Rips_complex/example_one_skeleton_rips_from_distance_matrix.cpp
#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits> // for std::numeric_limits
int main() {
// Type definitions
using Distance_matrix = std::vector<std::vector<Filtration_value>>;
// User defined distance matrix is:
// | 0 0.94 0.77 0.99 0.11 |
// | 0.94 0 0.26 0.99 0.39 |
// | 0.77 0.26 0 0.28 0.97 |
// | 0.99 0.99 0.28 0 0.30 |
// | 0.11 0.39 0.97 0.30 0 |
Distance_matrix distances;
distances.push_back({});
distances.push_back({0.94});
distances.push_back({0.77, 0.26});
distances.push_back({0.99, 0.99, 0.28});
distances.push_back({0.11, 0.39, 0.97, 0.30});
// Init of a Rips complex from points
double threshold = 1.0;
Rips_complex rips_complex_from_points(distances, threshold);
Simplex_tree stree;
rips_complex_from_points.create_complex(stree, 1);
// Display information about the one skeleton Rips complex
std::clog << "Rips complex is of dimension " << stree.dimension() <<
" - " << stree.num_simplices() << " simplices - " <<
stree.num_vertices() << " vertices." << std::endl;
std::clog << "Iterator on Rips complex simplices in the filtration order, with [filtration value]:" <<
std::endl;
for (auto f_simplex : stree.filtration_simplex_range()) {
std::clog << " ( ";
for (auto vertex : stree.simplex_vertex_range(f_simplex)) {
std::clog << vertex << " ";
std::clog << ") -> " << "[" << stree.filtration(f_simplex) << "] ";
std::clog << std::endl;
return 0;
GUDHI  Version 3.4.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Dec 15 2020 16:00:41 for GUDHI by Doxygen 1.8.13
