12 #ifndef EUCLIDEAN_STRONG_WITNESS_COMPLEX_H_ 13 #define EUCLIDEAN_STRONG_WITNESS_COMPLEX_H_ 15 #include <gudhi/Strong_witness_complex.h> 16 #include <gudhi/Active_witness/Active_witness.h> 17 #include <gudhi/Kd_tree_search.h> 19 #include <CGAL/version.h> 21 #include <Eigen/src/Core/util/Macros.h> 27 #if CGAL_VERSION_NR < 1041101000 28 # error Euclidean_strong_witness_complex is only available for CGAL >= 4.11 31 #if !EIGEN_VERSION_AT_LEAST(3,1,0) 32 # error Euclidean_strong_witness_complex is only available for Eigen3 >= 3.1.0 installed with CGAL 37 namespace witness_complex {
48 template<
class Kernel_ >
51 std::vector<typename Kernel_::Point_d>>::INS_range>> {
54 typedef typename K::Point_d Point_d;
55 typedef std::vector<Point_d> Point_range;
58 typedef typename std::vector<Nearest_landmark_range> Nearest_landmark_table;
60 typedef typename Nearest_landmark_range::Point_with_transformed_distance Id_distance_pair;
61 typedef typename Id_distance_pair::first_type Landmark_id;
62 typedef Landmark_id Vertex_handle;
65 Point_range landmarks_;
66 Kd_tree landmark_tree_;
82 template<
typename LandmarkRange,
83 typename WitnessRange >
85 const WitnessRange & witnesses)
86 : landmarks_(std::begin(landmarks), std::end(landmarks)), landmark_tree_(landmarks_) {
87 nearest_landmark_table_.reserve(boost::size(witnesses));
88 for (
auto w : witnesses)
94 template <
typename Vertex_handle>
96 return landmarks_[vertex];
106 #endif // EUCLIDEAN_STRONG_WITNESS_COMPLEX_H_
Incremental_neighbor_search INS_range
The range returned by an incremental nearest or furthest neighbor search. Its value type is std::pair...
Definition: Kd_tree_search.h:112
Definition: SimplicialComplexForAlpha.h:14
INS_range incremental_nearest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the nearest neighbors from a query point.
Definition: Kd_tree_search.h:271
Constructs strong witness complex for given sets of witnesses and landmarks in Euclidean space...
Definition: Euclidean_strong_witness_complex.h:49
Point_d get_point(Vertex_handle vertex) const
Returns the point corresponding to the given vertex.
Definition: Euclidean_strong_witness_complex.h:95
Euclidean_strong_witness_complex(const LandmarkRange &landmarks, const WitnessRange &witnesses)
Initializes member variables before constructing simplicial complex.
Definition: Euclidean_strong_witness_complex.h:84
Constructs strong witness complex for a given table of nearest landmarks with respect to witnesses...
Definition: Strong_witness_complex.h:40
