Bitmap_cubical_complex_periodic_boundary_conditions_base.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Pawel Dlotko
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef BITMAP_CUBICAL_COMPLEX_PERIODIC_BOUNDARY_CONDITIONS_BASE_H_
12 #define BITMAP_CUBICAL_COMPLEX_PERIODIC_BOUNDARY_CONDITIONS_BASE_H_
13
14 #include <gudhi/Bitmap_cubical_complex_base.h>
15
16 #include <cmath>
17 #include <limits> // for numeric_limits<>
18 #include <vector>
19 #include <stdexcept>
20 #include <cstddef>
21
22 namespace Gudhi {
23
24 namespace cubical_complex {
25
26 // in this class, we are storing all the elements which are in normal bitmap (i.e. the bitmap without the periodic
27 // boundary conditions). But, we set up the iterators and the procedures to compute boundary and coboundary in the way
28 // that it is all right. We assume here that all the cells that are on the left / bottom and so on remains, while all
29 // the cells on the right / top are not in the Bitmap_cubical_complex_periodic_boundary_conditions_base
30
39 template <typename T>
41  public:
42  // constructors that take an extra parameter:
43
56  const std::vector<unsigned>& sizes,
57  const std::vector<bool>& directions_in_which_periodic_b_cond_are_to_be_imposed);
71  const std::vector<unsigned>& dimensions, const std::vector<T>& topDimensionalCells,
72  const std::vector<bool>& directions_in_which_periodic_b_cond_are_to_be_imposed);
73
78
79  // overwritten methods co compute boundary and coboundary
86  virtual std::vector<std::size_t> get_boundary_of_a_cell(std::size_t cell) const override;
87
96  virtual std::vector<std::size_t> get_coboundary_of_a_cell(std::size_t cell) const override;
97
117  virtual int compute_incidence_between_cells(std::size_t coface, std::size_t face) const override {
118  // first get the counters for coface and face:
119  std::vector<unsigned> coface_counter = this->compute_counter_for_given_cell(coface);
120  std::vector<unsigned> face_counter = this->compute_counter_for_given_cell(face);
121
122  // coface_counter and face_counter should agree at all positions except from one:
123  int number_of_position_in_which_counters_do_not_agree = -1;
124  std::size_t number_of_full_faces_that_comes_before = 0;
125  for (std::size_t i = 0; i != coface_counter.size(); ++i) {
126  if ((coface_counter[i] % 2 == 1) && (number_of_position_in_which_counters_do_not_agree == -1)) {
127  ++number_of_full_faces_that_comes_before;
128  }
129  if (coface_counter[i] != face_counter[i]) {
130  if (number_of_position_in_which_counters_do_not_agree != -1) {
131  std::cerr << "Cells given to compute_incidence_between_cells procedure do not form a pair of coface-face.\n";
132  throw std::logic_error(
133  "Cells given to compute_incidence_between_cells procedure do not form a pair of coface-face.");
134  }
135  number_of_position_in_which_counters_do_not_agree = i;
136  }
137  }
138
139  int incidence = 1;
140  if (number_of_full_faces_that_comes_before % 2) incidence = -1;
141  // if the face cell is on the right from coface cell:
142  if ((coface_counter[number_of_position_in_which_counters_do_not_agree] + 1 ==
143  face_counter[number_of_position_in_which_counters_do_not_agree]) ||
144  ((coface_counter[number_of_position_in_which_counters_do_not_agree] != 1) &&
145  (face_counter[number_of_position_in_which_counters_do_not_agree] == 0))) {
146  incidence *= -1;
147  }
148
149  return incidence;
150  }
151
152  protected:
153  std::vector<bool> directions_in_which_periodic_b_cond_are_to_be_imposed;
154
155  void set_up_containers(const std::vector<unsigned>& sizes) {
156  unsigned multiplier = 1;
157  for (std::size_t i = 0; i != sizes.size(); ++i) {
158  this->sizes.push_back(sizes[i]);
159  this->multipliers.push_back(multiplier);
160
161  if (directions_in_which_periodic_b_cond_are_to_be_imposed[i]) {
162  multiplier *= 2 * sizes[i];
163  } else {
164  multiplier *= 2 * sizes[i] + 1;
165  }
166  }
167  // std::reverse( this->sizes.begin() , this->sizes.end() );
168  this->data = std::vector<T>(multiplier, std::numeric_limits<T>::infinity());
169  this->total_number_of_cells = multiplier;
170  }
171  Bitmap_cubical_complex_periodic_boundary_conditions_base(const std::vector<unsigned>& sizes);
172  Bitmap_cubical_complex_periodic_boundary_conditions_base(const std::vector<unsigned>& dimensions,
173  const std::vector<T>& topDimensionalCells);
174
178  void construct_complex_based_on_top_dimensional_cells(
179  const std::vector<unsigned>& dimensions, const std::vector<T>& topDimensionalCells,
180  const std::vector<bool>& directions_in_which_periodic_b_cond_are_to_be_imposed);
181 };
182
183 template <typename T>
185  const std::vector<unsigned>& dimensions, const std::vector<T>& topDimensionalCells,
186  const std::vector<bool>& directions_in_which_periodic_b_cond_are_to_be_imposed) {
187  this->directions_in_which_periodic_b_cond_are_to_be_imposed = directions_in_which_periodic_b_cond_are_to_be_imposed;
188  this->set_up_containers(dimensions);
189
190  std::size_t i = 0;
191  for (auto it = this->top_dimensional_cells_iterator_begin(); it != this->top_dimensional_cells_iterator_end(); ++it) {
192  this->get_cell_data(*it) = topDimensionalCells[i];
193  ++i;
194  }
196 }
197
198 template <typename T>
200  const std::vector<unsigned>& sizes,
201  const std::vector<bool>& directions_in_which_periodic_b_cond_are_to_be_imposed) {
202  this->directions_in_which_periodic_b_cond_are_to_be_imposed(directions_in_which_periodic_b_cond_are_to_be_imposed);
203  this->set_up_containers(sizes);
204 }
205
206 template <typename T>
208  const char* perseus_style_file) {
209  // for Perseus style files:
210  bool dbg = false;
211
212  std::ifstream inFiltration;
213  inFiltration.open(perseus_style_file);
214  unsigned dimensionOfData;
215  inFiltration >> dimensionOfData;
216
217  this->directions_in_which_periodic_b_cond_are_to_be_imposed = std::vector<bool>(dimensionOfData, false);
218
219  std::vector<unsigned> sizes;
220  sizes.reserve(dimensionOfData);
221  for (std::size_t i = 0; i != dimensionOfData; ++i) {
222  int size_in_this_dimension;
223  inFiltration >> size_in_this_dimension;
224  if (size_in_this_dimension < 0) {
225  this->directions_in_which_periodic_b_cond_are_to_be_imposed[i] = true;
226  }
227  sizes.push_back(abs(size_in_this_dimension));
228  }
229  this->set_up_containers(sizes);
230
233
234  while (!inFiltration.eof()) {
235  double filtrationLevel;
236  inFiltration >> filtrationLevel;
237  if (inFiltration.eof()) break;
238
239  if (dbg) {
240  std::clog << "Cell of an index : " << it.compute_index_in_bitmap()
241  << " and dimension: " << this->get_dimension_of_a_cell(it.compute_index_in_bitmap())
242  << " get the value : " << filtrationLevel << std::endl;
243  }
244  this->get_cell_data(*it) = filtrationLevel;
245  ++it;
246  }
247  inFiltration.close();
249 }
250
251 template <typename T>
253  const std::vector<unsigned>& sizes) {
254  this->directions_in_which_periodic_b_cond_are_to_be_imposed = std::vector<bool>(sizes.size(), false);
255  this->set_up_containers(sizes);
256 }
257
258 template <typename T>
260  const std::vector<unsigned>& dimensions, const std::vector<T>& topDimensionalCells) {
261  std::vector<bool> directions_in_which_periodic_b_cond_are_to_be_imposed = std::vector<bool>(dimensions.size(), false);
262  this->construct_complex_based_on_top_dimensional_cells(dimensions, topDimensionalCells,
263  directions_in_which_periodic_b_cond_are_to_be_imposed);
264 }
265
266 template <typename T>
268  const std::vector<unsigned>& dimensions, const std::vector<T>& topDimensionalCells,
269  const std::vector<bool>& directions_in_which_periodic_b_cond_are_to_be_imposed) {
270  this->construct_complex_based_on_top_dimensional_cells(dimensions, topDimensionalCells,
271  directions_in_which_periodic_b_cond_are_to_be_imposed);
272 }
273
274 // ***********************Methods************************ //
275
276 template <typename T>
278  std::size_t cell) const {
279  bool dbg = false;
280  if (dbg) {
281  std::clog << "Computations of boundary of a cell : " << cell << std::endl;
282  }
283
284  std::vector<std::size_t> boundary_elements;
285  boundary_elements.reserve(this->dimension() * 2);
286  std::size_t cell1 = cell;
287  std::size_t sum_of_dimensions = 0;
288
289  for (std::size_t i = this->multipliers.size(); i != 0; --i) {
290  unsigned position = cell1 / this->multipliers[i - 1];
291  // this cell have a nonzero length in this direction, therefore we can compute its boundary in this direction.
292  if (position % 2 == 1) {
293  // if there are no periodic boundary conditions in this direction, we do not have to do anything.
294  if (!directions_in_which_periodic_b_cond_are_to_be_imposed[i - 1]) {
295  if (sum_of_dimensions % 2) {
296  boundary_elements.push_back(cell - this->multipliers[i - 1]);
297  boundary_elements.push_back(cell + this->multipliers[i - 1]);
298  } else {
299  boundary_elements.push_back(cell + this->multipliers[i - 1]);
300  boundary_elements.push_back(cell - this->multipliers[i - 1]);
301  }
302  if (dbg) {
303  std::clog << cell - this->multipliers[i - 1] << " " << cell + this->multipliers[i - 1] << " ";
304  }
305  } else {
306  // in this direction we have to do boundary conditions. Therefore, we need to check if we are not at the end.
307  if (position != 2 * this->sizes[i - 1] - 1) {
308  if (sum_of_dimensions % 2) {
309  boundary_elements.push_back(cell - this->multipliers[i - 1]);
310  boundary_elements.push_back(cell + this->multipliers[i - 1]);
311  } else {
312  boundary_elements.push_back(cell + this->multipliers[i - 1]);
313  boundary_elements.push_back(cell - this->multipliers[i - 1]);
314  }
315  if (dbg) {
316  std::clog << cell - this->multipliers[i - 1] << " " << cell + this->multipliers[i - 1] << " ";
317  }
318  } else {
319  if (sum_of_dimensions % 2) {
320  boundary_elements.push_back(cell - this->multipliers[i - 1]);
321  boundary_elements.push_back(cell - (2 * this->sizes[i - 1] - 1) * this->multipliers[i - 1]);
322  } else {
323  boundary_elements.push_back(cell - (2 * this->sizes[i - 1] - 1) * this->multipliers[i - 1]);
324  boundary_elements.push_back(cell - this->multipliers[i - 1]);
325  }
326  if (dbg) {
327  std::clog << cell - this->multipliers[i - 1] << " "
328  << cell - (2 * this->sizes[i - 1] - 1) * this->multipliers[i - 1] << " ";
329  }
330  }
331  }
332  ++sum_of_dimensions;
333  }
334  cell1 = cell1 % this->multipliers[i - 1];
335  }
336  return boundary_elements;
337 }
338
339 template <typename T>
341  std::size_t cell) const {
342  std::vector<unsigned> counter = this->compute_counter_for_given_cell(cell);
343  std::vector<std::size_t> coboundary_elements;
344  std::size_t cell1 = cell;
345  for (std::size_t i = this->multipliers.size(); i != 0; --i) {
346  unsigned position = cell1 / this->multipliers[i - 1];
347  // if the cell has zero length in this direction, then it will have cbd in this direction.
348  if (position % 2 == 0) {
349  if (!this->directions_in_which_periodic_b_cond_are_to_be_imposed[i - 1]) {
350  // no periodic boundary conditions in this direction
351  if ((counter[i - 1] != 0) && (cell > this->multipliers[i - 1])) {
352  coboundary_elements.push_back(cell - this->multipliers[i - 1]);
353  }
354  if ((counter[i - 1] != 2 * this->sizes[i - 1]) && (cell + this->multipliers[i - 1] < this->data.size())) {
355  coboundary_elements.push_back(cell + this->multipliers[i - 1]);
356  }
357  } else {
358  // we want to have periodic boundary conditions in this direction
359  if (counter[i - 1] != 0) {
360  coboundary_elements.push_back(cell - this->multipliers[i - 1]);
361  coboundary_elements.push_back(cell + this->multipliers[i - 1]);
362  } else {
363  // in this case counter[i-1] == 0.
364  coboundary_elements.push_back(cell + this->multipliers[i - 1]);
365  coboundary_elements.push_back(cell + (2 * this->sizes[i - 1] - 1) * this->multipliers[i - 1]);
366  }
367  }
368  }
369
370  cell1 = cell1 % this->multipliers[i - 1];
371  }
372  return coboundary_elements;
373 }
374
375 } // namespace cubical_complex
376
377 namespace Cubical_complex = cubical_complex;
378
379 } // namespace Gudhi
380
381 #endif // BITMAP_CUBICAL_COMPLEX_PERIODIC_BOUNDARY_CONDITIONS_BASE_H_
void impose_lower_star_filtration()
Definition: Bitmap_cubical_complex_base.h:809
unsigned dimension() const
Definition: Bitmap_cubical_complex_base.h:207
T & get_cell_data(std::size_t cell)
Definition: Bitmap_cubical_complex_base.h:804
Cubical complex with periodic boundary conditions represented as a bitmap.
Definition: Bitmap_cubical_complex_periodic_boundary_conditions_base.h:40
Cubical complex represented as a bitmap, class with basic implementation.
Definition: Bitmap_cubical_complex_base.h:53
unsigned get_dimension_of_a_cell(std::size_t cell) const
Definition: Bitmap_cubical_complex_base.h:780
Definition: SimplicialComplexForAlpha.h:14
This is an implementation of a counter being a vector of integers.
Definition: counter.h:32
Bitmap_cubical_complex_periodic_boundary_conditions_base()
Definition: Bitmap_cubical_complex_periodic_boundary_conditions_base.h:47
Top_dimensional_cells_iterator top_dimensional_cells_iterator_end()
Definition: Bitmap_cubical_complex_base.h:444
Top_dimensional_cells_iterator top_dimensional_cells_iterator_begin()
Definition: Bitmap_cubical_complex_base.h:436
virtual std::vector< std::size_t > get_coboundary_of_a_cell(std::size_t cell) const override
Definition: Bitmap_cubical_complex_periodic_boundary_conditions_base.h:340
virtual ~Bitmap_cubical_complex_periodic_boundary_conditions_base()
Definition: Bitmap_cubical_complex_periodic_boundary_conditions_base.h:77
Definition: Bitmap_cubical_complex_periodic_boundary_conditions_base.h:117
Iterator through top dimensional cells of the complex. The cells appear in order they are stored in t...
Definition: Bitmap_cubical_complex_base.h:358
virtual std::vector< std::size_t > get_boundary_of_a_cell(std::size_t cell) const override
Definition: Bitmap_cubical_complex_periodic_boundary_conditions_base.h:277
GUDHI  Version 3.4.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Dec 15 2020 16:00:41 for GUDHI by Doxygen 1.8.13
