#include <gudhi/random_point_generators.h>
#include <CGAL/Epick_d.h>
#include <CGAL/algorithm.h>
#include <CGAL/assertions.h>
#include <iostream>
#include <iterator>
#include <vector>
#include <fstream>
#include <cstdlib>
typedef CGAL::Epick_d< CGAL::Dynamic_dimension_tag > K;
typedef K::Point_d Point;
void usage(char * const progName) {
std::cerr << "Usage: " << progName << " in|on sphere|cube off_file_name points_number[integer > 0] " <<
"dimension[integer > 1] radius[double > 0.0 | default = 1.0]" << std::endl;
exit(-1);
int main(int argc, char **argv) {
if ((argc != 6) && (argc != 7)) {
std::cerr << "Error: Number of arguments (" << argc << ") is not correct" << std::endl;
usage(argv[0]);
int points_number = atoi(argv[4]);
if (points_number <= 0) {
std::cerr << "Error: " << argv[4] << " is not correct" << std::endl;
usage(argv[0]);
int dimension = atoi(argv[5]);
if (dimension <= 0) {
std::cerr << "Error: " << argv[5] << " is not correct" << std::endl;
usage(argv[0]);
double radius = 1.0;
if (argc == 7) {
radius = atof(argv[6]);
if (radius <= 0.0) {
std::cerr << "Error: " << argv[6] << " is not correct" << std::endl;
usage(argv[0]);
bool in = false;
if (strcmp(argv[1], "in") == 0) {
in = true;
} else if (strcmp(argv[1], "on") != 0) {
std::cerr << "Error: " << argv[1] << " is not correct" << std::endl;
usage(argv[0]);
enum class Data_shape { sphere, cube, curve, torus, klein, undefined};
Data_shape shape = Data_shape::undefined;
if (memcmp(argv[2], "sphere", sizeof("sphere")) == 0) {
shape = Data_shape::sphere;
} else if (memcmp(argv[2], "cube", sizeof("cube")) == 0) {
shape = Data_shape::cube;
} else if (memcmp(argv[2], "curve", sizeof("curve")) == 0) {
shape = Data_shape::curve;
} else if (memcmp(argv[2], "torus", sizeof("torus")) == 0) {
shape = Data_shape::torus;
} else if (memcmp(argv[2], "klein", sizeof("klein")) == 0) {
shape = Data_shape::klein;
} else {
std::cerr << "Error: " << argv[2] << " is not correct" << std::endl;
usage(argv[0]);
std::ofstream diagram_out(argv[3]);
if (dimension == 3) {
diagram_out << "OFF" << std::endl;
diagram_out << points_number << " 0 0" << std::endl;
} else {
diagram_out << "nOFF" << std::endl;
diagram_out << dimension << " " << points_number << " 0 0" << std::endl;
if (diagram_out.is_open()) {
std::vector<Point> points;
if (in) {
switch (shape) {
case Data_shape::sphere:
points = Gudhi::generate_points_in_ball_d<K>(points_number, dimension, radius);
break;
case Data_shape::cube:
break;
case Data_shape::curve:
std::cerr << "Sorry: in curve is not available" << std::endl;
usage(argv[0]);
break;
case Data_shape::torus:
std::cerr << "Sorry: in torus is not available" << std::endl;
usage(argv[0]);
break;
case Data_shape::klein:
std::cerr << "Sorry: in klein is not available" << std::endl;
usage(argv[0]);
break;
default:
usage(argv[0]);
break;
} else {
switch (shape) {
points = Gudhi::generate_points_on_sphere_d<K>(points_number, dimension, radius);
break;
std::cerr << "Sorry: on cube is not available" << std::endl;
usage(argv[0]);
break;
points = Gudhi::generate_points_on_moment_curve<K>(points_number, dimension, -radius/2., radius/2.);
break;
if (dimension == 3)
points = Gudhi::generate_points_on_torus_3D<K>(points_number, dimension, radius, radius/2.);
else
points = Gudhi::generate_points_on_torus_d<K>(points_number, dimension, true);
break;
switch (dimension) {
case 3:
points = Gudhi::generate_points_on_klein_bottle_3D<K>(points_number, radius, radius/2., true);
break;
case 4:
points = Gudhi::generate_points_on_klein_bottle_4D<K>(points_number, radius, radius/2., 0., true);
break;
case 5:
points = Gudhi::generate_points_on_klein_bottle_variant_5D<K>(points_number, radius, radius/2., true);
break;
default:
std::cerr << "Sorry: on klein is only available for dimension 3, 4 and 5" << std::endl;
usage(argv[0]);
break;
break;
default:
usage(argv[0]);
break;
for (auto thePoint : points) {
int i = 0;
for (; i < dimension - 1; i++) {
diagram_out << thePoint[i] << " ";
diagram_out << thePoint[i] << std::endl;
} else {
std::cerr << "Error: " << argv[3] << " cannot be opened" << std::endl;
usage(argv[0]);
return 0;
