Skeleton_blockers_edges_iterators.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): David Salinas
4  *
5  * Copyright (C) 2014 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_EDGES_ITERATORS_H_
12 #define SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_EDGES_ITERATORS_H_
13
14 #include <boost/iterator/iterator_facade.hpp>
15 #include <boost/graph/adjacency_list.hpp>
16
17 #include <utility> // for pair<>
18
19 namespace Gudhi {
20
21 namespace skeleton_blocker {
22
23 template<typename SkeletonBlockerComplex>
24 class Edge_around_vertex_iterator : public boost::iterator_facade <Edge_around_vertex_iterator<SkeletonBlockerComplex>
25 , typename SkeletonBlockerComplex::Edge_handle const, boost::forward_traversal_tag
26 , typename SkeletonBlockerComplex::Edge_handle const> {
27  friend class boost::iterator_core_access;
28
29  typedef SkeletonBlockerComplex Complex;
30  typedef typename Complex::boost_adjacency_iterator boost_adjacency_iterator;
31  typedef typename Complex::Vertex_handle Vertex_handle;
32  typedef typename Complex::Edge_handle Edge_handle;
33
34  private:
35  const Complex* complex;
36  Vertex_handle v;
37
38  boost_adjacency_iterator current_;
39  boost_adjacency_iterator end_;
40
41  public:
42  Edge_around_vertex_iterator() : complex(NULL) { }
43
44  Edge_around_vertex_iterator(const Complex* complex_, Vertex_handle v_) :
45  complex(complex_),
46  v(v_) {
47  tie(current_, end_) = adjacent_vertices(v.vertex, complex->skeleton);
48  }
49
53  Edge_around_vertex_iterator(const Complex* complex_, Vertex_handle v_, int end) :
54  complex(complex_),
55  v(v_) {
56  tie(current_, end_) = adjacent_vertices(v.vertex, complex->skeleton);
57  set_end();
58  }
59
60  bool equal(const Edge_around_vertex_iterator& other) const {
61  return (complex == other.complex) && (v == other.v) && (current_ == other.current_) && (end_ == other.end_);
62  }
63
64  void increment() {
65  if (current_ != end_)
66  ++current_;
67  }
68
69  Edge_handle dereference() const {
70  return *(*complex)[std::make_pair(v, static_cast<Vertex_handle> (*current_))];
71  }
72
73  private:
74  // remove this ugly hack
75  void set_end() {
76  current_ = end_;
77  }
78 };
79
84 template<typename SkeletonBlockerComplex>
85 class Edge_iterator : public boost::iterator_facade <Edge_iterator<SkeletonBlockerComplex>
86 , typename SkeletonBlockerComplex::Edge_handle const
87 , boost::forward_traversal_tag
88 , typename SkeletonBlockerComplex::Edge_handle const> {
89  friend class boost::iterator_core_access;
90
91  public:
92  typedef SkeletonBlockerComplex Complex;
93  typedef typename Complex::boost_edge_iterator boost_edge_iterator;
94  typedef typename Complex::Edge_handle Edge_handle;
95
96  const Complex* complex;
97  std::pair<boost_edge_iterator, boost_edge_iterator> edge_iterator;
98
99  Edge_iterator() : complex(NULL) { }
100
101  Edge_iterator(const SkeletonBlockerComplex* complex_) :
102  complex(complex_),
103  edge_iterator(boost::edges(complex_->skeleton)) { }
104
108  Edge_iterator(const SkeletonBlockerComplex* complex_, int end) :
109  complex(complex_),
110  edge_iterator(boost::edges(complex_->skeleton)) {
111  edge_iterator.first = edge_iterator.second;
112  }
113
114  bool equal(const Edge_iterator& other) const {
115  return (complex == other.complex) && (edge_iterator == other.edge_iterator);
116  }
117
118  void increment() {
119  if (edge_iterator.first != edge_iterator.second) {
120  ++(edge_iterator.first);
121  }
122  }
123
124  Edge_handle dereference() const {
125  return (*(edge_iterator.first));
126  }
127 };
128
129 } // namespace skeleton_blocker
130
131 namespace skbl = skeleton_blocker;
132
133 } // namespace Gudhi
134
135 #endif // SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_EDGES_ITERATORS_H_
Definition: SimplicialComplexForAlpha.h:14
Iterator on the edges of a simplicial complex.
Definition: Skeleton_blockers_edges_iterators.h:85
Edge_iterator(const SkeletonBlockerComplex *complex_, int end)
Definition: Skeleton_blockers_edges_iterators.h:108
GUDHI  Version 3.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Wed May 20 2020 07:53:46 for GUDHI by Doxygen 1.8.13
