11 #ifndef SKELETON_BLOCKER_SIMPLIFIABLE_COMPLEX_H_    12 #define SKELETON_BLOCKER_SIMPLIFIABLE_COMPLEX_H_    14 #include <gudhi/Skeleton_blocker/Skeleton_blocker_sub_complex.h>    22 namespace skeleton_blocker {
    32 template<
typename SkeletonBlockerDS>
    34   assert(this->contains_blocker(*sigma));
    36   build_link_of_blocker(*
this, *sigma, link_blocker_sigma);
    44 template<
    46   std::list<Vertex_handle> vertex_to_check;
    47   for (
auto v : this->vertex_range())
    48     vertex_to_check.push_front(v);
    50   while (!vertex_to_check.empty()) {
    52     vertex_to_check.pop_front();
    54     bool blocker_popable_found =
true;
    55     while (blocker_popable_found) {
    56       blocker_popable_found =
false;
    57       for (
auto block : this->blocker_range(v)) {
    58         if (this->is_popable_blocker(block)) {
    60             if (nv != v) vertex_to_check.push_back(nv);
    61           this->delete_blocker(block);
    62           blocker_popable_found =
true;
    73 template<
    75   bool blocker_popable_found =
true;
    76   while (blocker_popable_found) {
    77     blocker_popable_found =
false;
    78     for (
    79       if (is_popable_blocker(block)) {
    80         this->delete_blocker(block);
    81         blocker_popable_found =
true;
    92 template<
    94   std::list<Vertex_handle> vertex_to_check;
    95   vertex_to_check.push_front(v);
    97   while (!vertex_to_check.empty()) {
    99     vertex_to_check.pop_front();
   101     bool blocker_popable_found =
true;
   102     while (blocker_popable_found) {
   103       blocker_popable_found =
false;
   104       for (
   105         if (this->is_popable_blocker(block)) {
   107             if (nv != v) vertex_to_check.push_back(nv);
   108           this->delete_blocker(block);
   109           blocker_popable_found =
true;
   120 template<
   123   update_blockers_after_remove_star_of_vertex_or_edge(
Simplex(v));
   124   while (this->degree(v) > 0) {
   125     Vertex_handle w(* (adjacent_vertices(v.vertex, this->skeleton).first));
   126     this->remove_edge(v, w);
   128   this->remove_vertex(v);
   136 template<
   138   std::list <Blocker_handle> blockers_to_update;
   139   if (simplex_to_be_removed.empty())
return;
   142   for (
auto blocker : this->blocker_range(v0)) {
   143     if (blocker->contains(simplex_to_be_removed))
   144       blockers_to_update.push_back(blocker);
   147   for (
auto blocker_to_update : blockers_to_update) {
   148     Simplex sub_blocker_to_be_added;
   149     bool sub_blocker_need_to_be_added =
   150         (blocker_to_update->dimension() - simplex_to_be_removed.
dimension()) >= 2;
   151     if (sub_blocker_need_to_be_added) {
   152       sub_blocker_to_be_added = *blocker_to_update;
   153       sub_blocker_to_be_added.
difference(simplex_to_be_removed);
   155     this->delete_blocker(blocker_to_update);
   156     if (sub_blocker_need_to_be_added)
   157       this->add_blocker(sub_blocker_to_be_added);
   165 template<
   167   update_blockers_after_remove_star_of_vertex_or_edge(
Simplex(a, b));
   169   this->remove_edge(a, b);
   175 template<
   177   return remove_star(this->first_vertex(e), this->second_vertex(e));
   183 template<
   185   assert(this->contains(sigma));
   191     remove_blocker_containing_simplex(sigma);
   192     this->add_blocker(sigma);
   196 template<
   200   assert(!this->contains(sigma));
   202   if (!contains_vertices(sigma)) {
   203     std::cerr <<
"add_simplex: Some vertices were not present in the complex, adding them" << std::endl;
   204     size_t num_vertices_to_add = sigma.
last_vertex() - this->num_vertices() + 1;
   205     for (
size_t i = 0; i < num_vertices_to_add; ++i)
   208   assert(contains_vertices(sigma));
   209   if (!contains_edges(sigma))
   211   remove_blocker_include_in_simplex(sigma);
   212   add_blockers_after_simplex_insertion(sigma);
   215 template<
   219   for (
auto s : coboundary_range(sigma)) {
   220     this->add_blocker(s);
   227 template<
   229   std::vector <Blocker_handle> blockers_to_remove;
   230   for (
auto blocker : this->blocker_range(sigma.
first_vertex())) {
   231     if (blocker->contains(sigma))
   232       blockers_to_remove.push_back(blocker);
   234   for (
auto blocker_to_update : blockers_to_remove)
   235     this->delete_blocker(blocker_to_update);
   241 template<
   245   std::set <Blocker_handle> blockers_to_remove;
   246   for (
auto s : sigma) {
   247     for (
auto blocker : this->blocker_range(s)) {
   248       if (sigma.contains(*blocker))
   249         blockers_to_remove.insert(blocker);
   252   for (
auto blocker_to_update : blockers_to_remove) {
   253     auto s = *blocker_to_update;
   254     this->delete_blocker(blocker_to_update);
   258     for (
const auto& b : coboundary_range(s))
   259       if (!sigma.contains(b))
   260         this->add_blocker(b);
   269 template<
   271        std::vector<Simplex> & buffer)
 const {
   272   for (
auto const & blocker : this->const_blocker_range(a)) {
   275     buffer.push_back(beta);
   279   this->add_neighbours(b, n);
   280   this->remove_neighbours(a, n);
   287     buffer.push_back(beta);
   299 template<
   302   this->add_edge_without_blockers(a, x);
   303   if (this->visitor) this->visitor->on_swaped_edge(a, b, x);
   304   this->remove_edge(b, x);
   307 template<
   310   std::list <Blocker_handle> blockers_to_delete;
   311   for (
auto blocker : this->blocker_range(v)) {
   312     blockers_to_delete.push_back(blocker);
   314   while (!blockers_to_delete.empty()) {
   315     this->remove_blocker(blockers_to_delete.back());
   316     blockers_to_delete.pop_back();
   323 template<
   326   std::list<Blocker_handle> blocker_to_delete;
   327   for (
auto blocker : this->blocker_range(a))
   328     if (blocker->contains(b)) blocker_to_delete.push_back(blocker);
   329   while (!blocker_to_delete.empty()) {
   330     this->delete_blocker(blocker_to_delete.back());
   331     blocker_to_delete.pop_back();
   340 template<
   343   assert(this->contains_vertex(a));
   344   assert(this->contains_vertex(b));
   346   if (this->contains_edge(a, b))
   347     this->add_edge_without_blockers(a, b);
   350   if (!link_condition(a, b))
   351     delete_blockers_around_edge(a, b);
   353   std::set<Simplex> blockers_to_add;
   355   get_blockers_to_be_added_after_contraction(a, b, blockers_to_add);
   357   delete_blockers_around_vertices(a, b);
   359   update_edges_after_contraction(a, b);
   361   this->remove_vertex(b);
   363   notify_changed_edges(a);
   365   for (
auto block : blockers_to_add)
   366     this->add_blocker(block);
   368   assert(this->contains_vertex(a));
   369   assert(!this->contains_vertex(b));
   372 template<
   375        std::set<Simplex>& blockers_to_add) {
   376   blockers_to_add.
clear();
   380   LinkComplexType link_a(*
this, a);
   381   LinkComplexType link_b(*
this, b);
   383   std::vector<Simplex> vector_alpha, vector_beta;
   385   tip_blockers(a, b, vector_alpha);
   386   tip_blockers(b, a, vector_beta);
   388   for (
auto alpha = vector_alpha.begin(); alpha != vector_alpha.end(); ++alpha) {
   389     for (
auto beta = vector_beta.begin(); beta != vector_beta.end(); ++beta) {
   393       if (this->contains(sigma) &&
   397         blockers_to_add.insert(sigma);
   406 template<
   409   std::vector<Blocker_handle> blocker_to_delete;
   410   for (
auto bl : this->blocker_range(a))
   411     blocker_to_delete.push_back(bl);
   412   for (
auto bl : this->blocker_range(b))
   413     blocker_to_delete.push_back(bl);
   414   while (!blocker_to_delete.empty()) {
   415     this->delete_blocker(blocker_to_delete.back());
   416     blocker_to_delete.pop_back();
   420 template<
   424   this->remove_edge(a, b);
   428   while (this->degree(b) > 0) {
   429     Vertex_handle x(*(adjacent_vertices(b.vertex, this->skeleton).first));
   430     if (!this->contains_edge(a, x))
   432       this->swap_edge(a, b, x);
   434       this->remove_edge(b, x);
   438 template<
   442   boost_adjacency_iterator v, v_end;
   444   for (tie(v, v_end) = adjacent_vertices(a.vertex, this->skeleton); v != v_end; ++v)
   445     if (this->visitor) this->visitor->on_changed_edge(a,
Vertex_handle(*v));
   451 namespace skbl = skeleton_blocker;
   455 #endif  // SKELETON_BLOCKER_SIMPLIFIABLE_COMPLEX_H_ T last_vertex() const
Definition: Skeleton_blocker_simplex.h:220
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:38
void add_vertex(T v)
Definition: Skeleton_blocker_simplex.h:110
virtual void clear()
Definition: Skeleton_blocker_complex.h:311
int dimension() const
Definition: Skeleton_blocker_simplex.h:197
SkeletonBlockerGeometricDS ::Vertex_handle Vertex_handle
The type of an handle to a vertex of the complex.
Definition: Skeleton_blocker_complex.h:77
void difference(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:139
void remove_vertex(T v)
Definition: Skeleton_blocker_simplex.h:117
void contract_edge(Edge_handle edge)
Definition: Skeleton_blocker_complex.h:1246
void remove_star(Vertex_handle v)
Definition: Skeleton_blocker_simplifiable_complex.h:121
Class representing the link of a simplicial complex encoded by a skeleton/blockers pair...
Definition: Skeleton_blocker_link_complex.h:30
Definition: SimplicialComplexForAlpha.h:14
void remove_all_popable_blockers(Vertex_handle v)
Removes all the popable blockers of the complex passing through v and delete them. Also remove popable blockers in the neighborhood if they became popable.
Definition: Skeleton_blocker_simplifiable_complex.h:93
void add_simplex(const Simplex &sigma)
add a simplex and all its faces.
Definition: Skeleton_blocker_simplifiable_complex.h:197
void union_vertices(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:155
boost::graph_traits< Graph >::edge_descriptor Edge_handle
Handle to an edge of the complex.
Definition: Skeleton_blocker_complex.h:114
bool is_popable_blocker(Blocker_handle sigma) const
Definition: Skeleton_blocker_simplifiable_complex.h:33
virtual contractible_status is_contractible() const
Test if the complex is reducible using a strategy defined in the class (by default it tests if the co...
Definition: Skeleton_blocker_complex.h:1164
Abstract Simplicial Complex represented with a skeleton/blockers pair.
Definition: Skeleton_blocker_complex.h:51
void remove_popable_blockers()
Definition: Skeleton_blocker_simplifiable_complex.h:45
T first_vertex() const
Definition: Skeleton_blocker_simplex.h:210
