Alpha_complex.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL and Eigen3
9  * - YYYY/MM Author: Description of the modification
10  */
11
12 #ifndef ALPHA_COMPLEX_H_
13 #define ALPHA_COMPLEX_H_
14
15 #include <gudhi/Alpha_complex/Alpha_kernel_d.h>
16 #include <gudhi/Debug_utils.h>
17 // to construct Alpha_complex from a OFF file of points
18 #include <gudhi/Points_off_io.h>
19
20 #include <stdlib.h>
21 #include <math.h> // isnan, fmax
22 #include <memory> // for std::unique_ptr
23
24 #include <CGAL/Delaunay_triangulation.h>
25 #include <CGAL/Regular_triangulation.h> // aka. Weighted Delaunay triangulation
26 #include <CGAL/Epeck_d.h> // For EXACT or SAFE version
27 #include <CGAL/Epick_d.h> // For FAST version
28 #include <CGAL/Spatial_sort_traits_adapter_d.h>
29 #include <CGAL/property_map.h> // for CGAL::Identity_property_map
30 #include <CGAL/version.h> // for CGAL_VERSION_NR
31 #include <CGAL/NT_converter.h>
32
33 #include <Eigen/src/Core/util/Macros.h> // for EIGEN_VERSION_AT_LEAST
34
35 #include <boost/range/size.hpp>
36 #include <boost/range/combine.hpp>
37 #include <boost/range/adaptor/transformed.hpp>
38
39 #include <iostream>
40 #include <vector>
41 #include <string>
42 #include <limits> // NaN
43 #include <map>
44 #include <utility> // std::pair
45 #include <stdexcept>
46 #include <numeric> // for std::iota
47
48 // Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
49 #if CGAL_VERSION_NR < 1041101000
50 # error Alpha_complex is only available for CGAL >= 4.11
51 #endif
52
53 #if !EIGEN_VERSION_AT_LEAST(3,1,0)
54 # error Alpha_complex is only available for Eigen3 >= 3.1.0 installed with CGAL
55 #endif
56
57 namespace Gudhi {
58
59 namespace alpha_complex {
60
61 template<typename D> struct Is_Epeck_D { static const bool value = false; };
62 template<typename D> struct Is_Epeck_D<CGAL::Epeck_d<D>> { static const bool value = true; };
63
101 template<class Kernel = CGAL::Epeck_d<CGAL::Dynamic_dimension_tag>, bool Weighted = false>
103  public:
105  using Geom_traits = std::conditional_t<Weighted, CGAL::Regular_triangulation_traits_adapter<Kernel>, Kernel>;
106
107  // Add an int in TDS to save point index in the structure
108  using TDS = CGAL::Triangulation_data_structure<typename Geom_traits::Dimension,
109  CGAL::Triangulation_vertex<Geom_traits, std::ptrdiff_t>,
110  CGAL::Triangulation_full_cell<Geom_traits> >;
111
113  using Triangulation = std::conditional_t<Weighted, CGAL::Regular_triangulation<Kernel, TDS>,
114  CGAL::Delaunay_triangulation<Kernel, TDS>>;
115
118
119  // Numeric type of coordinates in the kernel
120  using FT = typename A_kernel_d::FT;
121
125  using Sphere = typename A_kernel_d::Sphere;
126
128  using Point_d = typename Geom_traits::Point_d;
129
130  private:
131  // Vertex_iterator type from CGAL.
132  using CGAL_vertex_iterator = typename Triangulation::Vertex_iterator;
133
134  // size_type type from CGAL.
135  using size_type = typename Triangulation::size_type;
136
137  // Structure to switch from simplex tree vertex handle to CGAL vertex iterator.
138  using Vector_vertex_iterator = std::vector< CGAL_vertex_iterator >;
139
140  private:
143  Vector_vertex_iterator vertex_handle_to_iterator_;
145  std::unique_ptr<Triangulation> triangulation_;
147  A_kernel_d kernel_;
148
150  std::vector<Sphere> cache_, old_cache_;
151
152  public:
162  Alpha_complex(const std::string& off_file_name) {
163  Gudhi::Points_off_reader<Point_d> off_reader(off_file_name);
164  if (!off_reader.is_valid()) {
165  std::cerr << "Alpha_complex - Unable to read file " << off_file_name << "\n";
166  exit(-1); // ----- >>
167  }
168
169  init_from_range(off_reader.get_point_cloud());
170  }
171
182  template<typename InputPointRange >
183  Alpha_complex(const InputPointRange& points) {
184  init_from_range(points);
185  }
186
199  template <typename InputPointRange, typename WeightRange>
200  Alpha_complex(const InputPointRange& points, WeightRange weights) {
201  static_assert(Weighted, "This constructor is not available for non-weighted versions of Alpha_complex");
202  // FIXME: this test is only valid if we have a forward range
203  GUDHI_CHECK(boost::size(weights) == boost::size(points),
204  std::invalid_argument("Points number in range different from weights range number"));
205  auto weighted_points = boost::range::combine(points, weights)
206  | boost::adaptors::transformed([](auto const&t){return Point_d(boost::get<0>(t), boost::get<1>(t));});
207  init_from_range(weighted_points);
208  }
209
210  // Forbid copy/move constructor/assignment operator
211  Alpha_complex(const Alpha_complex& other) = delete;
212  Alpha_complex& operator= (const Alpha_complex& other) = delete;
213  Alpha_complex (Alpha_complex&& other) = delete;
214  Alpha_complex& operator= (Alpha_complex&& other) = delete;
215
222  const Point_d& get_point(std::size_t vertex) const {
223  return vertex_handle_to_iterator_.at(vertex)->point();
224  }
225
226  private:
227  template<typename InputPointRange >
228  void init_from_range(const InputPointRange& points) {
229  #if CGAL_VERSION_NR < 1050000000
230  if (Is_Epeck_D<Kernel>::value)
231  std::cerr << "It is strongly advised to use a CGAL version >= 5.0 with Epeck_d Kernel for performance reasons."
232  << std::endl;
233  #endif
234
235 #if CGAL_VERSION_NR < 1050101000
236  // Make compilation fail if weighted and CGAL < 5.1
237  static_assert(!Weighted, "Weighted Alpha_complex is only available for CGAL >= 5.1");
238 #endif
239
240  auto first = std::begin(points);
241  auto last = std::end(points);
242
243  if (first != last) {
244  // Delaunay triangulation init with point dimension.
245  triangulation_ = std::make_unique<Triangulation>(kernel_.get_dimension(*first));
246
247  std::vector<Point_d> point_cloud(first, last);
248
249  // Creates a vector {0, 1, ..., N-1}
250  std::vector<std::ptrdiff_t> indices(boost::counting_iterator<std::ptrdiff_t>(0),
251  boost::counting_iterator<std::ptrdiff_t>(point_cloud.size()));
252
253  using Point_property_map = boost::iterator_property_map<typename std::vector<Point_d>::iterator,
254  CGAL::Identity_property_map<std::ptrdiff_t>>;
255  using Search_traits_d = CGAL::Spatial_sort_traits_adapter_d<Geom_traits, Point_property_map>;
256
257  CGAL::spatial_sort(indices.begin(), indices.end(), Search_traits_d(std::begin(point_cloud)));
258
259  typename Triangulation::Full_cell_handle hint;
260  for (auto index : indices) {
261  typename Triangulation::Vertex_handle pos = triangulation_->insert(point_cloud[index], hint);
262  if (pos != nullptr) {
263  // Save index value as data to retrieve it after insertion
264  pos->data() = index;
265  hint = pos->full_cell();
266  }
267  }
268  // --------------------------------------------------------------------------------------------
269  // structure to retrieve CGAL points from vertex handle - one vertex handle per point.
270  // Needs to be constructed before as vertex handles arrives in no particular order.
271  vertex_handle_to_iterator_.resize(point_cloud.size());
272  // Loop on triangulation vertices list
273  for (CGAL_vertex_iterator vit = triangulation_->vertices_begin(); vit != triangulation_->vertices_end(); ++vit) {
274  if (!triangulation_->is_infinite(*vit)) {
275 #ifdef DEBUG_TRACES
276  std::clog << "Vertex insertion - " << vit->data() << " -> " << vit->point() << std::endl;
277 #endif // DEBUG_TRACES
278  vertex_handle_to_iterator_[vit->data()] = vit;
279  }
280  }
281  // --------------------------------------------------------------------------------------------
282  }
283  }
284
291  const Point_d& get_point_(std::size_t vertex) const {
292  return vertex_handle_to_iterator_[vertex]->point();
293  }
294
296  template<class SimplicialComplexForAlpha>
297  auto& get_cache(SimplicialComplexForAlpha& cplx, typename SimplicialComplexForAlpha::Simplex_handle s) {
298  auto k = cplx.key(s);
299  if(k==cplx.null_key()){
300  k = cache_.size();
301  cplx.assign_key(s, k);
302  // Using a transform_range is slower, currently.
303  thread_local std::vector<Point_d> v;
304  v.clear();
305  for (auto vertex : cplx.simplex_vertex_range(s))
306  v.push_back(get_point_(vertex));
307  cache_.emplace_back(kernel_.get_sphere(v.cbegin(), v.cend()));
308  }
309  return cache_[k];
310  }
311
313  template<class SimplicialComplexForAlpha>
315  auto k = cplx.key(s);
316  if(k!=cplx.null_key())
317  return kernel_.get_squared_radius(old_cache_[k]);
318  // Using a transform_range is slower, currently.
319  thread_local std::vector<Point_d> v;
320  v.clear();
321  for (auto vertex : cplx.simplex_vertex_range(s))
322  v.push_back(get_point_(vertex));
323  return kernel_.get_squared_radius(v.cbegin(), v.cend());
324  }
325
326  public:
350  template <typename SimplicialComplexForAlpha,
353  Filtration_value max_alpha_square = std::numeric_limits<Filtration_value>::infinity(),
354  bool exact = false,
355  bool default_filtration_value = false) {
356  // From SimplicialComplexForAlpha type required to insert into a simplicial complex (with or without subfaces).
358  using Simplex_handle = typename SimplicialComplexForAlpha::Simplex_handle;
359  using Vector_vertex = std::vector<Vertex_handle>;
360
361  if (triangulation_ == nullptr) {
362  std::cerr << "Alpha_complex cannot create_complex from a NULL triangulation\n";
363  return false; // ----- >>
364  }
365  if (triangulation_->maximal_dimension() < 1) {
366  std::cerr << "Alpha_complex cannot create_complex from a zero-dimension triangulation\n";
367  return false; // ----- >>
368  }
369  if (complex.num_vertices() > 0) {
370  std::cerr << "Alpha_complex create_complex - complex is not empty\n";
371  return false; // ----- >>
372  }
373
374  // --------------------------------------------------------------------------------------------
375  // Simplex_tree construction from loop on triangulation finite full cells list
376  if (triangulation_->number_of_vertices() > 0) {
377  for (auto cit = triangulation_->finite_full_cells_begin();
378  cit != triangulation_->finite_full_cells_end();
379  ++cit) {
380  Vector_vertex vertexVector;
381 #ifdef DEBUG_TRACES
382  std::clog << "Simplex_tree insertion ";
383 #endif // DEBUG_TRACES
384  for (auto vit = cit->vertices_begin(); vit != cit->vertices_end(); ++vit) {
385  if (*vit != nullptr) {
386 #ifdef DEBUG_TRACES
387  std::clog << " " << (*vit)->data();
388 #endif // DEBUG_TRACES
389  // Vector of vertex construction for simplex_tree structure
390  vertexVector.push_back((*vit)->data());
391  }
392  }
393 #ifdef DEBUG_TRACES
394  std::clog << std::endl;
395 #endif // DEBUG_TRACES
396  // Insert each simplex and its subfaces in the simplex tree - filtration is NaN
397  complex.insert_simplex_and_subfaces(vertexVector, std::numeric_limits<double>::quiet_NaN());
398  }
399  }
400  // --------------------------------------------------------------------------------------------
401
402  if (!default_filtration_value) {
403  CGAL::NT_converter<FT, Filtration_value> cgal_converter;
404  // --------------------------------------------------------------------------------------------
405  // ### For i : d -> 0
406  for (int decr_dim = triangulation_->maximal_dimension(); decr_dim >= 0; decr_dim--) {
407  // ### Foreach Sigma of dim i
408  for (Simplex_handle f_simplex : complex.skeleton_simplex_range(decr_dim)) {
409  int f_simplex_dim = complex.dimension(f_simplex);
410  if (decr_dim == f_simplex_dim) {
411  // ### If filt(Sigma) is NaN : filt(Sigma) = alpha(Sigma)
412  if (std::isnan(complex.filtration(f_simplex))) {
413  Filtration_value alpha_complex_filtration = 0.0;
414  // No need to compute squared_radius on a non-weighted single point - alpha is 0.0
415  if (Weighted || f_simplex_dim > 0) {
416  auto const& sqrad = radius(complex, f_simplex);
417 #if CGAL_VERSION_NR >= 1050000000
418  if(exact) CGAL::exact(sqrad);
419 #endif
420  alpha_complex_filtration = cgal_converter(sqrad);
421  }
422  complex.assign_filtration(f_simplex, alpha_complex_filtration);
423 #ifdef DEBUG_TRACES
424  std::clog << "filt(Sigma) is NaN : filt(Sigma) =" << complex.filtration(f_simplex) << std::endl;
425 #endif // DEBUG_TRACES
426  }
427  // No need to propagate further, unweighted points all have value 0
428  if (decr_dim > !Weighted)
429  propagate_alpha_filtration(complex, f_simplex);
430  }
431  }
432  old_cache_ = std::move(cache_);
433  cache_.clear();
434  }
435  // --------------------------------------------------------------------------------------------
436
437  // --------------------------------------------------------------------------------------------
438  // As Alpha value is an approximation, we have to make filtration non decreasing while increasing the dimension
440  // Remove all simplices that have a filtration value greater than max_alpha_square
441  complex.prune_above_filtration(max_alpha_square);
442  // --------------------------------------------------------------------------------------------
443  }
444  return true;
445  }
446
447  private:
448  template <typename SimplicialComplexForAlpha, typename Simplex_handle>
449  void propagate_alpha_filtration(SimplicialComplexForAlpha& complex, Simplex_handle f_simplex) {
450  // From SimplicialComplexForAlpha type required to assign filtration values.
451  using Filtration_value = typename SimplicialComplexForAlpha::Filtration_value;
453
454  // ### Foreach Tau face of Sigma
455  for (auto f_boundary : complex.boundary_simplex_range(f_simplex)) {
456 #ifdef DEBUG_TRACES
457  std::clog << " | --------------------------------------------------\n";
458  std::clog << " | Tau ";
459  for (auto vertex : complex.simplex_vertex_range(f_boundary)) {
460  std::clog << vertex << " ";
461  }
462  std::clog << "is a face of Sigma\n";
463  std::clog << " | isnan(complex.filtration(Tau)=" << std::isnan(complex.filtration(f_boundary)) << std::endl;
464 #endif // DEBUG_TRACES
465  // ### If filt(Tau) is not NaN
466  if (!std::isnan(complex.filtration(f_boundary))) {
467  // ### filt(Tau) = fmin(filt(Tau), filt(Sigma))
468  Filtration_value alpha_complex_filtration = fmin(complex.filtration(f_boundary),
469  complex.filtration(f_simplex));
470  complex.assign_filtration(f_boundary, alpha_complex_filtration);
471 #ifdef DEBUG_TRACES
472  std::clog << " | filt(Tau) = fmin(filt(Tau), filt(Sigma)) = " << complex.filtration(f_boundary) << std::endl;
473 #endif // DEBUG_TRACES
474  // ### Else
475  } else {
476  // Find which vertex of f_simplex is missing in f_boundary. We could actually write a variant of boundary_simplex_range that gives pairs (f_boundary, vertex). We rely on the fact that simplex_vertex_range is sorted.
477  auto longlist = complex.simplex_vertex_range(f_simplex);
478  auto shortlist = complex.simplex_vertex_range(f_boundary);
479  auto longiter = std::begin(longlist);
480  auto shortiter = std::begin(shortlist);
481  auto enditer = std::end(shortlist);
482  while(shortiter != enditer && *longiter == *shortiter) { ++longiter; ++shortiter; }
483  Vertex_handle extra = *longiter;
484  auto const& cache=get_cache(complex, f_boundary);
485  bool is_gab = kernel_.is_gabriel(cache, get_point_(extra));
486 #ifdef DEBUG_TRACES
487  std::clog << " | Tau is_gabriel(Sigma)=" << is_gab << " - vertexForGabriel=" << extra << std::endl;
488 #endif // DEBUG_TRACES
489  // ### If Tau is not Gabriel of Sigma
490  if (false == is_gab) {
491  // ### filt(Tau) = filt(Sigma)
492  Filtration_value alpha_complex_filtration = complex.filtration(f_simplex);
493  complex.assign_filtration(f_boundary, alpha_complex_filtration);
494 #ifdef DEBUG_TRACES
495  std::clog << " | filt(Tau) = filt(Sigma) = " << complex.filtration(f_boundary) << std::endl;
496 #endif // DEBUG_TRACES
497  }
498  }
499  }
500  }
501 };
502
503 } // namespace alpha_complex
504
505 namespace alphacomplex = alpha_complex;
506
507 } // namespace Gudhi
508
509 #endif // ALPHA_COMPLEX_H_
std::conditional_t< Weighted, CGAL::Regular_triangulation< Kernel, TDS >, CGAL::Delaunay_triangulation< Kernel, TDS > > Triangulation
A (Weighted or not) Delaunay triangulation of a set of points in .
Definition: Alpha_complex.h:114
Alpha_complex(const InputPointRange &points)
Alpha_complex constructor from a list of points.
Definition: Alpha_complex.h:183
const Point_d & get_point(std::size_t vertex) const
get_point returns the point corresponding to the vertex given as parameter.
Definition: Alpha_complex.h:222
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
void insert_simplex_and_subfaces(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in th...
Simplex_vertex_range simplex_vertex_range(Simplex_handle const &simplex)
Returns a range over vertices of a given simplex.
Simplex_key null_key()
Returns a constant dummy number that is either negative, or at least as large as the number of simpli...
typename Geom_traits::Point_d Point_d
A point, or a weighted point in Euclidean space.
Definition: Alpha_complex.h:128
Definition: SimplicialComplexForAlpha.h:14
typename A_kernel_d::Sphere Sphere
Sphere is a std::pair<Kernel::Point_d, Kernel::FT> (aka. circurmcenter and squared radius)...
Definition: Alpha_complex.h:125
const std::vector< Point_d > & get_point_cloud() const
Point cloud getter.
Definition: Points_off_io.h:158
bool create_complex(SimplicialComplexForAlpha &complex, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity(), bool exact=false, bool default_filtration_value=false)
Inserts all Delaunay triangulation into the simplicial complex. It also computes the filtration value...
Definition: Alpha_complex.h:352
unspecified Vertex_handle
Definition: SimplicialComplexForAlpha.h:25
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
bool is_valid() const
Returns if the OFF file read operation was successful or not.
Definition: Points_off_io.h:150
The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial...
Definition: SimplicialComplexForAlpha.h:21
std::conditional_t< Weighted, CGAL::Regular_triangulation_traits_adapter< Kernel >, Kernel > Geom_traits
Geometric traits class that provides the geometric types and predicates needed by the triangulations...
Definition: Alpha_complex.h:105
Alpha_complex(const InputPointRange &points, WeightRange weights)
Alpha_complex constructor from a list of points and weights.
Definition: Alpha_complex.h:200
void prune_above_filtration(Filtration_value filtration)
Alpha complex data structure.
Definition: Alpha_complex.h:102
Alpha complex kernel container.
Definition: Alpha_kernel_d.h:42
Skeleton_simplex_range skeleton_simplex_range
Returns a range over the simplices of the skeleton of the simplicial complex, for a given dimension...
Definition: SimplicialComplexForAlpha.h:70
int assign_filtration(Simplex_handle simplex, Filtration_value filtration)
unspecified Simplex_handle
Definition: SimplicialComplexForAlpha.h:23
Simplex_key key(Simplex_handle sh)
Returns the number stored for a simplex by assign_key().
Boundary_simplex_range boundary_simplex_range(Simplex_handle const &simplex)
Returns a range over boundaries of a given simplex.
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
unspecified Filtration_value
Definition: SimplicialComplexForAlpha.h:27
Alpha_complex(const std::string &off_file_name)
Alpha_complex constructor from an OFF file name.
Definition: Alpha_complex.h:162
void assign_key(Simplex_handle sh, Simplex_key n)
Store a number for a simplex, which can later be retrieved with key().
GUDHI  Version 3.4.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Dec 15 2020 16:00:41 for GUDHI by Doxygen 1.8.13
