11 #ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_    12 #define SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_    14 #include <gudhi/Skeleton_blocker/Skeleton_blocker_simplex.h>    18 namespace skeleton_blocker {
    25 template<
typename Vertex_handle>
    30   virtual void on_add_vertex(Vertex_handle) = 0;
    31   virtual void on_remove_vertex(Vertex_handle) = 0;
    33   virtual void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) = 0;
    34   virtual void on_remove_edge(Vertex_handle a, Vertex_handle b) = 0;
    52   virtual void on_add_blocker(
    54   virtual void on_delete_blocker(
    63 template<
    67   void on_add_vertex(Vertex_handle) { }
    69   void on_remove_vertex(Vertex_handle) { }
    71   void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) { }
    73   void on_remove_edge(Vertex_handle a, Vertex_handle b) { }
    89 template<
    93   void on_add_vertex(Vertex_handle v) {
    94     std::cerr <<
"on_add_vertex:" << v << std::endl;
    97   void on_remove_vertex(Vertex_handle v) {
    98     std::cerr <<
"on_remove_vertex:" << v << std::endl;
   101   void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) {
   102     std::cerr <<
"on_add_edge_without_blockers:" << a <<
"," << b << std::endl;
   105   void on_remove_edge(Vertex_handle a, Vertex_handle b) {
   106     std::cerr <<
"on_remove_edge:" << a <<
   110     std::cerr <<
"on_changed_edge:" << a <<
   114     std::cerr <<
"on_swaped_edge:" << a <<
"," << b <<
"," << x << std::endl;
   118     std::cerr <<
"on_add_blocker:" << b << std::endl;
   122     std::cerr <<
"on_delete_blocker:" << b << std::endl;
   128 namespace skbl = skeleton_blocker;
   132 #endif  // SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_ A visitor that prints the visit information.
Definition: Skeleton_blocker_complex_visitor.h:90
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:38
Definition: SimplicialComplexForAlpha.h:14
void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)
Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already pre...
Definition: Skeleton_blocker_complex_visitor.h:113
void on_changed_edge(Vertex_handle a, Vertex_handle b)
Called when an edge changes, during the contraction of an edge.
Definition: Skeleton_blocker_complex_visitor.h:75
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:64
virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)=0
Interface for a visitor of a simplicial complex.
Definition: Skeleton_blocker_complex_visitor.h:26
virtual void on_changed_edge(Vertex_handle a, Vertex_handle b)=0
Definition: Skeleton_blocker_complex_visitor.h:109
Definition: Skeleton_blocker_complex_visitor.h:77
