11 #ifndef PERSISTENCE_VECTORS_H_ 12 #define PERSISTENCE_VECTORS_H_ 15 #include <gudhi/read_persistence_from_file.h> 16 #include <gudhi/common_persistence_representations.h> 29 namespace Persistence_representations {
32 struct Maximum_distance {
33 double operator()(
const std::pair<T, T>& f,
const std::pair<T, T>& s) {
34 return std::max(fabs(f.first - s.first), fabs(f.second - s.second));
72 unsigned dimension = std::numeric_limits<unsigned>::max());
78 friend std::ostream& operator<<(std::ostream& out, const Vector_distances_in_diagram<K>& d) {
79 for (
size_t i = 0; i != std::min(d.sorted_vector_of_distances.size(), d.where_to_cut); ++i) {
80 out << d.sorted_vector_of_distances[i] <<
89 if (position >= this->sorted_vector_of_distances.size())
90 throw(
"Wrong position in accessing Vector_distances_in_diagram::sorted_vector_of_distances\n");
91 return this->sorted_vector_of_distances[position];
97 inline size_t size()
const {
return this->sorted_vector_of_distances.size(); }
102 void write_to_file(
const char* filename)
const;
107 void print_to_file(
const { this->write_to_file(filename); }
112 void load_from_file(
const char* filename);
118 if (this->sorted_vector_of_distances.size() != second.sorted_vector_of_distances.size())
return false;
119 for (
size_t i = 0; i != this->sorted_vector_of_distances.size(); ++i) {
120 if (!almost_equal(this->sorted_vector_of_distances[i], second.sorted_vector_of_distances[i]))
return false;
135 double project_to_R(
int number_of_function)
const;
145 std::vector<double> vectorize(
const;
155 void compute_average(
const std::vector<Vector_distances_in_diagram*>& to_average);
178 void plot(
const {
179 std::stringstream gnuplot_script;
180 gnuplot_script << filename <<
"_GnuplotScript";
182 out.open(gnuplot_script.str().c_str());
183 out <<
"set style data histogram" << std::endl;
184 out <<
"set style histogram cluster gap 1" << std::endl;
185 out <<
"set style fill solid border -1" << std::endl;
186 out <<
"plot '-' notitle" << std::endl;
187 for (
188 out << this->sorted_vector_of_distances[i] << std::endl;
192 std::clog <<
"To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'" 193 << gnuplot_script.str().c_str() <<
"\'\"" << std::endl;
199 std::pair<double, double>
get_x_range()
const {
return std::make_pair(0, this->sorted_vector_of_distances.size()); }
205 if (this->sorted_vector_of_distances.size() == 0)
return std::make_pair(0, 0);
206 return std::make_pair(this->sorted_vector_of_distances[0], 0);
210 template <
typename Operation_type>
213 Operation_type opertion) {
216 result.sorted_vector_of_distances.reserve(
217 std::max(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size()));
218 for (
size_t i = 0; i != std::min(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size());
220 result.sorted_vector_of_distances.push_back(
221 opertion(first.sorted_vector_of_distances[i], second.sorted_vector_of_distances[i]));
223 if (first.sorted_vector_of_distances.size() ==
224 std::min(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size())) {
225 for (
size_t i = std::min(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size());
226 i != std::max(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size()); ++i) {
227 result.sorted_vector_of_distances.push_back(opertion(0, second.sorted_vector_of_distances[i]));
230 for (
231 i != std::max(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size()); ++i) {
232 result.sorted_vector_of_distances.push_back(opertion(first.sorted_vector_of_distances[i], 0));
243 result.sorted_vector_of_distances.reserve(this->sorted_vector_of_distances.size());
244 for (
245 result.sorted_vector_of_distances.push_back(scalar * this->sorted_vector_of_distances[i]);
255 return operation_on_pair_of_vectors(first, second, std::plus<double>());
262 return operation_on_pair_of_vectors(first, second, std::minus<double>());
305 if (x == 0)
throw(
"In operator /=, division by 0. Program terminated.");
306 *
this = *
this * (1 / x);
311 std::vector<std::pair<double, double> > intervals;
312 std::vector<double> sorted_vector_of_distances;
313 size_t number_of_functions_for_vectorization;
314 size_t number_of_functions_for_projections_to_reals;
317 void compute_sorted_vector_of_distances_via_heap(
size_t where_to_cut);
318 void compute_sorted_vector_of_distances_via_vector_sorting(
321 : sorted_vector_of_distances(sorted_vector_of_distances_) {
322 this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
325 void set_up_numbers_of_functions_for_vectorization_and_projections_to_reals() {
327 this->number_of_functions_for_vectorization = this->sorted_vector_of_distances.size();
328 this->number_of_functions_for_projections_to_reals = this->sorted_vector_of_distances.size();
332 template <
typename F>
334 size_t where_to_cut_)
335 : where_to_cut(where_to_cut_) {
336 std::vector<std::pair<double, double> > i(intervals_);
339 this->compute_sorted_vector_of_distances_via_vector_sorting(where_to_cut);
340 this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
343 template <
typename F>
346 : where_to_cut(where_to_cut) {
347 std::vector<std::pair<double, double> > intervals;
348 if (dimension == std::numeric_limits<unsigned>::max()) {
349 intervals = read_persistence_intervals_in_one_dimension_from_file(filename);
351 intervals = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
353 this->intervals = intervals;
354 this->compute_sorted_vector_of_distances_via_heap(where_to_cut);
356 set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
359 template <
typename F>
363 std::clog <<
"Here are the intervals : \n";
364 for (
size_t i = 0; i != this->intervals.size(); ++i) {
365 std::clog << this->intervals[i].first <<
" , " << this->intervals[i].second << std::endl;
368 where_to_cut = std::min(
369 where_to_cut, (
size_t)(0.5 * this->intervals.size() * (this->intervals.size() - 1) + this->intervals.size()));
371 std::vector<double> heap(where_to_cut, std::numeric_limits<int>::max());
372 std::make_heap(heap.begin(), heap.end());
377 for (
size_t i = 0; i < this->intervals.size(); ++i) {
378 for (
size_t j = i + 1; j < this->intervals.size(); ++j) {
379 double value = std::min(
380 f(this->intervals[i], this->intervals[j]),
382 f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
383 0.5 * (this->intervals[i].first + this->intervals[i].second))),
384 f(this->intervals[j], std::make_pair(0.5 * (this->intervals[j].first + this->intervals[j].second),
385 0.5 * (this->intervals[j].first + this->intervals[j].second)))));
388 std::clog <<
"Value : " << value << std::endl;
389 std::clog <<
"heap.front() : " << heap.front() << std::endl;
393 if (-value < heap.front()) {
395 std::clog <<
"Replacing : " << heap.front() <<
" with : " << -value << std::endl;
399 std::pop_heap(heap.begin(), heap.end());
403 heap[where_to_cut - 1] = -value;
404 std::push_heap(heap.begin(), heap.end());
410 for (
411 double value = f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
412 0.5 * (this->intervals[i].first + this->intervals[i].second)));
413 if (-value < heap.front()) {
415 std::pop_heap(heap.begin(), heap.end());
419 heap[where_to_cut - 1] = -value;
420 std::push_heap(heap.begin(), heap.end());
424 std::sort_heap(heap.begin(), heap.end());
425 for (
size_t i = 0; i != heap.size(); ++i) {
426 if (heap[i] == std::numeric_limits<int>::max()) {
434 std::clog <<
"This is the heap after all the operations :\n";
435 for (
436 std::clog << heap[i] <<
438 std::clog << std::endl;
441 this->sorted_vector_of_distances = heap;
444 template <
typename F>
446 std::vector<double> distances;
447 distances.reserve((
452 for (
455 f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
456 0.5 * (this->intervals[i].first + this->intervals[i].second))));
457 for (
458 double value = std::min(
459 f(this->intervals[i], this->intervals[j]),
461 f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
462 0.5 * (this->intervals[i].first + this->intervals[i].second))),
463 f(this->intervals[j], std::make_pair(0.5 * (this->intervals[j].first + this->intervals[j].second),
464 0.5 * (this->intervals[j].first + this->intervals[j].second)))));
465 distances.push_back(value);
468 std::sort(distances.begin(), distances.end(), std::greater<double>());
469 if (distances.size() > where_to_cut) distances.resize(where_to_cut);
471 this->sorted_vector_of_distances = distances;
475 template <
typename F>
477 if ((
size_t)number_of_function > this->number_of_functions_for_projections_to_reals)
478 throw "Wrong index of a function in a method Vector_distances_in_diagram<F>::project_to_R";
479 if (number_of_function < 0)
480 throw "Wrong index of a function in a method Vector_distances_in_diagram<F>::project_to_R";
483 for (
size_t i = 0; i != (size_t)number_of_function; ++i) {
484 result += sorted_vector_of_distances[i];
489 template <
typename F>
491 if (to_average.size() == 0) {
496 size_t maximal_length_of_vector = 0;
497 for (
size_t i = 0; i != to_average.size(); ++i) {
498 if (to_average[i]->sorted_vector_of_distances.size() > maximal_length_of_vector) {
499 maximal_length_of_vector = to_average[i]->sorted_vector_of_distances.size();
503 std::vector<double> av(maximal_length_of_vector, 0);
504 for (
505 for (
size_t j = 0; j != to_average[i]->sorted_vector_of_distances.size(); ++j) {
506 av[j] += to_average[i]->sorted_vector_of_distances[j];
510 for (
size_t i = 0; i != maximal_length_of_vector; ++i) {
511 av[i] /=
static_cast<double>(to_average.size());
513 this->sorted_vector_of_distances = av;
514 this->where_to_cut = av.size();
517 template <
typename F>
522 std::clog <<
"Entering double Vector_distances_in_diagram<F>::distance( const Abs_Topological_data_with_distances* " 523 "second , double power ) procedure \n";
524 std::clog <<
"Power : " << power << std::endl;
525 std::clog <<
"This : " << *
this << std::endl;
526 std::clog <<
"second : " << second_ << std::endl;
530 for (
size_t i = 0; i != std::min(this->sorted_vector_of_distances.size(), second_.sorted_vector_of_distances.size());
534 std::clog <<
"|" << this->sorted_vector_of_distances[i] <<
" - " << second_.sorted_vector_of_distances[i]
535 <<
" | : " << fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i])
538 result += fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]);
540 if (power < std::numeric_limits<double>::max()) {
541 result += std::pow(fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]), power);
544 if (result < fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]))
545 result = fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]);
548 std::clog <<
"| " << this->sorted_vector_of_distances[i] <<
549 <<
" : " << fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i])
554 if (this->sorted_vector_of_distances.size() != second_.sorted_vector_of_distances.size()) {
555 if (this->sorted_vector_of_distances.size() > second_.sorted_vector_of_distances.size()) {
556 for (
size_t i = second_.sorted_vector_of_distances.size(); i != this->sorted_vector_of_distances.size(); ++i) {
557 result += fabs(this->sorted_vector_of_distances[i]);
561 for (
size_t i = this->sorted_vector_of_distances.size(); i != second_.sorted_vector_of_distances.size(); ++i) {
562 result += fabs(second_.sorted_vector_of_distances[i]);
568 result = std::pow(result, (1.0 / power));
573 template <
typename F>
575 if ((
size_t)number_of_function > this->number_of_functions_for_vectorization)
576 throw "Wrong index of a function in a method Vector_distances_in_diagram<F>::vectorize";
577 if (number_of_function < 0)
579 std::vector<double> result(std::min((
size_t)number_of_function, this->sorted_vector_of_distances.size()));
580 for (
size_t i = 0; i != std::min((
size_t)number_of_function, this->sorted_vector_of_distances.size()); ++i) {
581 result[i] = this->sorted_vector_of_distances[i];
586 template <
typename F>
591 for (
592 out << this->sorted_vector_of_distances[i] <<
598 template <
typename F>
604 std::cerr <<
"The file : " << filename <<
" do not exist. The program will now terminate \n";
605 throw "The persistence landscape file do not exist. The program will now terminate \n";
609 while (in >> number) {
610 this->sorted_vector_of_distances.push_back(number);
615 template <
typename F>
619 i != std::min(this->sorted_vector_of_distances.size(), second_vector.sorted_vector_of_distances.size()); ++i) {
620 result += this->sorted_vector_of_distances[i] * second_vector.sorted_vector_of_distances[i];
628 #endif // PERSISTENCE_VECTORS_H_ double vector_in_position(size_t position) const
Definition: Persistence_vectors.h:88
Vector_distances_in_diagram operator/=(double x)
Definition: Persistence_vectors.h:304
void load_from_file(const char *filename)
Definition: Persistence_vectors.h:599
void print_to_file(const char *filename) const
Definition: Persistence_vectors.h:107
std::vector< double > output_for_visualization() const
Definition: Persistence_vectors.h:173
std::pair< double, double > get_x_range() const
Definition: Persistence_vectors.h:199
A class implementing persistence vectors.
Definition: Persistence_vectors.h:54
Definition: SimplicialComplexForAlpha.h:14
Vector_distances_in_diagram operator*(double scalar)
Definition: Persistence_vectors.h:279
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_vectors.h:574
size_t number_of_vectorize_functions() const
Definition: Persistence_vectors.h:150
Vector_distances_in_diagram operator*=(double x)
Definition: Persistence_vectors.h:297
void write_to_file(const char *filename) const
Definition: Persistence_vectors.h:587
size_t size() const
Definition: Persistence_vectors.h:97
void plot(const char *filename) const
Definition: Persistence_vectors.h:178
size_t number_of_projections_to_R() const
Definition: Persistence_vectors.h:140
friend Vector_distances_in_diagram operator*(double scalar, const Vector_distances_in_diagram &A)
Definition: Persistence_vectors.h:267
void compute_average(const std::vector< Vector_distances_in_diagram *> &to_average)
Definition: Persistence_vectors.h:490
Global distance functions.
bool operator==(const Vector_distances_in_diagram &second) const
Definition: Persistence_vectors.h:117
Vector_distances_in_diagram operator+=(const Vector_distances_in_diagram &rhs)
Definition: Persistence_vectors.h:283
std::pair< double, double > get_y_range() const
Definition: Persistence_vectors.h:204
friend Vector_distances_in_diagram operator*(const Vector_distances_in_diagram &A, double scalar)
Definition: Persistence_vectors.h:273
Vector_distances_in_diagram()
double compute_scalar_product(const Vector_distances_in_diagram &second) const
Definition: Persistence_vectors.h:616
double project_to_R(int number_of_function) const
Definition: Persistence_vectors.h:476
double distance(const Vector_distances_in_diagram &second, double power=1) const
Definition: Persistence_vectors.h:518
friend Vector_distances_in_diagram operator-(const Vector_distances_in_diagram &first, const Vector_distances_in_diagram &second)
Definition: Persistence_vectors.h:260
Vector_distances_in_diagram multiply_by_scalar(double scalar) const
Definition: Persistence_vectors.h:241
friend Vector_distances_in_diagram operator+(const Vector_distances_in_diagram &first, const Vector_distances_in_diagram &second)
Definition: Persistence_vectors.h:253
Vector_distances_in_diagram operator-=(const Vector_distances_in_diagram &rhs)
Definition: Persistence_vectors.h:290
