Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Persistence_representations/persistence_intervals/compute_number_of_dominant_intervals.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Persistence_intervals.h>
#include <iostream>
#include <limits>
#include <vector>
#include <utility>
int main(int argc, char** argv) {
std::clog << "This program compute the dominant intervals. A number of intervals to be displayed is a parameter of "
"this program. \n";
if (argc != 4) {
std::clog << "To run this program, please provide the name of a file with persistence diagram, dimension of "
"intervals that should be taken into account (if your file contains only persistence pairs in a "
"single dimension, set it up to -1) and number of dominant intervals you would like to get \n";
return 1;
int dim = atoi(argv[2]);
unsigned dimension = std::numeric_limits<unsigned>::max();
if (dim >= 0) {
dimension = (unsigned)dim;
Persistence_intervals p(argv[1], dimension);
std::vector<std::pair<double, double> > dominant_intervals = p.dominant_intervals(atoi(argv[3]));
std::clog << "Here are the dominant intervals : " << std::endl;
for (size_t i = 0; i != dominant_intervals.size(); ++i) {
std::clog << " " << dominant_intervals[i].first << "," << dominant_intervals[i].second << " " << std::endl;
return 0;
GUDHI  Version 3.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Aug 11 2020 11:09:13 for GUDHI by Doxygen 1.8.13
