Gudhi::cover_complex::Cover_complex< Point > Member List
This is the complete list of members for Gudhi::cover_complex::Cover_complex< Point >, including all inherited members.
compute_confidence_level_from_distance(double d)Gudhi::cover_complex::Cover_complex< Point >inline
compute_distance_from_confidence_level(double alpha)Gudhi::cover_complex::Cover_complex< Point >inline
compute_distribution(unsigned int N=100)Gudhi::cover_complex::Cover_complex< Point >inline
compute_p_value()Gudhi::cover_complex::Cover_complex< Point >inline
compute_PD()Gudhi::cover_complex::Cover_complex< Point >inline
create_complex(SimplicialComplex &complex)Gudhi::cover_complex::Cover_complex< Point >inline
find_simplices()Gudhi::cover_complex::Cover_complex< Point >inline
plot_DOT()Gudhi::cover_complex::Cover_complex< Point >inline
plot_OFF()Gudhi::cover_complex::Cover_complex< Point >inline
read_point_cloud(const std::string &off_file_name)Gudhi::cover_complex::Cover_complex< Point >inline
set_automatic_resolution()Gudhi::cover_complex::Cover_complex< Point >inline
set_color_from_coordinate(int k=0)Gudhi::cover_complex::Cover_complex< Point >inline
set_color_from_file(const std::string &color_file_name)Gudhi::cover_complex::Cover_complex< Point >inline
set_color_from_range(std::vector< double > color)Gudhi::cover_complex::Cover_complex< Point >inline
set_cover_from_file(const std::string &cover_file_name)Gudhi::cover_complex::Cover_complex< Point >inline
set_cover_from_function()Gudhi::cover_complex::Cover_complex< Point >inline
set_cover_from_Voronoi(Distance distance, int m=100)Gudhi::cover_complex::Cover_complex< Point >inline
set_distances_from_range(const std::vector< std::vector< double > > &distance_matrix)Gudhi::cover_complex::Cover_complex< Point >inline
set_function_from_coordinate(int k)Gudhi::cover_complex::Cover_complex< Point >inline
set_function_from_file(const std::string &func_file_name)Gudhi::cover_complex::Cover_complex< Point >inline
set_function_from_range(InputRange const &function)Gudhi::cover_complex::Cover_complex< Point >inline
set_gain(double g=0.3)Gudhi::cover_complex::Cover_complex< Point >inline
set_graph_from_automatic_rips(Distance distance, int N=100)Gudhi::cover_complex::Cover_complex< Point >inline
set_graph_from_file(const std::string &graph_file_name)Gudhi::cover_complex::Cover_complex< Point >inline
set_graph_from_OFF()Gudhi::cover_complex::Cover_complex< Point >inline
set_graph_from_rips(double threshold, Distance distance)Gudhi::cover_complex::Cover_complex< Point >inline
set_mask(int nodemask)Gudhi::cover_complex::Cover_complex< Point >inline
set_point_cloud_from_range(const std::vector< std::vector< double > > &point_cloud)Gudhi::cover_complex::Cover_complex< Point >inline
set_resolution_with_interval_length(double reso)Gudhi::cover_complex::Cover_complex< Point >inline
set_resolution_with_interval_number(int reso)Gudhi::cover_complex::Cover_complex< Point >inline
set_subsampling(double constant, double power)Gudhi::cover_complex::Cover_complex< Point >inline
set_type(const std::string &t)Gudhi::cover_complex::Cover_complex< Point >inline
set_verbose(bool verb=false)Gudhi::cover_complex::Cover_complex< Point >inline
subpopulation(int c)Gudhi::cover_complex::Cover_complex< Point >inline
write_info()Gudhi::cover_complex::Cover_complex< Point >inline
GUDHI  Version 3.4.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Dec 15 2020 16:00:42 for GUDHI by Doxygen 1.8.13
