11 #ifndef PERSISTENCE_LANDSCAPE_ON_GRID_H_    12 #define PERSISTENCE_LANDSCAPE_ON_GRID_H_    15 #include <gudhi/read_persistence_from_file.h>    16 #include <gudhi/common_persistence_representations.h>    32 namespace Persistence_representations {
    36 template <
typename operation>
    65     this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
    66     this->grid_min = this->grid_max = 0;
    73                                 size_t number_of_points_);
    80                                 size_t number_of_points_,
unsigned number_of_levels_of_landscape);
    91                                 unsigned number_of_levels_of_landscape,
    92                                 uint16_t dimension_ = std::numeric_limits<uint16_t>::max());
   102                                 uint16_t dimension_ = std::numeric_limits<uint16_t>::max());
   112                                 uint16_t dimension = std::numeric_limits<uint16_t>::max());
   124                                 uint16_t dimension = std::numeric_limits<uint16_t>::max());
   143     for (
size_t i = 0; i != maximal_level; ++i) {
   155     double dx = (this->grid_max - this->grid_min) / static_cast<double>(this->values_of_landscapes.size() - 1);
   158       std::clog <<
"this->grid_max : " << this->grid_max << std::endl;
   159       std::clog <<
"this->grid_min : " << this->grid_min << std::endl;
   160       std::clog <<
"this->values_of_landscapes.size() : " << this->values_of_landscapes.size() << std::endl;
   164     double previous_x = this->grid_min - dx;
   165     double previous_y = 0;
   166     for (
size_t i = 0; i != this->values_of_landscapes.size(); ++i) {
   167       double current_x = previous_x + dx;
   168       double current_y = 0;
   169       if (this->values_of_landscapes[i].
size() > level) current_y = this->values_of_landscapes[i][level];
   172         std::clog <<
"this->values_of_landscapes[i].size() : " << this->values_of_landscapes[i].size()
   173                   <<
" , level : " << level << std::endl;
   174         if (this->values_of_landscapes[i].
size() > level)
   175           std::clog <<
"this->values_of_landscapes[i][level] : " << this->values_of_landscapes[i][level] << std::endl;
   176         std::clog <<
"previous_y : " << previous_y << std::endl;
   177         std::clog <<
"current_y : " << current_y << std::endl;
   178         std::clog <<
"dx : " << dx << std::endl;
   179         std::clog <<
"0.5*dx*( previous_y + current_y ); " << 0.5 * dx * (previous_y + current_y) << std::endl;
   182       result += 0.5 * dx * (previous_y + current_y);
   183       previous_x = current_x;
   184       previous_y = current_y;
   196     for (
   210     double dx = (this->grid_max - this->grid_min) / static_cast<double>(this->values_of_landscapes.size() - 1);
   211     double previous_x = this->grid_min;
   212     double previous_y = 0;
   213     if (this->values_of_landscapes[0].
size() > level) previous_y = this->values_of_landscapes[0][level];
   216       std::clog <<
   217       std::clog <<
"previous_x : " << previous_x << std::endl;
   218       std::clog <<
   219       std::clog <<
"power : " << p << std::endl;
   223     for (
   224       double current_x = previous_x + dx;
   225       double current_y = 0;
   226       if (this->values_of_landscapes[i].
   228       if (dbg) std::clog <<
   230       if (current_y == previous_y)
continue;
   232       std::pair<double, double> coef =
   233           compute_parameters_of_a_line(std::make_pair(previous_x, previous_y), std::make_pair(current_x, current_y));
   234       double a = coef.first;
   235       double b = coef.second;
   238         std::clog <<
"A line passing through points : (" << previous_x <<
"," << previous_y <<
") and (" << current_x
   239                   <<
"," << current_y <<
") is : " << a <<
"x+" << b << std::endl;
   244       double value_to_add = 0;
   246         value_to_add = 1 / (a * (p + 1)) * (pow((a * current_x + b), p + 1) - pow((a * previous_x + b), p + 1));
   248         value_to_add = (current_x - previous_x) * (pow(b, p));
   250       result += value_to_add;
   252         std::clog <<
"Increasing result by : " << value_to_add << std::endl;
   253         std::clog <<
"result : " << result << std::endl;
   256       previous_x = current_x;
   257       previous_y = current_y;
   259     if (dbg) std::clog <<
"The total result is : " << result << std::endl;
   269     double dx = (land.grid_max - land.grid_min) / static_cast<double>(land.values_of_landscapes.size() - 1);
   270     double x = land.grid_min;
   271     for (
size_t i = 0; i != land.values_of_landscapes.size(); ++i) {
   273       for (
size_t j = 0; j != land.values_of_landscapes[i].size(); ++j) {
   274         out << land.values_of_landscapes[i][j] <<
   282   template <
typename oper>
   293     if ((x < this->grid_min) || (x > this->grid_max))
return 0;
   296     double dx = (this->grid_max - this->grid_min) / static_cast<double>(this->values_of_landscapes.size() - 1);
   297     size_t position = size_t((x - this->grid_min) / dx);
   300       std::clog <<
"This is a procedure compute_value_at_a_given_point \n";
   301       std::clog <<
"level : " << level << std::endl;
   302       std::clog <<
"x : " << x << std::endl;
   303       std::clog <<
"position : " << position << std::endl;
   306     if (almost_equal(position * dx + this->grid_min, x)) {
   307       if (this->values_of_landscapes[position].
size() < level) {
   308         return this->values_of_landscapes[position][level];
   314     std::pair<double, double> line;
   315     if ((this->values_of_landscapes[position].
size() > level) &&
   316         (this->values_of_landscapes[position + 1].
size() > level)) {
   317       line = compute_parameters_of_a_line(
   318           std::make_pair(position * dx + this->grid_min, this->values_of_landscapes[position][level]),
   319           std::make_pair((position + 1) * dx + this->grid_min, this->values_of_landscapes[position + 1][level]));
   321       if ((this->values_of_landscapes[position].
size() > level) ||
   322           (this->values_of_landscapes[position + 1].
size() > level)) {
   323         if ((this->values_of_landscapes[position].
size() > level)) {
   324           line = compute_parameters_of_a_line(
   325               std::make_pair(position * dx + this->grid_min, this->values_of_landscapes[position][level]),
   326               std::make_pair((position + 1) * dx + this->grid_min, 0));
   328           line = compute_parameters_of_a_line(
   329               std::make_pair(position * dx + this->grid_min, 0),
   330               std::make_pair((position + 1) * dx + this->grid_min, this->values_of_landscapes[position + 1][level]));
   337     return line.first * x + line.second;
   346     return operation_on_pair_of_landscapes_on_grid<std::plus<double> >(land1, land2);
   354     return operation_on_pair_of_landscapes_on_grid<std::minus<double> >(land1, land2);
   377     return first.multiply_lanscape_by_real_number_not_overwrite(con);
   384     return first.multiply_lanscape_by_real_number_not_overwrite(con);
   389     if (land1.values_of_landscapes.size() != land2.values_of_landscapes.size())
return false;
   390     if (land1.grid_min != land2.grid_min)
return false;
   391     if (land1.grid_max != land2.grid_max)
return false;
   424     if (x == 0)
throw(
"In operator /=, division by 0. Program terminated.");
   425     *
this = *
this * (1 / x);
   434     if (this->values_of_landscapes.size() != rhs.values_of_landscapes.size()) {
   435       if (dbg) std::clog <<
"values_of_landscapes of incompatible sizes\n";
   438     if (!almost_equal(this->grid_min, rhs.grid_min)) {
   439       if (dbg) std::clog <<
"grid_min not equal\n";
   442     if (!almost_equal(this->grid_max, rhs.grid_max)) {
   443       if (dbg) std::clog <<
"grid_max not equal\n";
   446     for (
   447       for (
size_t aa = 0; aa != this->values_of_landscapes[i].size(); ++aa) {
   448         if (!almost_equal(this->values_of_landscapes[i][aa], rhs.values_of_landscapes[i][aa])) {
   450             std::clog <<
"Problem in the position : " << i <<
" of values_of_landscapes. \n";
   451             std::clog << this->values_of_landscapes[i][aa] <<
" " << rhs.values_of_landscapes[i][aa] << std::endl;
   471     double max_value = -std::numeric_limits<double>::max();
   472     for (
   473       if (this->values_of_landscapes[i].
size()) {
   474         if (this->values_of_landscapes[i][0] > max_value) max_value = this->values_of_landscapes[i][0];
   475         if (this->values_of_landscapes[i][this->values_of_landscapes[i].
size() - 1] > max_value)
   476           max_value = this->values_of_landscapes[i][this->values_of_landscapes[i].
size() - 1];
   488     double max_value = -std::numeric_limits<double>::max();
   489     double min_value = 0;
   490     for (
   491       if (this->values_of_landscapes[i].
size()) {
   492         if (this->values_of_landscapes[i][0] > max_value) max_value = this->values_of_landscapes[i][0];
   493         if (this->values_of_landscapes[i][this->values_of_landscapes[i].
   494           max_value = this->values_of_landscapes[i][this->values_of_landscapes[i].
size() - 1];
   496         if (this->values_of_landscapes[i][0] < min_value) min_value = this->values_of_landscapes[i][0];
   497         if (this->values_of_landscapes[i][this->values_of_landscapes[i].
size() - 1] < min_value)
   498           min_value = this->values_of_landscapes[i][this->values_of_landscapes[i].
size() - 1];
   501     return std::make_pair(min_value, max_value);
   509     return std::make_pair(this->grid_min, this->grid_max);
   523     for (
   524       if (this->values_of_landscapes[i].
size() > result) result = this->values_of_landscapes[i].
size();
   533     std::vector<std::pair<double, double> > p;
   536     if (i < std::numeric_limits<double>::max()) {
   561     for (
   562       for (
size_t j = 0; j != this->values_of_landscapes[i].size(); ++j) {
   563         this->values_of_landscapes[i][j] = std::abs(this->values_of_landscapes[i][j]);
   577     double max_value = -std::numeric_limits<double>::max();
   578     for (
   579       if (this->values_of_landscapes[i].
size() > lambda) {
   580         if (this->values_of_landscapes[i][lambda] > max_value) max_value = this->values_of_landscapes[i][lambda];
   591     if (!check_if_defined_on_the_same_domain(l1, l2))
   592       throw "Landscapes are not defined on the same grid, the program will now terminate";
   595     for (
   608     if (!check_if_defined_on_the_same_domain(l1, l2))
   609       throw "Landscapes are not defined on the same grid, the program will now terminate";
   612     double dx = (l1.grid_max - l1.grid_min) / static_cast<double>(l1.values_of_landscapes.size() - 1);
   614     double previous_x = l1.grid_min - dx;
   615     double previous_y_l1 = 0;
   616     double previous_y_l2 = 0;
   617     for (
size_t i = 0; i != l1.values_of_landscapes.size(); ++i) {
   618       if (dbg) std::clog <<
"i : " << i << std::endl;
   620       double current_x = previous_x + dx;
   621       double current_y_l1 = 0;
   622       if (l1.values_of_landscapes[i].size() > level) current_y_l1 = l1.values_of_landscapes[i][level];
   624       double current_y_l2 = 0;
   625       if (l2.values_of_landscapes[i].size() > level) current_y_l2 = l2.values_of_landscapes[i][level];
   628         std::clog <<
   629         std::clog <<
"previous_y_l1 : " << previous_y_l1 << std::endl;
   630         std::clog <<
"current_y_l1 : " << current_y_l1 << std::endl;
   631         std::clog <<
"previous_y_l2 : " << previous_y_l2 << std::endl;
   632         std::clog <<
"current_y_l2 : " << current_y_l2 << std::endl;
   635       std::pair<double, double> l1_coords = compute_parameters_of_a_line(std::make_pair(previous_x, previous_y_l1),
   636        std::make_pair(current_x, current_y_l1));
   637       std::pair<double, double> l2_coords = compute_parameters_of_a_line(std::make_pair(previous_x, previous_y_l2),
   638        std::make_pair(current_x, current_y_l2));
   642       double a = l1_coords.first;
   643       double b = l1_coords.second;
   645       double c = l2_coords.first;
   646       double d = l2_coords.second;
   649         std::clog <<
"Here are the formulas for a line: \n";
   650         std::clog <<
"a : " << a << std::endl;
   651         std::clog <<
"b : " << b << std::endl;
   652         std::clog <<
"c : " << c << std::endl;
   653         std::clog <<
"d : " << d << std::endl;
   660       double added_value = (a * c / 3 * current_x * current_x * current_x +
   661                             (a * d + b * c) / 2 * current_x * current_x + b * d * current_x) -
   662                            (a * c / 3 * previous_x * previous_x * previous_x +
   663                             (a * d + b * c) / 2 * previous_x * previous_x + b * d * previous_x);
   666         std::clog <<
"Value of the integral on the left end i.e. : " << previous_x <<
" is : "   667                   << a * c / 3 * previous_x * previous_x * previous_x + (a * d + b * c) / 2 * previous_x * previous_x +
   670         std::clog <<
"Value of the integral on the right end i.e. : " << current_x <<
" is "   671                   << a * c / 3 * current_x * current_x * current_x + (a * d + b * c) / 2 * current_x * current_x +
   676       result += added_value;
   679         std::clog <<
"added_value : " << added_value << std::endl;
   680         std::clog <<
   684       previous_x = current_x;
   685       previous_y_l1 = current_y_l1;
   686       previous_y_l2 = current_y_l2;
   706       std::clog <<
"first : " << first << std::endl;
   707       std::clog <<
"second : " << second << std::endl;
   715       std::clog <<
"Difference : " << lan << std::endl;
   722       std::clog <<
"Abs : " << lan << std::endl;
   725     if (p < std::numeric_limits<double>::max()) {
   730           std::clog <<
"p : " << p << std::endl;
   735           std::clog <<
"integral : " << result << std::endl;
   741           std::clog <<
"integral, without power : " << result << std::endl;
   746       return pow(result, 1.0 / p);
   777   std::vector<double>
vectorize(
int number_of_function)
 const {
   779     if ((number_of_function < 0) || ((
size_t)number_of_function >= this->values_of_landscapes.size())) {
   780       throw "Wrong number of function\n";
   782     std::vector<double> v(this->values_of_landscapes.size());
   783     for (
   785       if (this->values_of_landscapes[i].
size() > (size_t)number_of_function) {
   786         v[i] = this->values_of_landscapes[i][number_of_function];
   806     this->values_of_landscapes.clear();
   807     this->grid_min = this->grid_max = 0;
   810     if (to_average.size() == 0)
return;
   813     for (
size_t i = 0; i != to_average.size(); ++i) {
   814       if (!check_if_defined_on_the_same_domain(*(to_average[0]), *(to_average[i])))
   815         throw "Two grids are not compatible";
   818     this->values_of_landscapes = std::vector<std::vector<double> >((to_average[0])->values_of_landscapes.size());
   819     this->grid_min = (to_average[0])->grid_min;
   820     this->grid_max = (to_average[0])->grid_max;
   823       std::clog <<
"Computations of average. The data from the current landscape have been cleared. We are ready to do "   824                    "the computations. \n";
   828     for (
size_t grid_point = 0; grid_point != (to_average[0])->values_of_landscapes.size(); ++grid_point) {
   830       size_t maximal_size_of_vector = 0;
   831       for (
size_t land_no = 0; land_no != to_average.size(); ++land_no) {
   832         if ((to_average[land_no])->values_of_landscapes[grid_point].size() > maximal_size_of_vector)
   833           maximal_size_of_vector = (to_average[land_no])->values_of_landscapes[grid_point].size();
   835       this->values_of_landscapes[grid_point] = std::vector<double>(maximal_size_of_vector);
   838         std::clog <<
"We are considering the point : " << grid_point
   839                   <<
" of the grid. In this point, there are at most : " << maximal_size_of_vector
   840                   <<
" nonzero landscape functions \n";
   844       for (
   846         for (
size_t i = 0; i != (to_average[land_no])->values_of_landscapes[grid_point].
size(); ++i) {
   848           this->values_of_landscapes[grid_point][i] += (to_average[land_no])->values_of_landscapes[grid_point][i];
   852       for (
size_t i = 0; i != this->values_of_landscapes[grid_point].size(); ++i) {
   853         this->values_of_landscapes[grid_point][i] /=
static_cast<double>(to_average.size());
   865     if (power < std::numeric_limits<double>::max()) {
   897   void plot(
const char* filename,
size_t from_,
size_t to_)
 const {
   898     this->
plot(filename, std::numeric_limits<double>::max(), std::numeric_limits<double>::max(),
   899                std::numeric_limits<double>::max(), std::numeric_limits<double>::max(), from_, to_);
   906   void plot(
double min_x = std::numeric_limits<double>::max(),
   907             double max_x = std::numeric_limits<double>::max(),
double min_y = std::numeric_limits<double>::max(),
   908             double max_y = std::numeric_limits<double>::max(),
size_t from_ = std::numeric_limits<size_t>::max(),
   909             size_t to_ = std::numeric_limits<size_t>::max())
const;
   914   std::vector<std::vector<double> > values_of_landscapes;
   915   size_t number_of_functions_for_vectorization;
   916   size_t number_of_functions_for_projections_to_reals;
   918   void set_up_numbers_of_functions_for_vectorization_and_projections_to_reals() {
   920     this->number_of_functions_for_vectorization = this->values_of_landscapes.size();
   921     this->number_of_functions_for_projections_to_reals = this->values_of_landscapes.size();
   923   void set_up_values_of_landscapes(
const std::vector<std::pair<double, double> >& p,
double grid_min_,
double grid_max_,
   924                                    size_t number_of_points_,
   925                                    unsigned number_of_levels = std::numeric_limits<unsigned>::max());
   929 void Persistence_landscape_on_grid::set_up_values_of_landscapes(
   930        double grid_min_,
double grid_max_,
   931        size_t number_of_points_,
unsigned number_of_levels) {
   934     std::clog <<
"Here is the procedure : set_up_values_of_landscapes. The parameters are : grid_min_ : " << grid_min_
   935               <<
", grid_max_ : " << grid_max_ <<
", number_of_points_ : " << number_of_points_
   936               <<
", number_of_levels: " << number_of_levels << std::endl;
   937     std::clog <<
"Here are the intervals at our disposal : \n";
   938     for (
size_t i = 0; i != p.size(); ++i) {
   939       std::clog << p[i].first <<
" , " << p[i].second << std::endl;
   943   if ((grid_min_ == std::numeric_limits<double>::max()) || (grid_max_ == std::numeric_limits<double>::max())) {
   945     double min = std::numeric_limits<double>::max();
   946     double max = std::numeric_limits<double>::min();
   947     for (
   948       if (p[i].first < min) min = p[i].first;
   949       if (p[i].second > max) max = p[i].second;
   951     if (grid_min_ == std::numeric_limits<double>::max()) {
   962   this->values_of_landscapes = std::vector<std::vector<double> >(number_of_points_ + 1);
   964   this->grid_min = grid_min_;
   965   this->grid_max = grid_max_;
   967   if (grid_max_ <= grid_min_) {
   968     throw "Wrong parameters of grid_min and grid_max given to the procedure. The program will now terminate.\n";
   971   double dx = (grid_max_ - grid_min_) / static_cast<double>(number_of_points_);
   973   for (
size_t int_no = 0; int_no != p.size(); ++int_no) {
   974     size_t grid_interval_begin = (p[int_no].first - grid_min_) / dx;
   975     size_t grid_interval_end = (p[int_no].second - grid_min_) / dx;
   976     size_t grid_interval_midpoint = (size_t)(0.5 * (grid_interval_begin + grid_interval_end));
   979       std::clog <<
"Considering an interval : " << p[int_no].first <<
"," << p[int_no].second << std::endl;
   981       std::clog <<
"grid_interval_begin : " << grid_interval_begin << std::endl;
   982       std::clog <<
"grid_interval_end : " << grid_interval_end << std::endl;
   983       std::clog <<
"grid_interval_midpoint : " << grid_interval_midpoint << std::endl;
   986     double landscape_value = dx;
   987     for (
size_t i = grid_interval_begin + 1; i < grid_interval_midpoint; ++i) {
   989         std::clog <<
"Adding landscape value (going up) for a point : " << i <<
" equal : " << landscape_value
   992       if (number_of_levels != std::numeric_limits<unsigned>::max()) {
   996         if (this->values_of_landscapes[i].
size() >= number_of_levels) {
   999           if (-landscape_value < this->values_of_landscapes[i].front()) {
  1001             std::pop_heap(this->values_of_landscapes[i].begin(), this->values_of_landscapes[i].end());
  1002             this->values_of_landscapes[i][this->values_of_landscapes[i].size() - 1] = -landscape_value;
  1003             std::push_heap(this->values_of_landscapes[i].begin(), this->values_of_landscapes[i].end());
  1007           this->values_of_landscapes[i].push_back(-landscape_value);
  1008           if (this->values_of_landscapes[i].
size() == number_of_levels - 1) {
  1011             std::make_heap(this->values_of_landscapes[i].begin(), this->values_of_landscapes[i].end());
  1016         this->values_of_landscapes[i].push_back(landscape_value);
  1018       landscape_value += dx;
  1020     for (
size_t i = grid_interval_midpoint; i <= grid_interval_end; ++i) {
  1021       if (landscape_value > 0) {
  1022         if (number_of_levels != std::numeric_limits<unsigned>::max()) {
  1024           if (this->values_of_landscapes[i].
  1027             if (-landscape_value < this->values_of_landscapes[i].front()) {
  1029               std::pop_heap(this->values_of_landscapes[i].begin(), this->values_of_landscapes[i].end());
  1030               this->values_of_landscapes[i][this->values_of_landscapes[i].size() - 1] = -landscape_value;
  1031               std::push_heap(this->values_of_landscapes[i].begin(), this->values_of_landscapes[i].end());
  1035             this->values_of_landscapes[i].push_back(-landscape_value);
  1036             if (this->values_of_landscapes[i].
  1039               std::make_heap(this->values_of_landscapes[i].begin(), this->values_of_landscapes[i].end());
  1043           this->values_of_landscapes[i].push_back(landscape_value);
  1047           std::clog <<
"Adding landscape value (going down) for a point : " << i <<
  1051       landscape_value -= dx;
  1055   if (number_of_levels != std::numeric_limits<unsigned>::max()) {
  1059     for (
size_t pt = 0; pt != this->values_of_landscapes.size(); ++pt) {
  1060       for (
size_t j = 0; j != this->values_of_landscapes[pt].size(); ++j) {
  1061         this->values_of_landscapes[pt][j] *= -1;
  1067   for (
  1068     std::sort(this->values_of_landscapes[pt].begin(), this->values_of_landscapes[pt].end(), std::greater<double>());
  1073                                                              double grid_min_,
double grid_max_,
  1074                                                              size_t number_of_points_) {
  1075   this->set_up_values_of_landscapes(p, grid_min_, grid_max_, number_of_points_);
  1079                                                              double grid_min_,
double grid_max_,
  1080                                                              size_t number_of_points_,
  1081                                                              unsigned number_of_levels_of_landscape) {
  1082   this->set_up_values_of_landscapes(p, grid_min_, grid_max_, number_of_points_, number_of_levels_of_landscape);
  1086                                                              size_t number_of_points_, uint16_t dimension) {
  1087   std::vector<std::pair<double, double> > p;
  1088   if (dimension == std::numeric_limits<uint16_t>::max()) {
  1089     p = read_persistence_intervals_in_one_dimension_from_file(filename);
  1091     p = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
  1093   this->set_up_values_of_landscapes(p, grid_min_, grid_max_, number_of_points_);
  1097                                                              size_t number_of_points_,
  1098                                                              unsigned number_of_levels_of_landscape,
  1099                                                              uint16_t dimension) {
  1100   std::vector<std::pair<double, double> > p;
  1101   if (dimension == std::numeric_limits<uint16_t>::max()) {
  1102     p = read_persistence_intervals_in_one_dimension_from_file(filename);
  1104     p = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
  1106   this->set_up_values_of_landscapes(p, grid_min_, grid_max_, number_of_points_, number_of_levels_of_landscape);
  1110                                                              uint16_t dimension) {
  1111   std::vector<std::pair<double, double> > p;
  1112   if (dimension == std::numeric_limits<uint16_t>::max()) {
  1113     p = read_persistence_intervals_in_one_dimension_from_file(filename);
  1115     p = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
  1117   double grid_min_ = std::numeric_limits<double>::max();
  1118   double grid_max_ = -std::numeric_limits<double>::max();
  1119   for (
  1120     if (p[i].first < grid_min_) grid_min_ = p[i].first;
  1121     if (p[i].second > grid_max_) grid_max_ = p[i].second;
  1123   this->set_up_values_of_landscapes(p, grid_min_, grid_max_, number_of_points_);
  1127                                                              unsigned number_of_levels_of_landscape,
  1128                                                              uint16_t dimension) {
  1129   std::vector<std::pair<double, double> > p;
  1130   if (dimension == std::numeric_limits<uint16_t>::max()) {
  1131     p = read_persistence_intervals_in_one_dimension_from_file(filename);
  1133     p = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
  1135   double grid_min_ = std::numeric_limits<double>::max();
  1136   double grid_max_ = -std::numeric_limits<double>::max();
  1137   for (
  1138     if (p[i].first < grid_min_) grid_min_ = p[i].first;
  1139     if (p[i].second > grid_max_) grid_max_ = p[i].second;
  1141   this->set_up_values_of_landscapes(p, grid_min_, grid_max_, number_of_points_, number_of_levels_of_landscape);
  1149     std::cerr <<
"The file : " << filename <<
" do not exist. The program will now terminate \n";
  1150     throw "The persistence landscape file do not exist. The program will now terminate \n";
  1153   size_t number_of_points_in_the_grid = 0;
  1154   in >> this->grid_min >> this->grid_max >> number_of_points_in_the_grid;
  1156   std::vector<std::vector<double> > v(number_of_points_in_the_grid);
  1158   std::getline(in, line);
  1160   for (
size_t i = 0; i != number_of_points_in_the_grid; ++i) {
  1162     std::vector<double> vv;
  1163     std::getline(in, line);
  1164     std::istringstream stream(line);
  1165     while (stream >> number) {
  1166       vv.push_back(number);
  1170   this->values_of_landscapes = v;
  1179   out << grid_min << std::endl << grid_max << std::endl << this->values_of_landscapes.size() << std::endl;
  1182   for (
  1183     for (
  1184       out << this->values_of_landscapes[i][j] <<
  1193                                          size_t from_,
size_t to_)
 const {
  1197   std::ostringstream gnuplot_script;
  1198   gnuplot_script << filename <<
"_GnuplotScript";
  1199   out.open(gnuplot_script.str().c_str());
  1201   if (min_x == max_x) {
  1203     out <<
"set xrange [" << this->grid_min <<
" : " << this->grid_max <<
"]" << std::endl;
  1204     out <<
"set yrange [" << min_max.first <<
" : " << min_max.second <<
"]" << std::endl;
  1206     out <<
"set xrange [" << min_x <<
" : " << max_x <<
"]" << std::endl;
  1207     out <<
"set yrange [" << min_y <<
" : " << max_y <<
"]" << std::endl;
  1211   double dx = (this->grid_max - this->grid_min) / static_cast<double>(this->values_of_landscapes.size() - 1);
  1214   if (from_ != std::numeric_limits<size_t>::max()) {
  1215     if (from_ < number_of_nonzero_levels) {
  1222   if (to_ != std::numeric_limits<size_t>::max()) {
  1223     if (to_ < number_of_nonzero_levels) {
  1229   for (
size_t lambda = from; lambda != to; ++lambda) {
  1230     out <<
"     '-' using 1:2 notitle with lp";
  1231     if (lambda + 1 != to) {
  1237   for (
  1238     double point = this->grid_min;
  1239     for (
  1241       if (this->values_of_landscapes[i].
size() > lambda) {
  1242         value = this->values_of_landscapes[i][lambda];
  1244       out << point <<
" " << value << std::endl;
  1247     out <<
"EOF" << std::endl;
  1249   std::clog <<
"To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'"  1250             << gnuplot_script.str().c_str() <<
"\'\"" << std::endl;
  1253 template <
typename T>
  1257   if (!check_if_defined_on_the_same_domain(land1, land2))
  1261   result.values_of_landscapes = std::vector<std::vector<double> >(land1.values_of_landscapes.size());
  1262   result.grid_min = land1.grid_min;
  1263   result.grid_max = land1.grid_max;
  1266   for (
size_t grid_point = 0; grid_point != land1.values_of_landscapes.size(); ++grid_point) {
  1267     result.values_of_landscapes[grid_point] = std::vector<double>(
  1268         std::max(land1.values_of_landscapes[grid_point].size(), land2.values_of_landscapes[grid_point].size()));
  1269     for (
size_t lambda = 0; lambda != std::max(land1.values_of_landscapes[grid_point].size(),
  1270                                                land2.values_of_landscapes[grid_point].size());
  1274       if (lambda < land1.values_of_landscapes[grid_point].size())
  1275         value1 = land1.values_of_landscapes[grid_point][lambda];
  1276       if (lambda < land2.values_of_landscapes[grid_point].size())
  1277         value2 = land2.values_of_landscapes[grid_point][lambda];
  1278       result.values_of_landscapes[grid_point][lambda] = oper(value1, value2);
  1288   result.values_of_landscapes = std::vector<std::vector<double> >(this->values_of_landscapes.size());
  1289   result.grid_min = this->grid_min;
  1290   result.grid_max = this->grid_max;
  1292   for (
size_t grid_point = 0; grid_point != this->values_of_landscapes.size(); ++grid_point) {
  1293     result.values_of_landscapes[grid_point] = std::vector<double>(this->values_of_landscapes[grid_point].size());
  1294     for (
  1295       result.values_of_landscapes[grid_point][i] = x * this->values_of_landscapes[grid_point][i];
  1307   if (!check_if_defined_on_the_same_domain(first, second))
  1309   for (
size_t i = 0; i != first.values_of_landscapes.size(); ++i) {
  1310     for (
size_t j = 0; j != std::min(first.values_of_landscapes[i].size(), second.values_of_landscapes[i].size());
  1312       if (result <
abs(first.values_of_landscapes[i][j] - second.values_of_landscapes[i][j])) {
  1313         result =
abs(first.values_of_landscapes[i][j] - second.values_of_landscapes[i][j]);
  1316     if (first.values_of_landscapes[i].size() ==
  1317         std::min(first.values_of_landscapes[i].size(), second.values_of_landscapes[i].size())) {
  1318       for (
size_t j = first.values_of_landscapes[i].size(); j != second.values_of_landscapes[i].size(); ++j) {
  1319         if (result < second.values_of_landscapes[i][j]) result = second.values_of_landscapes[i][j];
  1322     if (second.values_of_landscapes[i].size() ==
  1323         std::min(first.values_of_landscapes[i].size(), second.values_of_landscapes[i].size())) {
  1324       for (
size_t j = second.values_of_landscapes[i].size(); j != first.values_of_landscapes[i].size(); ++j) {
  1325         if (result < first.values_of_landscapes[i][j]) result = first.values_of_landscapes[i][j];
  1335 #endif  // PERSISTENCE_LANDSCAPE_ON_GRID_H_ friend double compute_distance_of_landscapes_on_grid(const Persistence_landscape_on_grid &first, const Persistence_landscape_on_grid &second, double p)
Definition: Persistence_landscape_on_grid.h:699
std::pair< double, double > get_x_range(size_t level=0) const
Definition: Persistence_landscape_on_grid.h:508
bool operator!=(const Persistence_landscape_on_grid &rhs) const
Definition: Persistence_landscape_on_grid.h:463
double distance(const Persistence_landscape_on_grid &second, double power=1) const
Definition: Persistence_landscape_on_grid.h:864
friend Persistence_landscape_on_grid operator*(const Persistence_landscape_on_grid &first, double con)
Definition: Persistence_landscape_on_grid.h:376
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_landscape_on_grid.h:777
friend double compute_max_norm_distance_of_landscapes(const Persistence_landscape_on_grid &first, const Persistence_landscape_on_grid &second)
Definition: Persistence_landscape_on_grid.h:1302
void print_to_file(const char *filename) const
Definition: Persistence_landscape_on_grid.h:1174
void compute_average(const std::vector< Persistence_landscape_on_grid *> &to_average)
Definition: Persistence_landscape_on_grid.h:802
void plot(const char *filename, size_t from_, size_t to_) const
Definition: Persistence_landscape_on_grid.h:897
friend Persistence_landscape_on_grid operator*(double con, const Persistence_landscape_on_grid &first)
Definition: Persistence_landscape_on_grid.h:383
Definition: SimplicialComplexForAlpha.h:14
double compute_integral_of_landscape() const
Definition: Persistence_landscape_on_grid.h:140
double operator()(unsigned level, double x) const
Definition: Persistence_landscape_on_grid.h:546
void load_landscape_from_file(const char *filename)
Definition: Persistence_landscape_on_grid.h:1144
Persistence_landscape_on_grid operator-=(const Persistence_landscape_on_grid &rhs)
Definition: Persistence_landscape_on_grid.h:406
double compute_integral_of_landscape(double p) const
Definition: Persistence_landscape_on_grid.h:193
double compute_value_at_a_given_point(unsigned level, double x) const
Definition: Persistence_landscape_on_grid.h:291
Persistence_landscape_on_grid()
Definition: Persistence_landscape_on_grid.h:64
void abs()
Definition: Persistence_landscape_on_grid.h:560
size_t number_of_nonzero_levels() const
Definition: Persistence_landscape_on_grid.h:521
friend Persistence_landscape_on_grid add_two_landscapes(const Persistence_landscape_on_grid &land1, const Persistence_landscape_on_grid &land2)
Definition: Persistence_landscape_on_grid.h:344
friend Persistence_landscape_on_grid operator-(const Persistence_landscape_on_grid &first, const Persistence_landscape_on_grid &second)
Definition: Persistence_landscape_on_grid.h:368
A class implementing persistence landscapes by approximating them on a collection of grid points...
Definition: Persistence_landscape_on_grid.h:59
Persistence_landscape_on_grid operator+=(const Persistence_landscape_on_grid &rhs)
Definition: Persistence_landscape_on_grid.h:398
friend double compute_inner_product(const Persistence_landscape_on_grid &l1, const Persistence_landscape_on_grid &l2)
Definition: Persistence_landscape_on_grid.h:589
size_t size() const
Definition: Persistence_landscape_on_grid.h:571
std::pair< double, double > compute_minimum_maximum() const
Definition: Persistence_landscape_on_grid.h:485
friend std::ostream & operator<<(std::ostream &out, const Persistence_landscape_on_grid &land)
Definition: Persistence_landscape_on_grid.h:268
friend double compute_inner_product(const Persistence_landscape_on_grid &l1, const Persistence_landscape_on_grid &l2, size_t level)
Definition: Persistence_landscape_on_grid.h:604
double compute_norm_of_landscape(double i) const
Definition: Persistence_landscape_on_grid.h:532
size_t number_of_vectorize_functions() const
Definition: Persistence_landscape_on_grid.h:796
friend Persistence_landscape_on_grid operator+(const Persistence_landscape_on_grid &first, const Persistence_landscape_on_grid &second)
Definition: Persistence_landscape_on_grid.h:360
std::pair< double, double > get_y_range(size_t level=0) const
Definition: Persistence_landscape_on_grid.h:516
std::vector< std::vector< double > > output_for_visualization() const
Definition: Persistence_landscape_on_grid.h:886
double compute_maximum() const
Definition: Persistence_landscape_on_grid.h:468
double compute_scalar_product(const Persistence_landscape_on_grid &second)
Definition: Persistence_landscape_on_grid.h:877
double project_to_R(int number_of_function) const
Definition: Persistence_landscape_on_grid.h:763
Persistence_landscape_on_grid operator/=(double x)
Definition: Persistence_landscape_on_grid.h:423
double compute_integral_of_landscape(double p, size_t level) const
Definition: Persistence_landscape_on_grid.h:206
size_t number_of_projections_to_R() const
Definition: Persistence_landscape_on_grid.h:771
friend Persistence_landscape_on_grid subtract_two_landscapes(const Persistence_landscape_on_grid &land1, const Persistence_landscape_on_grid &land2)
Definition: Persistence_landscape_on_grid.h:352
double compute_integral_of_landscape(size_t level) const
Definition: Persistence_landscape_on_grid.h:152
Persistence_landscape_on_grid operator*=(double x)
Definition: Persistence_landscape_on_grid.h:415
double find_max(unsigned lambda) const
Definition: Persistence_landscape_on_grid.h:576
bool operator==(const Persistence_landscape_on_grid &rhs) const
Definition: Persistence_landscape_on_grid.h:432
