graph_simplicial_complex.h
Go to the documentation of this file.
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): ClĂ©ment Maria
4  *
5  * Copyright (C) 2014 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef GRAPH_SIMPLICIAL_COMPLEX_H_
12 #define GRAPH_SIMPLICIAL_COMPLEX_H_
13
14 #include <boost/graph/adjacency_list.hpp>
15
16 #include <utility> // for pair<>
17 #include <vector>
18 #include <map>
19 #include <tuple> // for std::tie
20
21 namespace Gudhi {
26 /* Edge tag for Boost PropertyGraph. */
27 struct edge_filtration_t {
28  typedef boost::edge_property_tag kind;
29 };
30
31 /* Vertex tag for Boost PropertyGraph. */
32 struct vertex_filtration_t {
33  typedef boost::vertex_property_tag kind;
34 };
35
42 template <typename SimplicialComplexForProximityGraph>
43 using Proximity_graph = typename boost::adjacency_list < boost::vecS, boost::vecS, boost::directedS
44 , boost::property < vertex_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value >
45 , boost::property < edge_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value >>;
46
59 template< typename SimplicialComplexForProximityGraph
60  , typename ForwardPointRange
61  , typename Distance >
63  const ForwardPointRange& points,
64  typename SimplicialComplexForProximityGraph::Filtration_value threshold,
65  Distance distance) {
66  using Vertex_handle = typename SimplicialComplexForProximityGraph::Vertex_handle;
67  using Filtration_value = typename SimplicialComplexForProximityGraph::Filtration_value;
68
69  std::vector<std::pair< Vertex_handle, Vertex_handle >> edges;
70  std::vector< Filtration_value > edges_fil;
71  std::map< Vertex_handle, Filtration_value > vertices;
72
73  Vertex_handle idx_u, idx_v;
74  Filtration_value fil;
75  idx_u = 0;
76  for (auto it_u = points.begin(); it_u != points.end(); ++it_u) {
77  idx_v = idx_u + 1;
78  for (auto it_v = it_u + 1; it_v != points.end(); ++it_v, ++idx_v) {
79  fil = distance(*it_u, *it_v);
80  if (fil <= threshold) {
81  edges.emplace_back(idx_u, idx_v);
82  edges_fil.push_back(fil);
83  }
84  }
85  ++idx_u;
86  }
87
88  // Points are labeled from 0 to idx_u-1
89  Proximity_graph<SimplicialComplexForProximityGraph> skel_graph(edges.begin(), edges.end(), edges_fil.begin(), idx_u);
90
91  auto vertex_prop = boost::get(vertex_filtration_t(), skel_graph);
92
93  typename boost::graph_traits<Proximity_graph<SimplicialComplexForProximityGraph>>::vertex_iterator vi, vi_end;
94  for (std::tie(vi, vi_end) = boost::vertices(skel_graph);
95  vi != vi_end; ++vi) {
96  boost::put(vertex_prop, *vi, 0.);
97  }
98
99  return skel_graph;
100 }
101
102 } // namespace Gudhi
103
104 #endif // GRAPH_SIMPLICIAL_COMPLEX_H_
typename boost::adjacency_list< boost::vecS, boost::vecS, boost::directedS, boost::property< vertex_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value >, boost::property< edge_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > > Proximity_graph
Proximity_graph contains the vertices and edges with their filtration values in order to store the re...
Definition: graph_simplicial_complex.h:45
Definition: SimplicialComplexForAlpha.h:14
Proximity_graph< SimplicialComplexForProximityGraph > compute_proximity_graph(const ForwardPointRange &points, typename SimplicialComplexForProximityGraph::Filtration_value threshold, Distance distance)
Computes the proximity graph of the points.
Definition: graph_simplicial_complex.h:62
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
GUDHI  Version 3.4.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Dec 15 2020 16:00:41 for GUDHI by Doxygen 1.8.13
