11 #ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_OFF_IO_H_    12 #define SKELETON_BLOCKER_SKELETON_BLOCKER_OFF_IO_H_    14 #include <gudhi/Off_reader.h>    22 namespace skeleton_blocker {
    27 template<
typename Complex>
    30   typedef typename Complex::Vertex_handle Vertex_handle;
    31   typedef typename Complex::Point Point;
    33   const bool load_only_points_;
    38       load_only_points_(load_only_points) { }
    40   void init(
int dim,
int num_vertices,
int num_faces,
int num_edges) {
    45   void point(
const std::vector<double>& point) {
    46     complex_.add_vertex(Point(point.begin(), point.end()));
    49   void maximal_face(
const std::vector<int>& face) {
    50     if (!load_only_points_) {
    51       for (
size_t i = 0; i < face.size(); ++i)
    52         for (
size_t j = i + 1; j < face.size(); ++j) {
    53           complex_.add_edge_without_blockers(Vertex_handle(face[i]), Vertex_handle(face[j]));
    64 template<
typename Complex>
    67   typedef typename Complex::Vertex_handle Vertex_handle;
    68   typedef typename Complex::Simplex Simplex;
    69   typedef typename Complex::Point Point;
    71   const bool load_only_points_;
    72   std::vector<Point> points_;
    73   std::vector<Simplex> maximal_faces_;
    78       load_only_points_(load_only_points) { }
    80   void init(
int dim,
int num_vertices,
int num_faces,
int num_edges) {
    81     maximal_faces_.reserve(num_faces);
    82     points_.reserve(num_vertices);
    85   void point(
    86     points_.emplace_back(point.begin(), point.end());
    89   void maximal_face(
    90     if (!load_only_points_) {
    93         s.add_vertex(Vertex_handle(x));
    94       maximal_faces_.emplace_back(s);
    99     complex_ = make_complex_from_top_faces<Complex>(maximal_faces_.begin(), maximal_faces_.end(),
   100                                                     points_.begin(), points_.end());
   107 template<
typename Complex>
   116                               bool read_only_points =
false,
bool is_flag =
false) : valid_(false) {
   117     std::ifstream stream(name_file);
   118     if (stream.is_open()) {
   119       if (is_flag || read_only_points) {
   122         valid_ = off_reader.
read(off_visitor);
   126         valid_ = off_reader.
read(off_visitor);
   142 template<
typename Complex>
   143 class Skeleton_blocker_off_writer {
   150   Skeleton_blocker_off_writer(
const std::string & name_file,
const Complex& save_complex) {
   153     std::ofstream stream(name_file);
   154     if (stream.is_open()) {
   156       size_t num_triangles = std::distance(save_complex.triangle_range().begin(), save_complex.triangle_range().end());
   157       stream << save_complex.num_vertices() <<
" " << num_triangles <<
" 0 \n";
   161       std::map<Vertex_handle, size_t> vertex_num;
   162       size_t current_vertex = 0;
   164       for (
auto v : save_complex.vertex_range()) {
   165         vertex_num[v] = current_vertex++;
   166         const auto& pt(save_complex.point(v));
   172       for (
const auto & t : save_complex.triangle_range()) {
   175           stream << vertex_num[x] <<
   180       std::cerr <<
"could not open file " << name_file << std::endl;
   187 namespace skbl = skeleton_blocker;
   191 #endif  // SKELETON_BLOCKER_SKELETON_BLOCKER_OFF_IO_H_ bool read(OffVisitor &off_visitor)
Read an OFF file and calls the following methods :
Definition: Off_reader.h:51
Definition: SimplicialComplexForAlpha.h:14
Skeleton_blocker_off_reader(const std::string &name_file, Complex &read_complex, bool read_only_points=false, bool is_flag=false)
Definition: Skeleton_blocker_off_io.h:115
OFF file reader top class visitor.
Definition: Off_reader.h:29
Off reader visitor that can be passed to Off_reader to read a Skeleton_blocker_complex.
Definition: Skeleton_blocker_off_io.h:28
bool is_valid() const
Definition: Skeleton_blocker_off_io.h:134
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
Definition: Skeleton_blocker_off_io.h:65
Class that allows to load a Skeleton_blocker_complex from an off file.
Definition: Skeleton_blocker_off_io.h:108
