Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Strong_witness_complex.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Siargey Kachanovich
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef STRONG_WITNESS_COMPLEX_H_
12 #define STRONG_WITNESS_COMPLEX_H_
13
14 #include <gudhi/Active_witness/Active_witness.h>
15
16 #include <utility>
17 #include <vector>
18 #include <list>
19 #include <limits>
20
21 namespace Gudhi {
22
23 namespace witness_complex {
24
39 template< class Nearest_landmark_table_ >
41  private:
42  typedef typename Nearest_landmark_table_::value_type Nearest_landmark_range;
43  typedef std::size_t Witness_id;
44  typedef std::size_t Landmark_id;
45  typedef std::pair<Landmark_id, double> Id_distance_pair;
46  typedef Active_witness<Id_distance_pair, Nearest_landmark_range> ActiveWitness;
47  typedef std::list< ActiveWitness > ActiveWitnessList;
48  typedef std::vector< Landmark_id > typeVectorVertex;
49  typedef std::vector<Nearest_landmark_range> Nearest_landmark_table_internal;
50  typedef Landmark_id Vertex_handle;
51
52  protected:
53  Nearest_landmark_table_internal nearest_landmark_table_;
54
55  public:
57  /* @name Constructor
58  */
59
61
63  }
64
73  Strong_witness_complex(Nearest_landmark_table_ const & nearest_landmark_table)
74  : nearest_landmark_table_(std::begin(nearest_landmark_table), std::end(nearest_landmark_table)) {
75  }
76
86  template < typename SimplicialComplexForWitness >
88  double max_alpha_square,
89  Landmark_id limit_dimension = std::numeric_limits<Landmark_id>::max()) const {
90  Landmark_id complex_dim = 0;
91  if (complex.num_vertices() > 0) {
92  std::cerr << "Strong witness complex cannot create complex - complex is not empty.\n";
93  return false;
94  }
95  if (max_alpha_square < 0) {
96  std::cerr << "Strong witness complex cannot create complex - squared relaxation parameter must be "
97  << "non-negative.\n";
98  return false;
99  }
100  for (auto w : nearest_landmark_table_) {
101  ActiveWitness aw(w);
102  typeVectorVertex simplex;
103  typename ActiveWitness::iterator aw_it = aw.begin();
104  float lim_dist2 = aw.begin()->second + max_alpha_square;
105  while ((Landmark_id)simplex.size() <= limit_dimension && aw_it != aw.end() && aw_it->second < lim_dist2) {
106  simplex.push_back(aw_it->first);
107  complex.insert_simplex_and_subfaces(simplex, aw_it->second - aw.begin()->second);
108  aw_it++;
109  }
110  // continue inserting limD-faces of the following simplices
111  typeVectorVertex& vertices = simplex; // 'simplex' now will be called vertices
112  while (aw_it != aw.end() && aw_it->second < lim_dist2) {
113  typeVectorVertex facet = {};
114  add_all_faces_of_dimension(limit_dimension, vertices, vertices.begin(), aw_it,
115  aw_it->second - aw.begin()->second, facet, complex);
116  vertices.push_back(aw_it->first);
117  aw_it++;
118  }
119  if ((Landmark_id)simplex.size() - 1 > complex_dim)
120  complex_dim = simplex.size() - 1;
121  }
122  return true;
123  }
124
126
127  private:
128  /* \brief Adds recursively all the faces of a certain dimension dim-1 witnessed by the same witness.
129  * Iterator is needed to know until how far we can take landmarks to form simplexes.
130  * simplex is the prefix of the simplexes to insert.
131  * The landmark pointed by aw_it is added to all formed simplices.
132  */
133  template < typename SimplicialComplexForWitness >
134  void add_all_faces_of_dimension(Landmark_id dim,
135  typeVectorVertex& vertices,
136  typename typeVectorVertex::iterator curr_it,
137  typename ActiveWitness::iterator aw_it,
138  double filtration_value,
139  typeVectorVertex& simplex,
140  SimplicialComplexForWitness& sc) const {
141  if (dim > 0) {
142  while (curr_it != vertices.end()) {
143  simplex.push_back(*curr_it);
144  ++curr_it;
145  add_all_faces_of_dimension(dim-1,
146  vertices,
147  curr_it,
148  aw_it,
149  filtration_value,
150  simplex,
151  sc);
152  simplex.pop_back();
153  add_all_faces_of_dimension(dim,
154  vertices,
155  curr_it,
156  aw_it,
157  filtration_value,
158  simplex,
159  sc);
160  }
161  } else if (dim == 0) {
162  simplex.push_back(aw_it->first);
163  sc.insert_simplex_and_subfaces(simplex, filtration_value);
164  simplex.pop_back();
165  }
166  }
167 };
168
169 } // namespace witness_complex
170
171 } // namespace Gudhi
172
173 #endif // STRONG_WITNESS_COMPLEX_H_
The concept SimplicialComplexForWitness describes the requirements for a type to implement a simplici...
Definition: SimplicialComplexForWitness.h:22
bool create_complex(SimplicialComplexForWitness &complex, double max_alpha_square, Landmark_id limit_dimension=std::numeric_limits< Landmark_id >::max()) const
Outputs the strong witness complex of relaxation &#39;max_alpha_square&#39; in a simplicial complex data stru...
Definition: Strong_witness_complex.h:87
Definition: SimplicialComplexForAlpha.h:14
Strong_witness_complex(Nearest_landmark_table_ const &nearest_landmark_table)
Initializes member variables before constructing simplicial complex.
Definition: Strong_witness_complex.h:73
Insertion_result_type insert_simplex_and_subfaces(Input_vertex_range const &vertex_range, Filtration_value filtration)
Inserts a simplex and all its faces with vertices from a given range &#39;vertex_range&#39; in the simplicial...
Constructs strong witness complex for a given table of nearest landmarks with respect to witnesses...
Definition: Strong_witness_complex.h:40
GUDHI  Version 3.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Aug 11 2020 11:09:13 for GUDHI by Doxygen 1.8.13
