Persistence_representations/persistence_intervals.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Persistence_intervals.h>
#include <iostream>
#include <utility>
#include <vector>
int main(int argc, char** argv) {
if (argc != 2) {
std::clog << "To run this program, please provide the name of a file with persistence diagram \n";
return 1;
std::pair<double, double> min_max_ = p.get_x_range();
std::clog << "Birth-death range : " << min_max_.first << " " << min_max_.second << std::endl;
std::vector<double> dominant_ten_intervals_length = p.length_of_dominant_intervals(10);
std::clog << "Length of ten dominant intervals : " << std::endl;
for (size_t i = 0; i != dominant_ten_intervals_length.size(); ++i) {
std::clog << dominant_ten_intervals_length[i] << std::endl;
std::vector<std::pair<double, double> > ten_dominant_intervals = p.dominant_intervals(10);
std::clog << "Here are the dominant intervals : " << std::endl;
for (size_t i = 0; i != ten_dominant_intervals.size(); ++i) {
std::clog << "( " << ten_dominant_intervals[i].first << "," << ten_dominant_intervals[i].second << std::endl;
std::vector<size_t> histogram = p.histogram_of_lengths(10);
std::clog << "Here is the histogram of barcode's length : " << std::endl;
for (size_t i = 0; i != histogram.size(); ++i) {
std::clog << histogram[i] << " ";
std::clog << std::endl;
std::vector<size_t> cumulative_histogram = p.cumulative_histogram_of_lengths(10);
std::clog << "Cumulative histogram : " << std::endl;
for (size_t i = 0; i != cumulative_histogram.size(); ++i) {
std::clog << cumulative_histogram[i] << " ";
std::vector<double> char_funct_diag = p.characteristic_function_of_diagram(min_max_.first, min_max_.second);
std::clog << "Characteristic function of diagram : " << std::endl;
for (size_t i = 0; i != char_funct_diag.size(); ++i) {
std::clog << char_funct_diag[i] << " ";
std::vector<double> cumul_char_funct_diag =
p.cumulative_characteristic_function_of_diagram(min_max_.first, min_max_.second);
std::clog << "Cumulative characteristic function of diagram : " << std::endl;
for (size_t i = 0; i != cumul_char_funct_diag.size(); ++i) {
std::clog << cumul_char_funct_diag[i] << " ";
std::clog << "Persistence Betti numbers \n";
std::vector<std::pair<double, size_t> > pbns = p.compute_persistent_betti_numbers();
for (size_t i = 0; i != pbns.size(); ++i) {
std::clog << pbns[i].first << " " << pbns[i].second << std::endl;
return 0;
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:15 for GUDHI by Doxygen 1.8.13
