Loading [MathJax]/jax/output/HTML-CSS/config.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Alpha_complex/Weighted_alpha_complex_3d_from_points.cpp
#include <gudhi/Alpha_complex_3d.h>
// to construct a simplex_tree from alpha complex
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits> // for numeric limits
// Complexity = SAFE, weighted = true, periodic = false
using Weighted_alpha_complex_3d =
using Bare_point = Weighted_alpha_complex_3d::Bare_point_3;
using Weighted_point = Weighted_alpha_complex_3d::Weighted_point_3;
int main(int argc, char **argv) {
// Init of a list of points and weights from a small molecule
std::vector<Weighted_point> weighted_points;
weighted_points.emplace_back(Bare_point(1, -1, -1), 4.);
weighted_points.emplace_back(Bare_point(-1, 1, -1), 4.);
weighted_points.emplace_back(Bare_point(-1, -1, 1), 4.);
weighted_points.emplace_back(Bare_point(1, 1, 1), 4.);
weighted_points.emplace_back(Bare_point(2, 2, 2), 1.);
// Init of an alpha complex from the list of points
Weighted_alpha_complex_3d alpha_complex_from_points(weighted_points);
if (alpha_complex_from_points.create_complex(simplex)) {
// Display information about the alpha complex
std::clog << "Weighted alpha complex is of dimension " << simplex.dimension() << " - " << simplex.num_simplices()
<< " simplices - " << simplex.num_vertices() << " vertices." << std::endl;
std::clog << "Iterator on weighted alpha complex simplices in the filtration order, with [filtration value]:" << std::endl;
for (auto f_simplex : simplex.filtration_simplex_range()) {
std::clog << " ( ";
for (auto vertex : simplex.simplex_vertex_range(f_simplex)) {
std::clog << vertex << " ";
std::clog << ") -> "
<< "[" << simplex.filtration(f_simplex) << "] ";
std::clog << std::endl;
return 0;
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:15 for GUDHI by Doxygen 1.8.13
