Bitmap_cubical_complex/cubical_complex_persistence.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2015 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Bitmap_cubical_complex.h>
#include <gudhi/Persistent_cohomology.h>
// standard stuff
#include <iostream>
#include <string>
#include <vector>
#include <cstddef>
int main(int argc, char** argv) {
std::clog
<< "This program computes persistent homology, by using bitmap_cubical_complex class, of cubical "
<< "complexes provided in text files in Perseus style (the only numbered in the first line is a dimension D of a"
<< "bitmap. In the lines I between 2 and D+1 there are numbers of top dimensional cells in the direction I. Let "
<< "N denote product of the numbers in the lines between 2 and D. In the lines D+2 to D+2+N there are "
<< "filtrations of top dimensional cells. We assume that the cells are in the lexicographical order. See "
<< "CubicalOneSphere.txt or CubicalTwoSphere.txt for example.\n"
<< std::endl;
if (argc != 2) {
std::cerr << "Wrong number of parameters. Please provide the name of a file with a Perseus style bitmap at "
<< "the input. The program will now terminate.\n";
return 1;
Bitmap_cubical_complex b(argv[1]);
// Compute the persistence diagram of the complex
Persistent_cohomology pcoh(b);
int p = 11;
double min_persistence = 0;
pcoh.init_coefficients(p); // initializes the coefficient field for homology
pcoh.compute_persistent_cohomology(min_persistence);
std::string output_file_name(argv[1]);
output_file_name += "_persistence";
std::size_t last_in_path = output_file_name.find_last_of("/\\");
if (last_in_path != std::string::npos) {
output_file_name = output_file_name.substr(last_in_path + 1);
std::ofstream out(output_file_name.c_str());
pcoh.output_diagram(out);
out.close();
std::clog << "Result in file: " << output_file_name << "\n";
return 0;
GUDHI  Version 3.4.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Dec 15 2020 16:00:41 for GUDHI by Doxygen 1.8.13
