CoefficientField.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): ClĂ©ment Maria
4  *
5  * Copyright (C) 2014 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
15
19  typedef unspecified Element;
20
23
24  void init(Element charac);
25  void init(Element charac_min, Element charac_max);
26
28  Element characteristic();
30  Element multiplicative_identity();
32  Element additive_identity();
33
35  void plus_equal(Element x, Element y);
36
38 //... inverse()
39
40  };
unspecified Element
Type of element of the field.
Definition: CoefficientField.h:19
Concept describing the requirements for a class to represent a field of coefficients to compute persi...
Definition: CoefficientField.h:14
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:15 for GUDHI by Doxygen 1.8.13
