14 #ifndef PERSISTENCE_HEAT_MAPS_H_ 15 #define PERSISTENCE_HEAT_MAPS_H_ 18 #include <gudhi/read_persistence_from_file.h> 19 #include <gudhi/common_persistence_representations.h> 33 namespace Persistence_representations {
39 std::vector<std::vector<double> > create_Gaussian_filter(
size_t pixel_radius,
double sigma) {
45 double sigma_sqr = sigma * sigma;
51 std::vector<std::vector<double> > kernel(2 * pixel_radius + 1);
52 for (
size_t i = 0; i != kernel.size(); ++i) {
53 std::vector<double> v(2 * pixel_radius + 1, 0);
58 std::clog <<
"Kernel initialize \n";
59 std::clog <<
"pixel_radius : " << pixel_radius << std::endl;
60 std::clog <<
"kernel.size() : " << kernel.size() << std::endl;
64 for (
int x = -pixel_radius; x <= static_cast<int>(pixel_radius); x++) {
65 for (
int y = -pixel_radius; y <= static_cast<int>(pixel_radius); y++) {
66 double real_x = 2 * sigma * x / pixel_radius;
67 double real_y = 2 * sigma * y / pixel_radius;
68 r = std::sqrt(real_x * real_x + real_y * real_y);
69 kernel[x + pixel_radius][y + pixel_radius] = (exp(-(r * r) / sigma_sqr)) / (3.141592 * sigma_sqr);
70 sum += kernel[x + pixel_radius][y + pixel_radius];
75 for (
76 for (
size_t j = 0; j != kernel[i].size(); ++j) {
82 std::clog <<
"Here is the kernel : \n";
83 for (
84 for (
85 std::clog << kernel[i][j] <<
87 std::clog << std::endl;
108 double operator()(
const std::pair<double, double>& point_in_diagram) {
return 1; }
118 double operator()(
120 return std::sqrt(std::pow((point_in_diagram.first - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2) +
121 std::pow((point_in_diagram.second - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2));
132 double operator()(
133 return std::pow((point_in_diagram.first - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2) +
134 std::pow((point_in_diagram.second - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2);
145 double operator()(
146 return atan(point_in_diagram.second - point_in_diagram.first);
160 double operator()(
161 return (point_in_diagram.second - point_in_diagram.first) / this->length_of_maximal_interval;
165 double length_of_maximal_interval;
177 template <
typename Scalling_of_kernels = constant_scaling_function>
185 Scalling_of_kernels f;
187 this->erase_below_diagonal =
false;
188 this->min_ = this->max_ = 0;
189 this->set_up_parameters_for_basic_classes();
206 std::vector<std::vector<double> > filter = create_Gaussian_filter(5, 1),
207 bool erase_below_diagonal =
false,
size_t number_of_pixels = 1000,
208 double min_ = std::numeric_limits<double>::max(),
209 double max_ = std::numeric_limits<double>::max());
232 Persistence_heat_maps(
const char* filename, std::vector<std::vector<double> > filter = create_Gaussian_filter(5, 1),
233 bool erase_below_diagonal =
false,
234 double min_ = std::numeric_limits<double>::max(),
235 double max_ = std::numeric_limits<double>::max(),
236 unsigned dimension = std::numeric_limits<unsigned>::max());
243 const std::function<
double(std::pair<double, double>, std::pair<double, double>)>& kernel,
244 size_t number_of_x_pixels,
size_t number_of_y_pixels,
double min_x = 0,
double max_x = 1,
245 double min_y = 0,
double max_y = 1);
251 const std::function<
double(std::pair<double, double>, std::pair<double, double>)>& kernel);
258 void compute_mean(
const std::vector<Persistence_heat_maps*>& maps);
265 void compute_median(
270 void compute_percentage_of_active(
const std::vector<Persistence_heat_maps*>& maps,
size_t cutoff = 1);
278 void print_to_file(
const char* filename)
const;
284 void load_from_file(
const char* filename);
291 if (this->heat_map.size() != second.heat_map.size()) {
293 std::clog <<
"this->heat_map.size() : " << this->heat_map.size()
294 <<
" \n second.heat_map.size() : " << second.heat_map.size() << std::endl;
297 if (this->min_ != second.min_) {
298 if (dbg) std::clog <<
"this->min_ : " << this->min_ <<
", second.min_ : " << second.min_ << std::endl;
301 if (this->max_ != second.max_) {
302 if (dbg) std::clog <<
"this->max_ : " << this->max_ <<
", second.max_ : " << second.max_ << std::endl;
312 inline double get_min()
const {
return this->min_; }
317 inline double get_max()
const {
return this->max_; }
324 if (!this->check_if_the_same(rhs)) {
325 if (dbg) std::clog <<
"The domains are not the same \n";
328 for (
size_t i = 0; i != this->heat_map.size(); ++i) {
329 for (
size_t j = 0; j != this->heat_map[i].size(); ++j) {
330 if (!almost_equal(this->heat_map[i][j], rhs.heat_map[i][j])) {
332 std::clog <<
"this->heat_map[" << i <<
"][" << j <<
"] = " << this->heat_map[i][j] << std::endl;
333 std::clog <<
"rhs.heat_map[" << i <<
"][" << j <<
"] = " << rhs.heat_map[i][j] << std::endl;
350 void plot(
const;
352 template <
typename Operation_type>
355 Operation_type operation) {
358 std::cerr <<
"Sizes of the heat maps are not compatible. The program will now terminate \n";
359 throw "Sizes of the heat maps are not compatible. The program will now terminate \n";
362 result.min_ = first.min_;
363 result.max_ = first.max_;
364 result.heat_map.reserve(first.heat_map.size());
365 for (
size_t i = 0; i != first.heat_map.size(); ++i) {
366 std::vector<double> v;
367 v.reserve(first.heat_map[i].size());
368 for (
size_t j = 0; j != first.heat_map[i].size(); ++j) {
369 v.push_back(operation(first.heat_map[i][j], second.heat_map[i][j]));
371 result.heat_map.push_back(v);
382 result.min_ = this->min_;
383 result.max_ = this->max_;
384 result.heat_map.reserve(this->heat_map.size());
385 for (
386 std::vector<double> v;
387 v.reserve(this->heat_map[i].size());
388 for (
389 v.push_back(this->heat_map[i][j] * scalar);
391 result.heat_map.push_back(v);
400 return operation_on_pair_of_heat_maps(first, second, std::plus<double>());
406 return operation_on_pair_of_heat_maps(first, second, std::minus<double>());
449 if (x == 0)
throw(
"In operator /=, division by 0. Program terminated.");
450 *
this = *
this * (1 / x);
460 std::vector<double> vectorize(
int number_of_function)
const;
474 double project_to_R(
const;
493 void compute_average(
const std::vector<Persistence_heat_maps*>& to_average);
507 std::pair<double, double>
get_x_range()
const {
return std::make_pair(this->min_, this->max_); }
512 std::pair<double, double>
get_y_range()
const {
return this->get_x_range(); }
516 std::vector<std::vector<double> > check_and_initialize_maps(
517 size_t number_of_functions_for_vectorization;
518 size_t number_of_functions_for_projections_to_reals;
519 void construct(
const std::vector<std::pair<double, double> >& intervals_,
520 std::vector<std::vector<double> > filter = create_Gaussian_filter(5, 1),
521 bool erase_below_diagonal =
false,
522 double min_ = std::numeric_limits<double>::max(),
524 void set_up_parameters_for_basic_classes() {
525 this->number_of_functions_for_vectorization = 1;
526 this->number_of_functions_for_projections_to_reals = 1;
530 bool discrete =
true;
531 std::function<double(std::pair<double, double>, std::pair<double, double>)> kernel;
532 std::vector<std::pair<double, double> > interval;
533 std::vector<double> weights;
536 Scalling_of_kernels f;
537 bool erase_below_diagonal;
540 std::vector<std::vector<double> > heat_map;
543 template <
typename Scalling_of_kernels>
545 const std::vector<std::pair<double, double> >& interval,
546 const std::function<
547 size_t number_of_x_pixels,
double min_x,
double max_x,
double min_y,
double max_y) {
548 this->discrete =
true;
551 this->heat_map.resize(number_of_y_pixels);
552 double step_x = (max_x - min_x) / (number_of_x_pixels - 1);
553 double step_y = (max_y - min_y) / (number_of_y_pixels - 1);
555 int num_pts = interval.size();
556 for (
size_t i = 0; i < number_of_y_pixels; i++) {
557 double y = min_y + i * step_y;
558 this->heat_map[i].reserve(number_of_x_pixels);
559 for (
size_t j = 0; j < number_of_x_pixels; j++) {
560 double x = min_x + j * step_x;
561 std::pair<double, double> grid_point(x, y);
562 double pixel_value = 0;
563 for (
int k = 0; k < num_pts; k++) pixel_value += this->f(interval[k]) * kernel(interval[k], grid_point);
564 this->heat_map[i].push_back(pixel_value);
567 this->set_up_parameters_for_basic_classes();
570 template <
572 const std::vector<std::pair<double, double> >& interval,
573 const std::function<
double(std::pair<double, double>, std::pair<double, double>)>& kernel) {
574 this->discrete =
false;
575 this->interval = interval;
576 this->kernel = kernel;
577 int num_pts = this->interval.size();
578 for (
int i = 0; i < num_pts; i++) this->weights.push_back(this->f(this->interval[i]));
579 this->set_up_parameters_for_basic_classes();
583 template <
585 std::vector<std::vector<double> > filter,
586 bool erase_below_diagonal,
size_t number_of_pixels,
587 double min_,
double max_) {
589 if (dbg) std::clog <<
"Entering construct procedure \n";
590 Scalling_of_kernels f;
593 if (dbg) std::clog <<
"min and max passed to construct() procedure: " << min_ <<
" " << max_ << std::endl;
596 if (dbg) std::clog <<
"min and max parameters will be determined based on intervals \n";
598 min_ = std::numeric_limits<int>::max();
599 max_ = -std::numeric_limits<int>::max();
601 for (
size_t i = 0; i != intervals_.size(); ++i) {
602 if (intervals_[i].first < min_) min_ = intervals_[i].first;
603 if (intervals_[i].second > max_) max_ = intervals_[i].second;
609 min_ -= fabs(max_ - min_) / 100;
610 max_ += fabs(max_ - min_) / 100;
614 std::clog <<
"min_ : " << min_ << std::endl;
615 std::clog <<
"max_ : " << max_ << std::endl;
616 std::clog <<
"number_of_pixels : " << number_of_pixels << std::endl;
624 std::vector<std::vector<double> > heat_map_;
625 for (
size_t i = 0; i != number_of_pixels; ++i) {
626 std::vector<double> v(number_of_pixels, 0);
627 heat_map_.push_back(v);
629 this->heat_map = heat_map_;
631 if (dbg) std::clog <<
"Done creating of the heat map, now we will fill in the structure \n";
633 for (
size_t pt_nr = 0; pt_nr != intervals_.size(); ++pt_nr) {
636 static_cast<int>((intervals_[pt_nr].first - this->min_) / (this->max_ - this->min_) * number_of_pixels);
638 static_cast<int>((intervals_[pt_nr].second - this->min_) / (this->max_ - this->min_) * number_of_pixels);
641 std::clog <<
"point : " << intervals_[pt_nr].first <<
" , " << intervals_[pt_nr].second << std::endl;
642 std::clog <<
"x_grid : " << x_grid << std::endl;
643 std::clog <<
"y_grid : " << y_grid << std::endl;
648 x_grid -= filter.size() / 2;
649 y_grid -= filter.size() / 2;
653 std::clog <<
"After shift : \n";
654 std::clog <<
655 std::clog <<
658 double scaling_value = this->f(intervals_[pt_nr]);
660 for (
size_t i = 0; i != filter.size(); ++i) {
661 for (
size_t j = 0; j != filter.size(); ++j) {
663 if (((x_grid + i) >= 0) && (x_grid + i < this->heat_map.size()) && ((y_grid + j) >= 0) &&
664 (y_grid + j < this->heat_map.size())) {
666 std::clog << y_grid + j <<
" " << x_grid + i << std::endl;
668 this->heat_map[y_grid + j][x_grid + i] += scaling_value * filter[i][j];
670 std::clog <<
"Position : (" << x_grid + i <<
"," << y_grid + j
671 <<
") got increased by the value : " << filter[i][j] << std::endl;
679 if (erase_below_diagonal) {
680 for (
681 for (
size_t j = i; j != this->heat_map.size(); ++j) {
682 this->heat_map[i][j] = 0;
688 template <
690 const std::vector<std::pair<double, double> >& interval, std::vector<std::vector<double> > filter,
691 bool erase_below_diagonal,
double min_,
double max_) {
692 this->construct(interval, filter, erase_below_diagonal, number_of_pixels, min_, max_);
693 this->set_up_parameters_for_basic_classes();
696 template <
698 std::vector<std::vector<double> > filter,
699 bool erase_below_diagonal,
700 double min_,
double max_,
unsigned dimension) {
701 std::vector<std::pair<double, double> > intervals_;
702 if (dimension == std::numeric_limits<unsigned>::max()) {
703 intervals_ = read_persistence_intervals_in_one_dimension_from_file(filename);
705 intervals_ = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
707 this->construct(intervals_, filter, erase_below_diagonal, number_of_pixels, min_, max_);
708 this->set_up_parameters_for_basic_classes();
711 template <
713 const std::vector<Persistence_heat_maps*>& maps) {
715 for (
size_t i = 0; i != maps.size(); ++i) {
716 if (maps[i]->heat_map.size() != maps[0]->heat_map.size()) {
717 std::cerr <<
"Sizes of Persistence_heat_maps are not compatible. The program will terminate now \n";
718 throw "Sizes of Persistence_heat_maps are not compatible. The program will terminate now \n";
720 if (maps[i]->heat_map[0].size() != maps[0]->heat_map[0].size()) {
721 std::cerr <<
722 throw "Sizes of Persistence_heat_maps are not compatible. The program will terminate now \n";
725 std::vector<std::vector<double> > heat_maps(maps[0]->heat_map.size());
726 for (
size_t i = 0; i != maps[0]->heat_map.size(); ++i) {
727 std::vector<double> v(maps[0]->heat_map[0].size(), 0);
733 template <
735 std::vector<std::vector<double> > heat_maps = this->check_and_initialize_maps(maps);
737 std::vector<double> to_compute_median(maps.size());
738 for (
size_t i = 0; i != heat_maps.size(); ++i) {
739 for (
size_t j = 0; j != heat_maps[i].size(); ++j) {
740 for (
size_t map_no = 0; map_no != maps.size(); ++map_no) {
741 to_compute_median[map_no] = maps[map_no]->heat_map[i][j];
743 std::nth_element(to_compute_median.begin(), to_compute_median.begin() + to_compute_median.size() / 2,
744 to_compute_median.end());
745 heat_maps[i][j] = to_compute_median[to_compute_median.size() / 2];
748 this->heat_map = heat_maps;
749 this->min_ = maps[0]->min_;
750 this->max_ = maps[0]->max_;
753 template <
755 std::vector<std::vector<double> > heat_maps = this->check_and_initialize_maps(maps);
756 for (
757 for (
759 for (
760 mean += maps[map_no]->heat_map[i][j];
762 heat_maps[i][j] = mean /
static_cast<double>(maps.size());
765 this->heat_map = heat_maps;
766 this->min_ = maps[0]->min_;
767 this->max_ = maps[0]->max_;
770 template <
772 const std::vector<Persistence_heat_maps*>& maps,
size_t cutoff) {
773 std::vector<std::vector<double> > heat_maps = this->check_and_initialize_maps(maps);
775 for (
776 for (
777 size_t number_of_active_levels = 0;
778 for (
779 if (maps[map_no]->heat_map[i][j]) number_of_active_levels++;
781 if (number_of_active_levels > cutoff) {
782 heat_maps[i][j] = number_of_active_levels;
788 this->heat_map = heat_maps;
789 this->min_ = maps[0]->min_;
790 this->max_ = maps[0]->max_;
793 template <
796 std::stringstream gnuplot_script;
797 gnuplot_script << filename <<
"_GnuplotScript";
799 out.open(gnuplot_script.str().c_str());
800 out <<
"plot '-' matrix with image" << std::endl;
801 for (
802 for (
803 out << this->heat_map[i][j] <<
808 std::clog <<
"To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'" 809 << gnuplot_script.str().c_str() <<
"\'\"" << std::endl;
812 template <
818 out << this->min_ <<
" " << this->max_ << std::endl;
819 for (
820 for (
821 out << this->heat_map[i][j] <<
828 template <
837 std::cerr <<
"The file : " << filename <<
" do not exist. The program will now terminate \n";
838 throw "The persistence landscape file do not exist. The program will now terminate \n";
843 in >> this->min_ >> this->max_;
845 std::clog <<
"Reading the following values of min and max : " << this->min_ <<
" , " << this->max_ << std::endl;
849 std::getline(in, temp);
851 std::getline(in, temp);
852 std::stringstream lineSS;
855 std::vector<double> line_of_heat_map;
856 while (lineSS.good()) {
860 line_of_heat_map.push_back(point);
862 std::clog << point <<
866 std::clog << std::endl;
870 if (in.good()) this->heat_map.push_back(line_of_heat_map);
873 if (dbg) std::clog <<
"Done \n";
877 template <
879 std::vector<double> result;
881 std::cerr <<
"No vectorize method in case of infinite dimensional vectorization" << std::endl;
886 size_t size_of_result = 0;
887 for (
888 size_of_result += this->heat_map[i].size();
891 result.reserve(size_of_result);
893 for (
894 for (
895 result.push_back(this->heat_map[i][j]);
902 template <
904 if (this->discrete) {
906 if (!this->check_if_the_same(second)) {
907 std::cerr <<
"The persistence images are of non compatible sizes. We cannot therefore compute distance between " 908 "them. The program will now terminate";
909 throw "The persistence images are of non compatible sizes. The program will now terminate";
916 if (power < std::numeric_limits<double>::max()) {
917 for (
918 for (
919 distance += std::pow(std::fabs(this->heat_map[i][j] - second.heat_map[i][j]), power);
924 for (
925 for (
926 if (distance < std::fabs(this->heat_map[i][j] - second.heat_map[i][j])) {
927 distance = std::fabs(this->heat_map[i][j] - second.heat_map[i][j]);
935 2 * this->compute_scalar_product(second));
939 template <
942 for (
943 for (
944 result += this->heat_map[i][j];
950 template <
952 const std::vector<Persistence_heat_maps*>& to_average) {
953 this->compute_mean(to_average);
956 template <
960 if (!this->check_if_the_same(second)) {
961 std::cerr <<
"The persistence images are of non compatible sizes. We cannot therefore compute distance between " 962 "them. The program will now terminate";
963 throw "The persistence images are of non compatible sizes. The program will now terminate";
968 double scalar_prod = 0;
969 for (
970 for (
971 scalar_prod += this->heat_map[i][j] * second.heat_map[i][j];
976 int num_pts1 = this->interval.size();
977 int num_pts2 = second.interval.size();
978 double kernel_val = 0;
979 for (
int i = 0; i < num_pts1; i++) {
980 std::pair<double, double> pi = this->interval[i];
981 for (
int j = 0; j < num_pts2; j++) {
982 std::pair<double, double> pj = second.interval[j];
983 kernel_val += this->weights[i] * second.weights[j] * this->kernel(pi, pj);
993 #endif // PERSISTENCE_HEAT_MAPS_H_ size_t number_of_vectorize_functions() const
Definition: Persistence_heat_maps.h:465
void compute_percentage_of_active(const std::vector< Persistence_heat_maps *> &maps, size_t cutoff=1)
Definition: Persistence_heat_maps.h:771
size_t number_of_projections_to_R() const
Definition: Persistence_heat_maps.h:479
bool check_if_the_same(const Persistence_heat_maps &second) const
Definition: Persistence_heat_maps.h:289
double get_min() const
Definition: Persistence_heat_maps.h:312
std::pair< double, double > get_x_range() const
Definition: Persistence_heat_maps.h:507
void compute_average(const std::vector< Persistence_heat_maps *> &to_average)
Definition: Persistence_heat_maps.h:951
void load_from_file(const char *filename)
Definition: Persistence_heat_maps.h:829
bool operator==(const Persistence_heat_maps &rhs) const
Definition: Persistence_heat_maps.h:322
Definition: Persistence_heat_maps.h:143
A class implementing persistence heat maps.
Definition: Persistence_heat_maps.h:178
Persistence_heat_maps multiply_by_scalar(double scalar) const
Definition: Persistence_heat_maps.h:380
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_heat_maps.h:878
Persistence_heat_maps operator/=(double x)
Definition: Persistence_heat_maps.h:448
double project_to_R(int number_of_function) const
Definition: Persistence_heat_maps.h:940
std::pair< double, double > get_y_range() const
Definition: Persistence_heat_maps.h:512
Persistence_heat_maps operator*=(double x)
Definition: Persistence_heat_maps.h:441
Persistence_heat_maps operator*(double scalar)
Definition: Persistence_heat_maps.h:423
friend Persistence_heat_maps operator-(const Persistence_heat_maps &first, const Persistence_heat_maps &second)
Definition: Persistence_heat_maps.h:405
Definition: SimplicialComplexForAlpha.h:14
void compute_median(const std::vector< Persistence_heat_maps *> &maps)
Definition: Persistence_heat_maps.h:734
void plot(const char *filename) const
Definition: Persistence_heat_maps.h:794
friend Persistence_heat_maps operator*(const Persistence_heat_maps &A, double scalar)
Definition: Persistence_heat_maps.h:417
void print_to_file(const char *filename) const
Definition: Persistence_heat_maps.h:813
double compute_scalar_product(const Persistence_heat_maps &second_) const
Definition: Persistence_heat_maps.h:957
Definition: Persistence_heat_maps.h:130
friend Persistence_heat_maps operator+(const Persistence_heat_maps &first, const Persistence_heat_maps &second)
Definition: Persistence_heat_maps.h:399
double distance(const Persistence_heat_maps &second_, double power=1) const
Definition: Persistence_heat_maps.h:903
friend Persistence_heat_maps operator*(double scalar, const Persistence_heat_maps &A)
Definition: Persistence_heat_maps.h:411
Definition: Persistence_heat_maps.h:116
Persistence_heat_maps()
Definition: Persistence_heat_maps.h:184
void compute_mean(const std::vector< Persistence_heat_maps *> &maps)
Definition: Persistence_heat_maps.h:754
Definition: Persistence_heat_maps.h:157
Definition: Persistence_heat_maps.h:106
Persistence_heat_maps operator+=(const Persistence_heat_maps &rhs)
Definition: Persistence_heat_maps.h:427
bool operator!=(const Persistence_heat_maps &rhs) const
Definition: Persistence_heat_maps.h:345
double get_max() const
Definition: Persistence_heat_maps.h:317
Persistence_heat_maps operator-=(const Persistence_heat_maps &rhs)
Definition: Persistence_heat_maps.h:434
