l2(persistence2);
// This is how to compute integral of landscapes:
std::clog << "Integral of the first landscape : " << l1.compute_integral_of_landscape() << std::endl;
std::clog << "Integral of the second landscape : " << l2.compute_integral_of_landscape() << std::endl;
// And here how to write landscapes to stream:
std::clog << "l1 : " << l1 << std::endl;
std::clog << "l2 : " << l2 << std::endl;
// Arithmetic operations on landscapes:
Persistence_landscape sum = l1 + l2;
std::clog << "sum : " << sum << std::endl;
// here are the maxima of the functions:
std::clog << "Maximum of l1 : " << l1.compute_maximum() << std::endl;
std::clog << "Maximum of l2 : " << l2.compute_maximum() << std::endl;
// here are the norms of landscapes:
std::clog << "L^1 Norm of l1 : " << l1.compute_norm_of_landscape(1.) << std::endl;
std::clog << "L^1 Norm of l2 : " << l2.compute_norm_of_landscape(1.) << std::endl;
// here is the average of landscapes:
average.compute_average({&l1, &l2});
std::clog << "average : " << average << std::endl;
// here is the distance of landscapes:
std::clog << "Distance : " << l1.distance(l2) << std::endl;
// here is the scalar product of landscapes:
std::clog << "Scalar product : " << l1.compute_scalar_product(l2) << std::endl;
// here is how to create a file which is suitable for visualization via gnuplot:
average.plot("average_landscape");
return 0;
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:15 for GUDHI by Doxygen 1.8.13
