12 #ifndef EUCLIDEAN_WITNESS_COMPLEX_H_ 13 #define EUCLIDEAN_WITNESS_COMPLEX_H_ 15 #include <gudhi/Witness_complex.h> 16 #include <gudhi/Active_witness/Active_witness.h> 17 #include <gudhi/Kd_tree_search.h> 19 #include <CGAL/version.h> 21 #include <Eigen/src/Core/util/Macros.h> 29 #if CGAL_VERSION_NR < 1041101000 30 # error Euclidean_witness_complex is only available for CGAL >= 4.11 33 #if !EIGEN_VERSION_AT_LEAST(3,1,0) 34 # error Euclidean_witness_complex is only available for Eigen3 >= 3.1.0 installed with CGAL 39 namespace witness_complex {
50 template<
class Kernel_ >
52 :
public Witness_complex<std::vector<typename Gudhi::spatial_searching::Kd_tree_search<Kernel_,
53 std::vector<typename Kernel_::Point_d>>::INS_range>> {
56 typedef typename K::Point_d Point_d;
57 typedef std::vector<Point_d> Point_range;
60 typedef typename std::vector<Nearest_landmark_range> Nearest_landmark_table;
62 typedef typename Nearest_landmark_range::Point_with_transformed_distance Id_distance_pair;
63 typedef typename Id_distance_pair::first_type Landmark_id;
64 typedef Landmark_id Vertex_handle;
67 Point_range landmarks_;
68 Kd_tree landmark_tree_;
84 template<
typename LandmarkRange,
85 typename WitnessRange >
87 const WitnessRange & witnesses)
88 : landmarks_(std::begin(landmarks), std::end(landmarks)), landmark_tree_(landmarks) {
89 nearest_landmark_table_.reserve(boost::size(witnesses));
90 for (
auto w : witnesses)
98 return landmarks_[vertex];
108 #endif // EUCLIDEAN_WITNESS_COMPLEX_H_
Incremental_neighbor_search INS_range
The range returned by an incremental nearest or furthest neighbor search. Its value type is std::pair...
Definition: Kd_tree_search.h:112
Constructs (weak) witness complex for given sets of witnesses and landmarks in Euclidean space...
Definition: Euclidean_witness_complex.h:51
Definition: SimplicialComplexForAlpha.h:14
INS_range incremental_nearest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the nearest neighbors from a query point.
Definition: Kd_tree_search.h:271
Point_d get_point(Vertex_handle vertex) const
Returns the point corresponding to the given vertex.
Definition: Euclidean_witness_complex.h:97
Constructs (weak) witness complex for a given table of nearest landmarks with respect to witnesses...
Definition: Witness_complex.h:38
Euclidean_witness_complex(const LandmarkRange &landmarks, const WitnessRange &witnesses)
Initializes member variables before constructing simplicial complex.
Definition: Euclidean_witness_complex.h:86
