11 #ifndef PERSISTENCE_LANDSCAPE_H_    12 #define PERSISTENCE_LANDSCAPE_H_    15 #include <gudhi/read_persistence_from_file.h>    16 #include <gudhi/common_persistence_representations.h>    31 namespace Persistence_representations {
    35 template <
typename operation>
    71                         size_t number_of_levels = std::numeric_limits<size_t>::max());
    79                         size_t number_of_levels = std::numeric_limits<size_t>::max());
   122   template <
typename operation>
   131     return operation_on_pair_of_landscapes<std::plus<double> >(land1, land2);
   139     return operation_on_pair_of_landscapes<std::minus<double> >(land1, land2);
   160     return first.multiply_lanscape_by_real_number_not_overwrite(con);
   167     return first.multiply_lanscape_by_real_number_not_overwrite(con);
   199     if (x == 0)
throw(
"In operator /=, division by 0. Program terminated.");
   200     *
this = *
this * (1 / x);
   219     if (this->land.
size()) {
   220       maxValue = -std::numeric_limits<int>::max();
   221       for (
size_t i = 0; i != this->land[0].
size(); ++i) {
   222         if (this->land[0][i].second > maxValue) maxValue = this->land[0][i].second;
   231   double compute_minimum()
 const {
   233     if (this->land.
size()) {
   234       minValue = std::numeric_limits<int>::max();
   235       for (
size(); ++i) {
   236         if (this->land[0][i].second < minValue) minValue = this->land[0][i].second;
   245   double compute_norm_of_landscape(
double i) {
   247     if (i < std::numeric_limits<double>::max()) {
   289   double find_max(
unsigned lambda)
const;
   320   std::vector<double>
vectorize(
int number_of_function)
 const {
   322     std::vector<double> v;
   323     if ((
size_t)number_of_function > this->land.
size()) {
   326     v.reserve(this->land[number_of_function].
size());
   327     for (
size_t i = 0; i != this->land[number_of_function].
size(); ++i) {
   328       v.push_back(this->land[number_of_function][i].second);
   346       std::clog <<
"to_average.size() : " << to_average.size() << std::endl;
   349     std::vector<Persistence_landscape*> nextLevelMerge(to_average.size());
   350     for (
size_t i = 0; i != to_average.size(); ++i) {
   351       nextLevelMerge[i] = to_average[i];
   353     bool is_this_first_level =
true;
   358     while (nextLevelMerge.size() != 1) {
   360         std::clog <<
"nextLevelMerge.size() : " << nextLevelMerge.size() << std::endl;
   362       std::vector<Persistence_landscape*> nextNextLevelMerge;
   363       nextNextLevelMerge.reserve(to_average.size());
   364       for (
size_t i = 0; i < nextLevelMerge.size(); i = i + 2) {
   366           std::clog <<
"i : " << i << std::endl;
   369         if (i + 1 != nextLevelMerge.size()) {
   370           (*l) = (*nextLevelMerge[i]) + (*nextLevelMerge[i + 1]);
   372           (*l) = *nextLevelMerge[i];
   374         nextNextLevelMerge.push_back(l);
   377         std::clog <<
"After this iteration \n";
   381       if (!is_this_first_level) {
   383         for (
size_t i = 0; i != nextLevelMerge.size(); ++i) {
   384           delete nextLevelMerge[i];
   387       is_this_first_level =
false;
   388       nextLevelMerge.swap(nextNextLevelMerge);
   390     (*this) = (*nextLevelMerge[0]);
   391     (*this) *= 1 /
static_cast<double>(to_average.size());
   401     if (power < std::numeric_limits<double>::max()) {
   423     std::pair<double, double> result;
   424     if (level < this->land.
size()) {
   426       double minn = this->compute_minimum();
   427       result = std::make_pair(minn, maxx);
   429       result = std::make_pair(0, 0);
   435   void plot(
const char* filename,
double xRangeBegin = std::numeric_limits<double>::max(),
   436             double xRangeEnd = std::numeric_limits<double>::max(),
   437             double yRangeBegin = std::numeric_limits<double>::max(),
   438             double yRangeEnd = std::numeric_limits<double>::max(),
int from = std::numeric_limits<int>::max(),
   439             int to = std::numeric_limits<int>::max());
   442   std::vector<std::vector<std::pair<double, double> > > land;
   443   size_t number_of_functions_for_vectorization;
   444   size_t number_of_functions_for_projections_to_reals;
   446   void construct_persistence_landscape_from_barcode(
const std::vector<std::pair<double, double> >& p,
   447                                                     size_t number_of_levels = std::numeric_limits<size_t>::max());
   449   void multiply_lanscape_by_real_number_overwrite(
double x);
   453   void set_up_numbers_of_functions_for_vectorization_and_projections_to_reals() {
   455     this->number_of_functions_for_vectorization = this->land.size();
   456     this->number_of_functions_for_projections_to_reals = this->land.size();
   461   std::vector<std::pair<double, double> > barcode;
   462   if (dimension < std::numeric_limits<double>::max()) {
   463     barcode = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
   465     barcode = read_persistence_intervals_in_one_dimension_from_file(filename);
   467   this->construct_persistence_landscape_from_barcode(barcode, number_of_levels);
   468   this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
   471 bool operatorEqualDbg =
false;
   473   if (this->land.size() != rhs.land.size()) {
   474     if (operatorEqualDbg) std::clog <<
"1\n";
   477   for (
size_t level = 0; level != this->land.size(); ++level) {
   478     if (this->land[level].
size() != rhs.land[level].size()) {
   479       if (operatorEqualDbg) std::clog <<
"this->land[level].size() : " << this->land[level].size() <<
"\n";
   480       if (operatorEqualDbg) std::clog <<
"rhs.land[level].size() : " << rhs.land[level].size() <<
"\n";
   481       if (operatorEqualDbg) std::clog <<
"2\n";
   484     for (
size_t i = 0; i != this->land[level].size(); ++i) {
   485       if (!(almost_equal(this->land[level][i].first, rhs.land[level][i].first) &&
   486             almost_equal(this->land[level][i].second, rhs.land[level][i].second))) {
   487         if (operatorEqualDbg)
   488           std::clog <<
"this->land[level][i] : " << this->land[level][i].first <<
" " << this->land[level][i].second
   490         if (operatorEqualDbg)
   491           std::clog <<
"rhs.land[level][i] : " << rhs.land[level][i].first <<
" " << rhs.land[level][i].second <<
"\n";
   492         if (operatorEqualDbg) std::clog <<
"3\n";
   501                                              size_t number_of_levels) {
   502   this->construct_persistence_landscape_from_barcode(p, number_of_levels);
   503   this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
   506 void Persistence_landscape::construct_persistence_landscape_from_barcode(
   507     const std::vector<std::pair<double, double> >& p,
   510     std::clog <<
"Persistence_landscape::Persistence_landscape( const std::vector< std::pair< double , double > >& p )"   515   std::vector<std::pair<double, double> > bars;
   516   bars.insert(bars.begin(), p.begin(), p.end());
   517   std::sort(bars.begin(), bars.end(), compare_points_sorting);
   520     std::clog <<
"Bars : \n";
   521     for (
size_t i = 0; i != bars.size(); ++i) {
   522       std::clog << bars[i].first <<
" " << bars[i].second <<
"\n";
   527   std::vector<std::pair<double, double> > characteristicPoints(p.size());
   528   for (
   529     characteristicPoints[i] =
   530         std::make_pair((bars[i].first + bars[i].second) / 2.0, (bars[i].second - bars[i].first) / 2.0);
   533   size_t number_of_levels_in_the_landscape = 0;
   534   while (!characteristicPoints.empty()) {
   536       for (
size_t i = 0; i != characteristicPoints.size(); ++i) {
   537         std::clog <<
"(" << characteristicPoints[i].first <<
" " << characteristicPoints[i].second <<
")\n";
   542     std::vector<std::pair<double, double> > lambda_n;
   543     lambda_n.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
   544     lambda_n.push_back(std::make_pair(minus_length(characteristicPoints[0]), 0));
   545     lambda_n.push_back(characteristicPoints[0]);
   548       std::clog <<
"1 Adding to lambda_n : (" << -std::numeric_limits<int>::max() <<
" " << 0 <<
") , ("   549                 << minus_length(characteristicPoints[0]) <<
" " << 0 <<
") , (" << characteristicPoints[0].first <<
" "   550                 << characteristicPoints[0].second <<
") \n";
   554     std::vector<std::pair<double, double> > newCharacteristicPoints;
   555     while (i < characteristicPoints.size()) {
   557       if ((minus_length(characteristicPoints[i]) >= minus_length(lambda_n[lambda_n.size() - 1])) &&
   558           (birth_plus_deaths(characteristicPoints[i]) > birth_plus_deaths(lambda_n[lambda_n.size() - 1]))) {
   559         if (minus_length(characteristicPoints[i]) < birth_plus_deaths(lambda_n[lambda_n.size() - 1])) {
   560           std::pair<double, double> point = std::make_pair(
   561               (minus_length(characteristicPoints[i]) + birth_plus_deaths(lambda_n[lambda_n.size() - 1])) / 2,
   562               (birth_plus_deaths(lambda_n[lambda_n.size() - 1]) - minus_length(characteristicPoints[i])) / 2);
   563           lambda_n.push_back(point);
   565             std::clog <<
"2 Adding to lambda_n : (" << point.first <<
" " << point.second <<
")\n";
   569             std::clog <<
"characteristicPoints[i+p] : " << characteristicPoints[i + p].first <<
" "   570                       << characteristicPoints[i + p].second <<
"\n";
   571             std::clog <<
"point : " << point.first <<
"\n";
   575           while ((i + p < characteristicPoints.size()) &&
   576                  (almost_equal(minus_length(point), minus_length(characteristicPoints[i + p]))) &&
   577                  (birth_plus_deaths(point) <= birth_plus_deaths(characteristicPoints[i + p]))) {
   578             newCharacteristicPoints.push_back(characteristicPoints[i + p]);
   580               std::clog <<
"3.5 Adding to newCharacteristicPoints : (" << characteristicPoints[i + p].first <<
" "   581                         << characteristicPoints[i + p].second <<
")\n";
   587           newCharacteristicPoints.push_back(point);
   589             std::clog <<
"4 Adding to newCharacteristicPoints : (" << point.first <<
")\n";
   592           while ((i + p < characteristicPoints.size()) &&
   593                  (minus_length(point) <= minus_length(characteristicPoints[i + p])) &&
   594                  (birth_plus_deaths(point) >= birth_plus_deaths(characteristicPoints[i + p]))) {
   595             newCharacteristicPoints.push_back(characteristicPoints[i + p]);
   597               std::clog <<
" "   598                         << characteristicPoints[i + p].second <<
"\n";
   599               std::clog <<
"\n";
   600               std::clog <<
"characteristicPoints[i+p] birth and death : " << minus_length(characteristicPoints[i + p])
   601                         <<
" , " << birth_plus_deaths(characteristicPoints[i + p]) <<
"\n";
   602               std::clog <<
"point birth and death : " << minus_length(point) <<
" , " << birth_plus_deaths(point)
   605               std::clog <<
"3 Adding to newCharacteristicPoints : (" << characteristicPoints[i + p].first <<
" "   606                         << characteristicPoints[i + p].second <<
")\n";
   613           lambda_n.push_back(std::make_pair(birth_plus_deaths(lambda_n[lambda_n.size() - 1]), 0));
   614           lambda_n.push_back(std::make_pair(minus_length(characteristicPoints[i]), 0));
   616             std::clog <<
"5 Adding to lambda_n : (" << birth_plus_deaths(lambda_n[lambda_n.size() - 1]) <<
" " << 0
   618             std::clog <<
"5 Adding to lambda_n : (" << minus_length(characteristicPoints[i]) <<
" " << 0 <<
")\n";
   621         lambda_n.push_back(characteristicPoints[i]);
   623           std::clog <<
"6 Adding to lambda_n : (" << characteristicPoints[i].first <<
" "   624                     << characteristicPoints[i].second <<
")\n";
   627         newCharacteristicPoints.push_back(characteristicPoints[i]);
   629           std::clog <<
"7 Adding to newCharacteristicPoints : (" << characteristicPoints[i].first <<
" "   630                     << characteristicPoints[i].second <<
")\n";
   635     lambda_n.push_back(std::make_pair(birth_plus_deaths(lambda_n[lambda_n.size() - 1]), 0));
   636     lambda_n.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
   638     characteristicPoints = newCharacteristicPoints;
   640     lambda_n.erase(std::unique(lambda_n.begin(), lambda_n.end()), lambda_n.end());
   641     this->land.push_back(lambda_n);
   643     ++number_of_levels_in_the_landscape;
   644     if (number_of_levels == number_of_levels_in_the_landscape) {
   652   if (this->land.size() < lambda)
return 0;
   653   double maximum = -std::numeric_limits<int>::max();
   654   for (
size_t i = 0; i != this->land[lambda].size(); ++i) {
   655     if (this->land[lambda][i].second > maximum) maximum = this->land[lambda][i].second;
   662   for (
size_t i = 0; i != this->land.size(); ++i) {
   663     for (
size_t nr = 2; nr != this->land[i].size() - 1; ++nr) {
   665       result += 0.5 * (this->land[i][nr].first - this->land[i][nr - 1].first) *
   666                 (this->land[i][nr].second + this->land[i][nr - 1].second);
   674   if (level >= this->land.size()) {
   679   if (level < 0)
return 0;
   681   for (
size_t nr = 2; nr != this->land[level].size() - 1; ++nr) {
   683     result += 0.5 * (this->land[level][nr].first - this->land[level][nr - 1].first) *
   684               (this->land[level][nr].second + this->land[level][nr - 1].second);
   693   for (
   694     for (
   695       if (dbg) std::clog <<
"nr : " << nr <<
"\n";
   698       std::pair<double, double> coef = compute_parameters_of_a_line(this->land[i][nr], this->land[i][nr - 1]);
   699       double a = coef.first;
   700       double b = coef.second;
   703         std::clog <<
"(" << this->land[i][nr].first <<
"," << this->land[i][nr].second <<
") , "   704                   << this->land[i][nr - 1].first <<
")" << std::endl;
   705       if (this->land[i][nr].first == this->land[i][nr - 1].first)
continue;
   707         result += 1 / (a * (p + 1)) *
   708                   (pow((a * this->land[i][nr].first + b), p + 1) - pow((a * this->land[i][nr - 1].first + b), p + 1));
   710         result += (this->land[i][nr].first - this->land[i][nr - 1].first) * (pow(this->land[i][nr].second, p));
   713         std::clog <<
"a : " << a <<
" , b : " << b << std::endl;
   714         std::clog <<
"result : " << result << std::endl;
   723   bool compute_value_at_a_given_pointDbg =
false;
   725   if (level >= this->land.size())
return 0;
   729   unsigned coordBegin = 1;
   730   unsigned coordEnd = this->land[level].size() - 2;
   732   if (compute_value_at_a_given_pointDbg) {
   733     std::clog <<
"Here \n";
   734     std::clog <<
"x : " << x <<
"\n";
   735     std::clog <<
"this->land[level][coordBegin].first : " << this->land[level][coordBegin].first <<
"\n";
   736     std::clog <<
"this->land[level][coordEnd].first : " << this->land[level][coordEnd].first <<
"\n";
   740   if (x <= this->land[level][coordBegin].first)
return 0;
   741   if (x >= this->land[level][coordEnd].first)
return 0;
   743   if (compute_value_at_a_given_pointDbg) std::clog <<
"Entering to the while loop \n";
   745   while (coordBegin + 1 != coordEnd) {
   746     if (compute_value_at_a_given_pointDbg) {
   747       std::clog <<
"coordBegin : " << coordBegin <<
"\n";
   748       std::clog <<
"coordEnd : " << coordEnd <<
"\n";
   749       std::clog <<
"\n";
   750       std::clog <<
"\n";
   753     unsigned newCord = (unsigned)floor((coordEnd + coordBegin) / 2.0);
   755     if (compute_value_at_a_given_pointDbg) {
   756       std::clog <<
"newCord : " << newCord <<
"\n";
   757       std::clog <<
"this->land[level][newCord].first : " << this->land[level][newCord].first <<
"\n";
   761     if (this->land[level][newCord].first <= x) {
   762       coordBegin = newCord;
   763       if (this->land[level][newCord].first == x)
return this->land[level][newCord].second;
   769   if (compute_value_at_a_given_pointDbg) {
   770     std::clog <<
"x : " << x <<
" is between : " << this->land[level][coordBegin].first <<
" a  "   771               << this->land[level][coordEnd].first <<
"\n";
   772     std::clog <<
"the y coords are : " << this->land[level][coordBegin].second <<
" a  "   773               << this->land[level][coordEnd].second <<
"\n";
   774     std::clog <<
"\n";
   775     std::clog <<
"\n";
   778   return function_value(this->land[level][coordBegin], this->land[level][coordEnd], x);
   782   for (
size_t level = 0; level != land.land.size(); ++level) {
   783     out <<
"Lambda_" << level <<
":" << std::endl;
   784     for (
size_t i = 0; i != land.land[level].size(); ++i) {
   785       if (land.land[level][i].first == -std::numeric_limits<int>::max()) {
   788         if (land.land[level][i].first == std::numeric_limits<int>::max()) {
   791           out << land.land[level][i].first;
   794       out <<
" , " << land.land[level][i].second << std::endl;
   800 void Persistence_landscape::multiply_lanscape_by_real_number_overwrite(
double x) {
   801   for (
size_t dim = 0; dim != this->land.size(); ++dim) {
   802     for (
size_t i = 0; i != this->land[dim].size(); ++i) {
   803       this->land[dim][i].second *= x;
   811   for (
   813       std::clog <<
"level: " << level << std::endl;
   815     std::vector<std::pair<double, double> > lambda_n;
   816     lambda_n.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
   817     for (
size_t i = 1; i != this->land[level].size(); ++i) {
   819         std::clog <<
"this->land[" << level <<
"][" << i <<
"] : " << this->land[level][i].first <<
" "   820                   << this->land[level][i].second << std::endl;
   824       if ((this->land[level][i - 1].second) * (this->land[level][i].second) < 0) {
   826             find_zero_of_a_line_segment_between_those_two_points(this->land[level][i - 1], this->land[level][i]);
   828         lambda_n.push_back(std::make_pair(zero, 0));
   829         lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
   831           std::clog <<
"Adding pair : (" << zero <<
",0)" << std::endl;
   832           std::clog <<
"In the same step adding pair : (" << this->land[level][i].first <<
","   833                     << fabs(this->land[level][i].second) <<
") " << std::endl;
   837         lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
   839           std::clog <<
"Adding pair : (" << this->land[level][i].first <<
"," << fabs(this->land[level][i].second)
   840                     <<
") " << std::endl;
   845     result.land.push_back(lambda_n);
   852   for (
   854       std::clog <<
   856     std::vector<std::pair<double, double> > lambda_n;
   857     lambda_n.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
   858     for (
   860         std::clog <<
"][" << i <<
" "   861                   << this->land[level][i].second << std::endl;
   865       if ((this->land[level][i - 1].second) * (this->land[level][i].second) < 0) {
   867             find_zero_of_a_line_segment_between_those_two_points(this->land[level][i - 1], this->land[level][i]);
   869         lambda_n.push_back(std::make_pair(zero, 0));
   870         lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
   872           std::clog <<
",0)" << std::endl;
   873           std::clog <<
","   874                     << fabs(this->land[level][i].second) <<
") " << std::endl;
   878         lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
   880           std::clog <<
   881                     <<
") " << std::endl;
   886     result->land.push_back(lambda_n);
   891 Persistence_landscape Persistence_landscape::multiply_lanscape_by_real_number_not_overwrite(
double x)
 const {
   892   std::vector<std::vector<std::pair<double, double> > > result(this->land.size());
   893   for (
   894     std::vector<std::pair<double, double> > lambda_dim(this->land[dim].
size());
   895     for (
   896       lambda_dim[i] = std::make_pair(this->land[dim][i].first, x * this->land[dim][i].second);
   898     result[dim] = lambda_dim;
   903   res.land.swap(result);
   909   write.open(filename);
   910   for (
   911     write <<
"#lambda_" << dim << std::endl;
   912     for (
size_t i = 1; i != this->land[dim].size() - 1; ++i) {
   913       write << this->land[dim][i].first <<
"  " << this->land[dim][i].second << std::endl;
   928     std::cerr <<
"The file : " << filename <<
" do not exist. The program will now terminate \n";
   929     throw "The persistence landscape file do not exist. The program will now terminate \n";
   933   std::vector<std::pair<double, double> > landscapeAtThisLevel;
   935   bool isThisAFirsLine =
true;
   938     if (!(line.length() == 0 || line[0] ==
   939       std::stringstream lineSS;
   944       landscapeAtThisLevel.push_back(std::make_pair(beginn, endd));
   946         std::clog <<
"Reading a point : " << beginn <<
" , " << endd << std::endl;
   950         std::clog <<
"IGNORE LINE\n";
   953       if (!isThisAFirsLine) {
   954         landscapeAtThisLevel.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
   955         this->land.push_back(landscapeAtThisLevel);
   956         std::vector<std::pair<double, double> > newLevelOdLandscape;
   957         landscapeAtThisLevel.swap(newLevelOdLandscape);
   959       landscapeAtThisLevel.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
   960       isThisAFirsLine =
false;
   963   if (landscapeAtThisLevel.size() > 1) {
   966     landscapeAtThisLevel.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
   967     this->land.push_back(landscapeAtThisLevel);
   973 template <
typename T>
   976   bool operation_on_pair_of_landscapesDBG =
false;
   977   if (operation_on_pair_of_landscapesDBG) {
   978     std::clog <<
"operation_on_pair_of_landscapes\n";
   982   std::vector<std::vector<std::pair<double, double> > > land(std::max(land1.land.size(), land2.land.size()));
   986   if (operation_on_pair_of_landscapesDBG) {
   987     for (
size_t i = 0; i != std::min(land1.land.size(), land2.land.size()); ++i) {
   988       std::clog <<
"land1.land[" << i <<
"].size() : " << land1.land[i].size() << std::endl;
   989       std::clog <<
"land2.land[" << i <<
"].size() : " << land2.land[i].size() << std::endl;
   994   for (
   995     std::vector<std::pair<double, double> > lambda_n;
   998     while ((p + 1 < land1.land[i].size()) && (q + 1 < land2.land[i].size())) {
   999       if (operation_on_pair_of_landscapesDBG) {
  1000         std::clog <<
"p : " << p <<
"\n";
  1001         std::clog <<
"q : " << q <<
"\n";
  1002         std::clog <<
"land1.land.size() : " << land1.land.size() << std::endl;
  1003         std::clog <<
"land2.land.size() : " << land2.land.size() << std::endl;
  1004         std::clog <<
  1005         std::clog <<
  1006         std::clog <<
"land1.land[i][p].first : " << land1.land[i][p].first <<
"\n";
  1007         std::clog <<
"land2.land[i][q].first : " << land2.land[i][q].first <<
"\n";
  1010       if (land1.land[i][p].first < land2.land[i][q].first) {
  1011         if (operation_on_pair_of_landscapesDBG) {
  1012           std::clog <<
"first \n";
  1013           std::clog <<
" function_value(land2.land[i][q-1],land2.land[i][q],land1.land[i][p].first) : "  1014                     << function_value(land2.land[i][q - 1], land2.land[i][q], land1.land[i][p].first) <<
"\n";
  1017             std::make_pair(land1.land[i][p].first,
  1018                            oper(static_cast<double>(land1.land[i][p].second),
  1019                                 function_value(land2.land[i][q - 1], land2.land[i][q], land1.land[i][p].first))));
  1023       if (land1.land[i][p].first > land2.land[i][q].first) {
  1024         if (operation_on_pair_of_landscapesDBG) {
  1025           std::clog <<
"Second \n";
  1026           std::clog <<
"function_value(" << land1.land[i][p - 1].first <<
" " << land1.land[i][p - 1].second <<
" ,"  1027                     << land1.land[i][p].first <<
" " << land1.land[i][p].second <<
", " << land2.land[i][q].first
  1028                     <<
" ) : " << function_value(land1.land[i][p - 1], land1.land[i][p - 1], land2.land[i][q].first)
  1030           std::clog <<
"oper( " << function_value(land1.land[i][p], land1.land[i][p - 1], land2.land[i][q].first) <<
","  1031                     << land2.land[i][q].second <<
" : "  1032                     << oper(land2.land[i][q].second,
  1033                             function_value(land1.land[i][p], land1.land[i][p - 1], land2.land[i][q].first))
  1036         lambda_n.push_back(std::make_pair(
  1037             land2.land[i][q].first, oper(function_value(land1.land[i][p], land1.land[i][p - 1], land2.land[i][q].first),
  1038                                          land2.land[i][q].second)));
  1042       if (land1.land[i][p].first == land2.land[i][q].first) {
  1043         if (operation_on_pair_of_landscapesDBG) std::clog <<
"Third \n";
  1045             std::make_pair(land2.land[i][q].first, oper(land1.land[i][p].second, land2.land[i][q].second)));
  1049       if (operation_on_pair_of_landscapesDBG) {
  1050         std::clog <<
"Next iteration \n";
  1053     while ((p + 1 < land1.land[i].size()) && (q + 1 >= land2.land[i].size())) {
  1054       if (operation_on_pair_of_landscapesDBG) {
  1055         std::clog <<
"New point : " << land1.land[i][p].first
  1056                   <<
"  oper(land1.land[i][p].second,0) : " << oper(land1.land[i][p].second, 0) << std::endl;
  1058       lambda_n.push_back(std::make_pair(land1.land[i][p].first, oper(land1.land[i][p].second, 0)));
  1061     while ((p + 1 >= land1.land[i].size()) && (q + 1 < land2.land[i].size())) {
  1062       if (operation_on_pair_of_landscapesDBG) {
  1063         std::clog <<
"New point : " << land2.land[i][q].first
  1064                   <<
" oper(0,land2.land[i][q].second) : " << oper(0, land2.land[i][q].second) << std::endl;
  1066       lambda_n.push_back(std::make_pair(land2.land[i][q].first, oper(0, land2.land[i][q].second)));
  1069     lambda_n.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
  1072     result.land[i].swap(lambda_n);
  1074   if (land1.land.size() > std::min(land1.land.size(), land2.land.size())) {
  1075     if (operation_on_pair_of_landscapesDBG) {
  1076       std::clog <<
"land1.land.size() > std::min( land1.land.size() , land2.land.size() )" << std::endl;
  1078     for (
size_t i = std::min(land1.land.size(), land2.land.size()); i != std::max(land1.land.size(), land2.land.size());
  1080       std::vector<std::pair<double, double> > lambda_n(land1.land[i]);
  1081       for (
size_t nr = 0; nr != land1.land[i].size(); ++nr) {
  1082         lambda_n[nr] = std::make_pair(land1.land[i][nr].first, oper(land1.land[i][nr].second, 0));
  1086       result.land[i].swap(lambda_n);
  1089   if (land2.land.size() > std::min(land1.land.size(), land2.land.size())) {
  1090     if (operation_on_pair_of_landscapesDBG) {
  1091       std::clog <<
"( land2.land.size() > std::min( land1.land.size() , land2.land.size() ) ) " << std::endl;
  1093     for (
  1095       std::vector<std::pair<double, double> > lambda_n(land2.land[i]);
  1096       for (
size_t nr = 0; nr != land2.land[i].size(); ++nr) {
  1097         lambda_n[nr] = std::make_pair(land2.land[i][nr].first, oper(0, land2.land[i][nr].second));
  1101       result.land[i].swap(lambda_n);
  1104   if (operation_on_pair_of_landscapesDBG) {
  1105     std::clog <<
"operation_on_pair_of_landscapes END\n";
  1113   if (dbg) std::clog <<
" compute_maximal_distance_non_symmetric \n";
  1116   size_t minimalNumberOfLevels = std::min(pl1.land.size(), pl2.land.size());
  1117   for (
size_t level = 0; level != minimalNumberOfLevels; ++level) {
  1119       std::clog <<
"Level : " << level << std::endl;
  1120       std::clog <<
"PL1 : \n";
  1121       for (
size_t i = 0; i != pl1.land[level].size(); ++i) {
  1122         std::clog <<
"(" << pl1.land[level][i].first <<
"," << pl1.land[level][i].second <<
") \n";
  1124       std::clog <<
"PL2 : \n";
  1125       for (
size_t i = 0; i != pl2.land[level].size(); ++i) {
  1126         std::clog <<
"(" << pl2.land[level][i].first <<
"," << pl2.land[level][i].second <<
") \n";
  1133     for (
size_t i = 1; i != pl1.land[level].size() - 1; ++i) {
  1135         if ((pl1.land[level][i].first >= pl2.land[level][p2Count].first) &&
  1136             (pl1.land[level][i].first <= pl2.land[level][p2Count + 1].first))
  1141           fabs(function_value(pl2.land[level][p2Count], pl2.land[level][p2Count + 1], pl1.land[level][i].first) -
  1142                pl1.land[level][i].second);
  1143       if (maxDist <= val) maxDist = val;
  1146         std::clog << pl1.land[level][i].first <<
"in [" << pl2.land[level][p2Count].first <<
","  1147                   << pl2.land[level][p2Count + 1].first <<
"] \n";
  1148         std::clog <<
"pl1[level][i].second : " << pl1.land[level][i].second << std::endl;
  1149         std::clog <<
"function_value( pl2[level][p2Count] , pl2[level][p2Count+1] , pl1[level][i].first ) : "  1150                   << function_value(pl2.land[level][p2Count], pl2.land[level][p2Count + 1], pl1.land[level][i].first)
  1152         std::clog <<
"val : " << val << std::endl;
  1158   if (dbg) std::clog <<
"minimalNumberOfLevels : " << minimalNumberOfLevels << std::endl;
  1160   if (minimalNumberOfLevels < pl1.land.size()) {
  1161     for (
size_t level = minimalNumberOfLevels; level != pl1.land.size(); ++level) {
  1162       for (
  1163         if (dbg) std::clog <<
  1164         if (maxDist < pl1.land[level][i].second) maxDist = pl1.land[level][i].second;
  1184     std::clog <<
"Abs of difference ; " << lan << std::endl;
  1188   if (p < std::numeric_limits<double>::max()) {
  1192       if (dbg) std::clog <<
"Power != 1, compute integral to the power p\n";
  1195       if (dbg) std::clog <<
"Power = 1, compute integral \n";
  1199     return pow(result, 1.0 / p);
  1202     if (dbg) std::clog <<
"Power = infty, compute maximum \n";
  1209   return std::max(compute_maximal_distance_non_symmetric(first, second),
  1210                   compute_maximal_distance_non_symmetric(second, first));
  1213 bool comparePairsForMerging(std::pair<double, unsigned> first, std::pair<double, unsigned> second) {
  1214   return (first.first < second.first);
  1221   for (
size_t level = 0; level != std::min(l1.
size(), l2.
size()); ++level) {
  1223       std::clog <<
"Computing inner product for a level : " << level << std::endl;
  1226     auto&& l1_land_level = l1.land[level];
  1227     auto&& l2_land_level = l2.land[level];
  1229     if (l1_land_level.size() * l2_land_level.size() == 0)
continue;
  1232     double x1 = -std::numeric_limits<int>::max();
  1234     if (l1_land_level[1].first < l2_land_level[1].first) {
  1235       x2 = l1_land_level[1].first;
  1237       x2 = l2_land_level[1].first;
  1244     while ((l1It < l1_land_level.size() - 1) && (l2It < l2_land_level.size() - 1)) {
  1249       if (l1_land_level[l1It + 1].first != l1_land_level[l1It].first) {
  1250         a = (l1_land_level[l1It + 1].second - l1_land_level[l1It].second) /
  1251             (l1_land_level[l1It + 1].first - l1_land_level[l1It].first);
  1255       b = l1_land_level[l1It].second - a * l1_land_level[l1It].first;
  1256       if (l2_land_level[l2It + 1].first != l2_land_level[l2It].first) {
  1257         c = (l2_land_level[l2It + 1].second - l2_land_level[l2It].second) /
  1258             (l2_land_level[l2It + 1].first - l2_land_level[l2It].first);
  1262       d = l2_land_level[l2It].second - c * l2_land_level[l2It].first;
  1264       double contributionFromThisPart = (a * c * x2 * x2 * x2 / 3 + (a * d + b * c) * x2 * x2 / 2 + b * d * x2) -
  1265                                         (a * c * x1 * x1 * x1 / 3 + (a * d + b * c) * x1 * x1 / 2 + b * d * x1);
  1267       result += contributionFromThisPart;
  1270         std::clog <<
"[l1_land_level[l1It].first,l1_land_level[l1It+1].first] : " << l1_land_level[l1It].first
  1271                   <<
" , " << l1_land_level[l1It + 1].first << std::endl;
  1272         std::clog <<
"[l2_land_level[l2It].first,l2_land_level[l2It+1].first] : " << l2_land_level[l2It].first
  1273                   <<
" , " << l2_land_level[l2It + 1].first << std::endl;
  1274         std::clog <<
"a : " << a <<
", b : " << b <<
" , c: " << c <<
", d : " << d << std::endl;
  1275         std::clog <<
"x1 : " << x1 <<
" , x2 : " << x2 << std::endl;
  1276         std::clog <<
"contributionFromThisPart : " << contributionFromThisPart << std::endl;
  1277         std::clog <<
  1288       if (x2 == l1_land_level[l1It + 1].first) {
  1289         if (x2 == l2_land_level[l2It + 1].first) {
  1293             std::clog <<
"Incrementing both \n";
  1297             std::clog <<
"Incrementing first \n";
  1305           std::clog <<
"Incrementing second \n";
  1309       if ( l1It + 1 >= l1_land_level.size()  )
break;
  1310       if ( l2It + 1 >= l2_land_level.size()  )
break;
  1314       if (l1_land_level[l1It + 1].first < l2_land_level[l2It + 1].first) {
  1315         x2 = l1_land_level[l1It + 1].first;
  1317         x2 = l2_land_level[l2It + 1].first;
  1324 void Persistence_landscape::plot(
double xRangeBegin,
double xRangeEnd,
double yRangeBegin,
  1325                                  double yRangeEnd,
int from,
int to) {
  1329   std::ostringstream gnuplot_script;
  1330   gnuplot_script << filename <<
"_GnuplotScript";
  1331   out.open(gnuplot_script.str().c_str());
  1333   if ((xRangeBegin != std::numeric_limits<double>::max()) || (xRangeEnd != std::numeric_limits<double>::max()) ||
  1334       (yRangeBegin != std::numeric_limits<double>::max()) || (yRangeEnd != std::numeric_limits<double>::max())) {
  1335     out <<
"set xrange [" << xRangeBegin <<
" : " << xRangeEnd <<
"]" << std::endl;
  1336     out <<
"set yrange [" << yRangeBegin <<
" : " << yRangeEnd <<
"]" << std::endl;
  1339   if (from == std::numeric_limits<int>::max()) {
  1342   if (to == std::numeric_limits<int>::max()) {
  1343     to = this->land.size();
  1347   for (
size_t lambda = std::min((
size_t)from, this->land.size()); lambda != std::min((
size_t)to, this->land.size());
  1350     out <<
"     '-' using 1:2 notitle with lp";
  1351     if (lambda + 1 != std::min((
size_t)to, this->land.size())) {
  1357   for (
  1359     for (
size_t i = 1; i != this->land[lambda].size() - 1; ++i) {
  1360       out << this->land[lambda][i].first <<
" " << this->land[lambda][i].second << std::endl;
  1362     out <<
"EOF" << std::endl;
  1364   std::clog <<
"To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'"  1365             << gnuplot_script.str().c_str() <<
"\'\"" << std::endl;
  1371 #endif  // PERSISTENCE_LANDSCAPE_H_ std::pair< double, double > get_y_range(size_t level=0) const
Definition: Persistence_landscape.h:422
Persistence_landscape operator+=(const Persistence_landscape &rhs)
Definition: Persistence_landscape.h:173
friend std::ostream & operator<<(std::ostream &out, Persistence_landscape &land)
Definition: Persistence_landscape.h:781
bool operator==(const Persistence_landscape &rhs) const
Definition: Persistence_landscape.h:472
friend Persistence_landscape subtract_two_landscapes(const Persistence_landscape &land1, const Persistence_landscape &land2)
Definition: Persistence_landscape.h:137
size_t size() const
Definition: Persistence_landscape.h:284
double operator()(unsigned level, double x) const
Definition: Persistence_landscape.h:257
Persistence_landscape()
Definition: Persistence_landscape.h:65
void print_to_file(const char *filename) const
Definition: Persistence_landscape.h:907
double compute_integral_of_a_level_of_a_landscape(size_t level) const
Definition: Persistence_landscape.h:672
void load_landscape_from_file(const char *filename)
Definition: Persistence_landscape.h:919
size_t number_of_vectorize_functions() const
Definition: Persistence_landscape.h:336
Persistence_landscape abs()
Definition: Persistence_landscape.h:809
size_t number_of_projections_to_R() const
Definition: Persistence_landscape.h:314
double distance(const Persistence_landscape &second, double power=1) const
Definition: Persistence_landscape.h:400
Definition: SimplicialComplexForAlpha.h:14
A class implementing persistence landscapes data structures.
Definition: Persistence_landscape.h:60
void compute_average(const std::vector< Persistence_landscape *> &to_average)
Definition: Persistence_landscape.h:342
double find_max(unsigned lambda) const
Definition: Persistence_landscape.h:651
friend double compute_distance_of_landscapes(const Persistence_landscape &first, const Persistence_landscape &second, double p)
Definition: Persistence_landscape.h:1171
double compute_scalar_product(const Persistence_landscape &second) const
Definition: Persistence_landscape.h:413
double project_to_R(int number_of_function) const
Definition: Persistence_landscape.h:306
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_landscape.h:320
bool operator!=(const Persistence_landscape &rhs) const
Definition: Persistence_landscape.h:212
Persistence_landscape operator/=(double x)
Definition: Persistence_landscape.h:198
friend Persistence_landscape operator+(const Persistence_landscape &first, const Persistence_landscape &second)
Definition: Persistence_landscape.h:145
friend Persistence_landscape operator*(double con, const Persistence_landscape &first)
Definition: Persistence_landscape.h:166
double compute_integral_of_landscape() const
Definition: Persistence_landscape.h:660
Persistence_landscape operator*=(double x)
Definition: Persistence_landscape.h:190
friend double compute_inner_product(const Persistence_landscape &l1, const Persistence_landscape &l2)
Definition: Persistence_landscape.h:1217
Persistence_landscape operator-=(const Persistence_landscape &rhs)
Definition: Persistence_landscape.h:181
friend Persistence_landscape add_two_landscapes(const Persistence_landscape &land1, const Persistence_landscape &land2)
Definition: Persistence_landscape.h:129
double compute_value_at_a_given_point(unsigned level, double x) const
Definition: Persistence_landscape.h:722
double compute_maximum() const
Definition: Persistence_landscape.h:217
friend double compute_max_norm_distance_of_landscapes(const Persistence_landscape &first, const Persistence_landscape &second)
Definition: Persistence_landscape.h:1207
friend Persistence_landscape operator*(const Persistence_landscape &first, double con)
Definition: Persistence_landscape.h:159
friend Persistence_landscape operator-(const Persistence_landscape &first, const Persistence_landscape &second)
Definition: Persistence_landscape.h:152
