13 #ifndef PERSISTENCE_INTERVALS_H_    14 #define PERSISTENCE_INTERVALS_H_    17 #include <gudhi/read_persistence_from_file.h>    31 namespace Persistence_representations {
    47   Persistence_intervals(
const char* filename,
unsigned dimension = std::numeric_limits<unsigned>::max());
    60     double min_ = std::numeric_limits<int>::max();
    61     double max_ = -std::numeric_limits<int>::max();
    62     for (
size_t i = 0; i != this->intervals.size(); ++i) {
    63       if (this->intervals[i].first < min_) min_ = this->intervals[i].first;
    64       if (this->intervals[i].second > max_) max_ = this->intervals[i].second;
    66     return std::make_pair(min_, max_);
    73     double min_ = std::numeric_limits<int>::max();
    74     double max_ = -std::numeric_limits<int>::max();
    75     for (
    76       if (this->intervals[i].second < min_) min_ = this->intervals[i].second;
    77       if (this->intervals[i].second > max_) max_ = this->intervals[i].second;
    79     return std::make_pair(min_, max_);
    92   std::vector<std::pair<double, double> >
dominant_intervals(
size_t where_to_cut = 100)
const;
   124        size_t number_of_bins = 10)
const;
   139   std::vector<double>
k_n_n(
size_t k,
size_t where_to_cut = 10)
const;
   145     for (
size_t i = 0; i != intervals.intervals.size(); ++i) {
   146       out << intervals.intervals[i].first <<
" " << intervals.intervals[i].second << std::endl;
   154   void plot(
double min_x = std::numeric_limits<double>::max(),
   155             double max_x = std::numeric_limits<double>::max(),
double min_y = std::numeric_limits<double>::max(),
   156             double max_y = std::numeric_limits<double>::max())
 const {
   160     std::stringstream gnuplot_script;
   161     gnuplot_script << filename <<
"_GnuplotScript";
   163     out.open(gnuplot_script.str().c_str());
   165     std::pair<double, double> min_max_values = this->
get_x_range();
   166     if (min_x == max_x) {
   167       out <<
"set xrange [" << min_max_values.first - 0.1 * (min_max_values.second - min_max_values.first) <<
" : "   168           << min_max_values.second + 0.1 * (min_max_values.second - min_max_values.first) <<
" ]" << std::endl;
   169       out <<
"set yrange [" << min_max_values.first - 0.1 * (min_max_values.second - min_max_values.first) <<
" : "   170           << min_max_values.second + 0.1 * (min_max_values.second - min_max_values.first) <<
" ]" << std::endl;
   172       out <<
"set xrange [" << min_x <<
" : " << max_x <<
" ]" << std::endl;
   173       out <<
"set yrange [" << min_y <<
" : " << max_y <<
" ]" << std::endl;
   175     out <<
"plot '-' using 1:2 notitle \"" << filename <<
"\", \\" << std::endl;
   176     out <<
"     '-' using 1:2 notitle with lp" << std::endl;
   177     for (
   178       out << this->intervals[i].first <<
" " << this->intervals[i].second << std::endl;
   180     out <<
"EOF" << std::endl;
   181     out << min_max_values.first - 0.1 * (min_max_values.second - min_max_values.first) <<
" "   182         << min_max_values.first - 0.1 * (min_max_values.second - min_max_values.first) << std::endl;
   183     out << min_max_values.second + 0.1 * (min_max_values.second - min_max_values.first) <<
" "   184         << min_max_values.second + 0.1 * (min_max_values.second - min_max_values.first) << std::endl;
   188     std::clog <<
"To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'"   189               << gnuplot_script.str().c_str() <<
"\'\"" << std::endl;
   195   size_t size()
 const {
return this->intervals.size(); }
   201   inline std::pair<double, double>
operator[](
size_t i)
 const {
   202     if (i >= this->intervals.size())
throw(
"Index out of range! Operator [], one_d_gaussians class\n");
   203     return this->intervals[i];
   226   std::vector<double>
vectorize(
int number_of_function)
 const {
   238   std::vector<std::pair<double, double> > output_for_visualization() {
return this->intervals; }
   241   void set_up_numbers_of_functions_for_vectorization_and_projections_to_reals() {
   243     this->number_of_functions_for_vectorization = this->intervals.size();
   244     this->number_of_functions_for_projections_to_reals = 1;
   247   std::vector<std::pair<double, double> > intervals;
   248   size_t number_of_functions_for_vectorization;
   249   size_t number_of_functions_for_projections_to_reals;
   253   if (dimension == std::numeric_limits<unsigned>::max()) {
   254     this->intervals = read_persistence_intervals_in_one_dimension_from_file(filename);
   256     this->intervals = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
   258   this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
   262     : intervals(intervals_) {
   263   this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
   267   std::vector<double> result(this->intervals.size());
   268   for (
   269     result[i] = this->intervals[i].second - this->intervals[i].first;
   271   std::sort(result.begin(), result.end(), std::greater<double>());
   273   result.resize(std::min(where_to_cut, result.size()));
   277 bool compare(
const std::pair<size_t, double>& first,
const std::pair<size_t, double>& second) {
   278   return first.second > second.second;
   283   std::vector<std::pair<size_t, double> > position_length_vector(this->intervals.size());
   284   for (
   285     position_length_vector[i] = std::make_pair(i, this->intervals[i].second - this->intervals[i].first);
   288   std::sort(position_length_vector.begin(), position_length_vector.end(), compare);
   290   std::vector<std::pair<double, double> > result;
   291   result.reserve(std::min(where_to_cut, position_length_vector.size()));
   293   for (
size_t i = 0; i != std::min(where_to_cut, position_length_vector.size()); ++i) {
   294     result.push_back(this->intervals[position_length_vector[i].first]);
   296       std::clog <<
"Position : " << position_length_vector[i].first <<
" length : " << position_length_vector[i].second
   306   if (dbg) std::clog <<
"this->intervals.size() : " << this->intervals.size() << std::endl;
   308   double lengthOfLongest = 0;
   309   for (
   310     if ((this->intervals[i].second - this->intervals[i].first) > lengthOfLongest) {
   311       lengthOfLongest = this->intervals[i].second - this->intervals[i].first;
   316     std::clog <<
"lengthOfLongest : " << lengthOfLongest << std::endl;
   320   std::vector<size_t> result(number_of_bins + 1, 0);
   323   for (
   325     double relative_length_of_this_interval = (this->intervals[i].second - this->intervals[i].first) / lengthOfLongest;
   328     size_t position = (size_t)(relative_length_of_this_interval * number_of_bins);
   333       std::clog <<
"i : " << i << std::endl;
   334       std::clog <<
"Interval : [" << this->intervals[i].first <<
" , " << this->intervals[i].second <<
" ] \n";
   335       std::clog <<
"relative_length_of_this_interval : " << relative_length_of_this_interval << std::endl;
   336       std::clog <<
"position : " << position << std::endl;
   341   result[number_of_bins-1]+=result[number_of_bins];
   342   result.resize(number_of_bins);
   345     for (
size_t i = 0; i != result.size(); ++i) std::clog << result[i] << std::endl;
   352   std::vector<size_t> result(histogram.size());
   355   for (
size_t i = 0; i != histogram.size(); ++i) {
   363        size_t number_of_bins)
 const {
   366   std::vector<double> result(number_of_bins);
   367   std::fill(result.begin(), result.end(), 0);
   369   for (
   371       std::clog <<
"Interval : " << this->intervals[i].first <<
" , " << this->intervals[i].second << std::endl;
   375     if (this->intervals[i].first < x_min) beginIt = 0;
   376     if (this->intervals[i].first >= x_max) beginIt = result.size();
   377     if ((this->intervals[i].first > x_min) && (this->intervals[i].first < x_max)) {
   378       beginIt = number_of_bins * (this->intervals[i].first - x_min) / (x_max - x_min);
   382     if (this->intervals[i].second < x_min) endIt = 0;
   383     if (this->intervals[i].second >= x_max) endIt = result.size();
   384     if ((this->intervals[i].second > x_min) && (this->intervals[i].second < x_max)) {
   385       endIt = number_of_bins * (this->intervals[i].second - x_min) / (x_max - x_min);
   388     if (beginIt > endIt) {
   393       std::clog <<
"beginIt : " << beginIt << std::endl;
   394       std::clog <<
"endIt : " << endIt << std::endl;
   397     for (
size_t pos = beginIt; pos != endIt; ++pos) {
   398       result[pos] += ((x_max - x_min) / static_cast<double>(number_of_bins)) *
   399                      (this->intervals[i].second - this->intervals[i].first);
   402       std::clog <<
"Result at this stage \n";
   403       for (
size_t aa = 0; aa != result.size(); ++aa) {
   404         std::clog << result[aa] <<
   406       std::clog << std::endl;
   413        size_t number_of_bins)
 const {
   415   std::vector<double> result(intsOfBars.size());
   417   for (
size_t i = 0; i != intsOfBars.size(); ++i) {
   418     sum += intsOfBars[i];
   424 template <
typename T>
   425 bool compare_first_element_of_pair(
const std::pair<T, bool>& f,
const std::pair<T, bool>& s) {
   426   return (f.first < s.first);
   430   std::vector<std::pair<double, bool> > places_where_pbs_change(2 * this->intervals.size());
   432   for (
   433     places_where_pbs_change[2 * i] = std::make_pair(this->intervals[i].first,
true);
   434     places_where_pbs_change[2 * i + 1] = std::make_pair(this->intervals[i].second,
false);
   437   std::sort(places_where_pbs_change.begin(), places_where_pbs_change.end(), compare_first_element_of_pair<double>);
   439   std::vector<std::pair<double, size_t> > pbns(places_where_pbs_change.size());
   440   for (
size_t i = 0; i != places_where_pbs_change.size(); ++i) {
   441     if (places_where_pbs_change[i].second ==
true) {
   446     pbns[i] = std::make_pair(places_where_pbs_change[i].first, pbn);
   451 inline double compute_euclidean_distance(
const std::pair<double, double>& f,
const std::pair<double, double>& s) {
   452   return sqrt((f.first - s.first) * (f.first - s.first) + (f.second - s.second) * (f.second - s.second));
   458     std::clog <<
"Here are the intervals : \n";
   459     for (
   460       std::clog <<
"[ " << this->intervals[i].first <<
"] \n";
   465   std::vector<double> result;
   468   std::vector<std::vector<double> > distances(this->intervals.size());
   469   for (
   470     std::vector<double> aa(this->intervals.size());
   471     std::fill(aa.begin(), aa.end(), 0);
   474   std::vector<double> distances_from_diagonal(this->intervals.size());
   475   std::fill(distances_from_diagonal.begin(), distances_from_diagonal.end(), 0);
   477   for (
   478     std::vector<double> distancesFromI;
   479     for (
size_t j = i + 1; j != this->intervals.size(); ++j) {
   480       distancesFromI.push_back(compute_euclidean_distance(this->intervals[i], this->intervals[j]));
   483     double distanceToDiagonal = compute_euclidean_distance(
   484         this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
   485                                            0.5 * (this->intervals[i].first + this->intervals[i].second)));
   486     distances_from_diagonal[i] = distanceToDiagonal;
   489       std::clog <<
"Here are the distances form the point : [" << this->intervals[i].first <<
" , "   490                 << this->intervals[i].second <<
"] in the diagram \n";
   491       for (
size_t aa = 0; aa != distancesFromI.size(); ++aa) {
   492         std::clog <<
"To : " << i + aa <<
" : " << distancesFromI[aa] <<
   494       std::clog << std::endl;
   499     for (
   500       distances[i][j] = distancesFromI[j - i - 1];
   501       distances[j][i] = distancesFromI[j - i - 1];
   505     std::clog <<
"Here is the distance matrix : \n";
   506     for (
size_t i = 0; i != distances.size(); ++i) {
   507       for (
size_t j = 0; j != distances.size(); ++j) {
   508         std::clog << distances[i][j] <<
   510       std::clog << std::endl;
   512     std::clog << std::endl << std::endl <<
"And here are the distances to the diagonal : " << std::endl;
   513     for (
size_t i = 0; i != distances_from_diagonal.size(); ++i) {
   514       std::clog << distances_from_diagonal[i] <<
   516     std::clog << std::endl << std::endl;
   520   for (
   521     std::vector<double> distancesFromI = distances[i];
   522     distancesFromI.push_back(distances_from_diagonal[i]);
   525     std::sort(distancesFromI.begin(), distancesFromI.end(), std::greater<double>());
   527     if (k > distancesFromI.size()) {
   529         std::clog <<
"There are not enough neighbors in your set. We set the result to plus infty \n";
   531       result.push_back(std::numeric_limits<double>::max());
   533       if (distances_from_diagonal[i] > distancesFromI[k]) {
   535           std::clog <<
"The k-th n.n. is on a diagonal. Therefore we set up a distance to diagonal \n";
   537         result.push_back(distances_from_diagonal[i]);
   539         result.push_back(distancesFromI[k]);
   543   std::sort(result.begin(), result.end(), std::greater<double>());
   544   result.resize(std::min(result.size(), where_to_cut));
   552   for (
   554         (this->intervals[i].second - this->intervals[i].first) * (this->intervals[i].second - this->intervals[i].first);
   563 #endif  // PERSISTENCE_INTERVALS_H_ std::vector< std::pair< double, size_t > > compute_persistent_betti_numbers() const
Definition: Persistence_intervals.h:429
size_t size() const
Definition: Persistence_intervals.h:195
std::vector< double > characteristic_function_of_diagram(double x_min, double x_max, size_t number_of_bins=10) const
Definition: Persistence_intervals.h:362
std::vector< double > k_n_n(size_t k, size_t where_to_cut=10) const
Definition: Persistence_intervals.h:455
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_intervals.h:226
std::vector< std::pair< double, double > > dominant_intervals(size_t where_to_cut=100) const
Definition: Persistence_intervals.h:281
Definition: SimplicialComplexForAlpha.h:14
std::vector< double > length_of_dominant_intervals(size_t where_to_cut=100) const
Definition: Persistence_intervals.h:266
std::vector< size_t > histogram_of_lengths(size_t number_of_bins=10) const
Definition: Persistence_intervals.h:303
void plot(const char *filename, double min_x=std::numeric_limits< double >::max(), double max_x=std::numeric_limits< double >::max(), double min_y=std::numeric_limits< double >::max(), double max_y=std::numeric_limits< double >::max()) const
Definition: Persistence_intervals.h:154
std::pair< double, double > get_x_range() const
Definition: Persistence_intervals.h:59
Persistence_intervals(const char *filename, unsigned dimension=std::numeric_limits< unsigned >::max())
Definition: Persistence_intervals.h:252
Definition: Persistence_intervals.h:37
size_t number_of_vectorize_functions() const
Definition: Persistence_intervals.h:233
friend std::ostream & operator<<(std::ostream &out, const Persistence_intervals &intervals)
Definition: Persistence_intervals.h:144
std::vector< double > cumulative_characteristic_function_of_diagram(double x_min, double x_max, size_t number_of_bins=10) const
Definition: Persistence_intervals.h:412
std::pair< double, double > operator[](size_t i) const
Definition: Persistence_intervals.h:201
std::vector< size_t > cumulative_histogram_of_lengths(size_t number_of_bins=10) const
Definition: Persistence_intervals.h:350
double project_to_R(int number_of_function) const
Definition: Persistence_intervals.h:549
size_t number_of_projections_to_R() const
Definition: Persistence_intervals.h:220
std::pair< double, double > get_y_range() const
Definition: Persistence_intervals.h:72
