11 #ifndef LAZY_TOPLEX_MAP_H    12 #define LAZY_TOPLEX_MAP_H    14 #include <gudhi/Toplex_map.h>    15 #include <boost/heap/fibonacci_heap.hpp>    42   template <
typename Input_vertex_range>
    47   template <
    52   template <
    56   template <
    57   bool membership(
const Input_vertex_range &vertex_range);
    60   template <
    75   template <
    76   void erase_max(
    77   template <
    78   Vertex best_index(
    79   void clean(
const Vertex v);
    81   std::unordered_map<Vertex, std::size_t> gamma0_lbounds;
    83   std::unordered_map<Vertex, Simplex_ptr_set> t0;
    84   bool empty_toplex =
true;
    86   typedef boost::heap::fibonacci_heap<std::pair<std::size_t, Vertex>> PriorityQueue;
    87   PriorityQueue cleaning_priority;
    88   std::unordered_map<Vertex, PriorityQueue::handle_type> cp_handles;
    90   std::size_t get_gamma0_lbound(
const Vertex v)
const;
    92   std::size_t size_lbound = 0;
    95   const double ALPHA = 4;
    96   const double BETTA = 8;
    99 template <
   101   for (
const Vertex &v : vertex_range)
   102     if (!gamma0_lbounds.count(v))
   103       gamma0_lbounds.emplace(v, 1);
   110 template <
   112   Simplex sigma(vertex_range.begin(), vertex_range.end());
   114   empty_toplex = (sigma.size() == 0);
   115   Simplex_ptr sptr = std::make_shared<Simplex>(sigma);
   116   bool inserted =
false;
   117   for (
const Vertex &v : sigma) {
   120       auto v_handle = cleaning_priority.push(std::make_pair(0, v));
   121       cp_handles.emplace(v, v_handle);
   123     inserted = t0.at(v).emplace(sptr).second;
   124     cleaning_priority.update(cp_handles.at(v), std::make_pair(t0.at(v).size() - get_gamma0_lbound(v), v));
   126   if (inserted) size++;
   127   if (size > (size_lbound + 1) * BETTA) clean(cleaning_priority.top().second);
   131 template <
   133   if (vertex_range.begin() == vertex_range.end()) {
   135     gamma0_lbounds.clear();
   136     cleaning_priority.clear();
   139     empty_toplex =
false;
   141     const Vertex &v = best_index(vertex_range);
   145         if (included(vertex_range, *sptr)) {
   152 template <
   154   if (t0.size() == 0 && !empty_toplex)
return false;
   155   if (vertex_range.begin() == vertex_range.end())
return true;
   156   Vertex v = best_index(vertex_range);
   157   if (!t0.count(v))
return false;
   159     if (included(vertex_range, *sptr))
return true;
   163 template <
   165   Simplex sigma(vertex_range.begin(), vertex_range.end());
   166   Vertex v = best_index(sigma);
   167   if (!t0.count(v))
return false;
   171   std::unordered_set<Vertex> facets_inside;
   173     for (
const Vertex &w : sigma) {
   176       if (included(f, *sptr)) facets_inside.insert(w);
   178   return facets_inside.size() == sigma.size() - 1;
   183   if (!t0.count(x))
return y;
   184   if (!t0.count(y))
return x;
   186   if (t0.at(x).size() > t0.at(y).size())
   203 template <
   204 inline void Lazy_toplex_map::erase_max(
const Input_vertex_range &vertex_range) {
   205   Simplex sigma(vertex_range.begin(), vertex_range.end());
   206   empty_toplex =
false;
   207   Simplex_ptr sptr = std::make_shared<Simplex>(sigma);
   209   for (
   210     erased = t0.at(v).erase(sptr) > 0;
   211     if (t0.at(v).size() == 0) t0.erase(v);
   216 template <
   218   Simplex tau(vertex_range.begin(), vertex_range.end());
   219   std::size_t min = std::numeric_limits<size_t>::max();
   221   for (
const Vertex &v : tau)
   224     else if (t0.at(v).size() < min)
   225       min = t0.at(v).size(), arg_min = v;
   226   if (min > ALPHA * get_gamma0_lbound(arg_min)) clean(arg_min);
   230 std::size_t Lazy_toplex_map::get_gamma0_lbound(
const Vertex v)
 const {
   231   return gamma0_lbounds.count(v) ? gamma0_lbounds.at(v) : 0;
   234 void Lazy_toplex_map::clean(
const Vertex v) {
   236   std::unordered_map<int, std::vector<Simplex>> dsorted_simplices;
   237   std::size_t max_dim = 0;
   239     if (sptr->size() > max_dim) {
   240       for (std::size_t d = max_dim + 1; d <= sptr->size(); d++) dsorted_simplices.emplace(d, std::vector<Simplex>());
   241       max_dim = sptr->size();
   243     dsorted_simplices[sptr->size()].emplace_back(*sptr);
   246   for (std::size_t d = max_dim; d >= 1; d--)
   247     for (
const Simplex &s : dsorted_simplices.at(d))
   252   size_lbound = size_lbound - get_gamma0_lbound(v) + clean_cofaces.size();
   253   gamma0_lbounds[v] = clean_cofaces.size();
 std::unordered_set< Toplex_map::Simplex_ptr, Sptr_hash, Sptr_equal > Simplex_ptr_set
Definition: Toplex_map.h:49
void insert_independent_simplex(const Input_vertex_range &vertex_range)
Definition: Lazy_toplex_map.h:100
Toplex_map::Vertex Vertex
Definition: Lazy_toplex_map.h:29
Toplex_map::Simplex Simplex
Definition: Lazy_toplex_map.h:32
Definition: SimplicialComplexForAlpha.h:14
std::shared_ptr< Toplex_map::Simplex > Simplex_ptr
Definition: Toplex_map.h:38
Definition: Toplex_map.h:245
bool membership(const Input_vertex_range &vertex_range) const
Definition: Toplex_map.h:169
bool insert_simplex(const Input_vertex_range &vertex_range)
Adds the given simplex to the complex. Nothing happens if the simplex is already in the complex (i...
Definition: Lazy_toplex_map.h:111
std::size_t Vertex
Definition: Toplex_map.h:32
Definition: Lazy_toplex_map.h:153
Toplex_map::Simplex_ptr Simplex_ptr
Definition: Lazy_toplex_map.h:35
Toplex_map::Simplex_ptr_set maximal_cofaces(const Input_vertex_range &vertex_range, const std::size_t max_number=0) const
Definition: Toplex_map.h:187
std::set< Vertex > Simplex
Definition: Toplex_map.h:35
Toplex_map::Simplex_ptr_set Simplex_ptr_set
Definition: Lazy_toplex_map.h:38
void remove_simplex(const Input_vertex_range &vertex_range)
Removes the given simplex and its cofaces from the complex. Its faces are kept inside.
Definition: Lazy_toplex_map.h:132
Vertex contraction(const Vertex x, const Vertex y)
Definition: Lazy_toplex_map.h:182
std::size_t num_vertices() const
Number of vertices.
Definition: Lazy_toplex_map.h:72
Lazy toplex map data structure for representing unfiltered simplicial complexes.
Definition: Lazy_toplex_map.h:26
bool all_facets_inside(const Input_vertex_range &vertex_range)
Definition: Lazy_toplex_map.h:164
Toplex map data structure for representing unfiltered simplicial complexes.
Definition: Toplex_map.h:29
std::size_t num_maximal_simplices() const
Number of maximal simplices.
Definition: Lazy_toplex_map.h:69
