12 #ifndef KD_TREE_SEARCH_H_    13 #define KD_TREE_SEARCH_H_    15 #include <CGAL/Orthogonal_k_neighbor_search.h>    16 #include <CGAL/Orthogonal_incremental_neighbor_search.h>    17 #include <CGAL/Search_traits.h>    18 #include <CGAL/Search_traits_adapter.h>    19 #include <CGAL/Fuzzy_sphere.h>    20 #include <CGAL/property_map.h>    21 #include <CGAL/version.h>      23 #include <Eigen/src/Core/util/Macros.h>      25 #include <boost/property_map/property_map.hpp>    26 #include <boost/iterator/counting_iterator.hpp>    32 #if CGAL_VERSION_NR < 1041101000    33 # error Kd_tree_search is only available for CGAL >= 4.11    36 #if !EIGEN_VERSION_AT_LEAST(3,1,0)    37 # error Kd_tree_search is only available for Eigen3 >= 3.1.0 installed with CGAL    41 namespace spatial_searching {
    69 template <
typename Search_traits,
typename Po
int_range>
    71   typedef boost::iterator_property_map<
    72     typename Point_range::const_iterator,
    73     CGAL::Identity_property_map<std::ptrdiff_t> >           Point_property_map;
    79   typedef typename Traits::FT
FT;
    81   typedef typename Point_range::value_type
Point;
    83   typedef CGAL::Search_traits<
    85     typename Traits::Cartesian_const_iterator_d,
    86     typename Traits::Construct_cartesian_const_iterator_d>  Traits_base;
    88   typedef CGAL::Search_traits_adapter<
    92   typedef CGAL::Distance_adapter<
    95     CGAL::Euclidean_distance<Traits_base> >                 Orthogonal_distance;
    97   typedef CGAL::Orthogonal_k_neighbor_search<STraits>       K_neighbor_search;
    98   typedef typename K_neighbor_search::Tree                  Tree;
    99   typedef typename K_neighbor_search::Distance              Distance;
   105   typedef CGAL::Orthogonal_incremental_neighbor_search<
   106     STraits, Distance, CGAL::Sliding_midpoint<STraits>, Tree>
   107                                                    Incremental_neighbor_search;
   113   typedef CGAL::Fuzzy_sphere<STraits>                       Fuzzy_sphere;
   119     m_tree(boost::counting_iterator<std::ptrdiff_t>(0),
   120            boost::counting_iterator<std::ptrdiff_t>(points.size()),
   121            typename Tree::Splitter(),
   122            STraits(std::begin(points))) {
   132   template <
typename Po
int_indices_range>
   134     Point_range
const& points,
   135     Point_indices_range
const& only_these_points)
   138         only_these_points.begin(), only_these_points.end(),
   139         typename Tree::Splitter(),
   140         STraits(std::begin(points))) {
   151     Point_range
const& points,
   152     std::size_t begin_idx, std::size_t past_the_end_idx)
   155       boost::counting_iterator<std::ptrdiff_t>(begin_idx),
   156       boost::counting_iterator<std::ptrdiff_t>(past_the_end_idx),
   157       typename Tree::Splitter(),
   158       STraits(std::begin(points))) {
   165   void insert(std::ptrdiff_t point_idx) {
   166     m_tree.insert(point_idx);
   179     FT eps =
FT(0))
 const {
   183     K_neighbor_search search(
   189       Orthogonal_distance(std::begin(m_points)), sorted);
   205     Incremental_neighbor_search search(
   210       Orthogonal_distance(std::begin(m_points)) );
   225     FT eps =
FT(0))
 const {
   229     K_neighbor_search search(
   235       Orthogonal_distance(std::begin(m_points)), sorted);
   251     Incremental_neighbor_search search(
   256       Orthogonal_distance(std::begin(m_points)) );
   267   template <
typename OutputIterator>
   271                    FT eps =
FT(0))
 const {
   272     m_tree.search(it, Fuzzy_sphere(p, radius, eps, m_tree.traits()));
   275   int tree_depth()
 const {
   276     return m_tree.root()->depth();
   280   Point_range
const& m_points;
   287 #endif  // KD_TREE_SEARCH_H_ Spatial tree data structure to perform (approximate) nearest and furthest neighbor search...
Definition: Kd_tree_search.h:70
Kd_tree_search(Point_range const &points, std::size_t begin_idx, std::size_t past_the_end_idx)
Constructor.
Definition: Kd_tree_search.h:150
Kd_tree_search(Point_range const &points, Point_indices_range const &only_these_points)
Constructor.
Definition: Kd_tree_search.h:133
Incremental_neighbor_search INS_range
The range returned by an incremental nearest or furthest neighbor search. Its value type is std::pair...
Definition: Kd_tree_search.h:111
K_neighbor_search KNS_range
The range returned by a k-nearest or k-furthest neighbor search. Its value type is std::pair<std::siz...
Definition: Kd_tree_search.h:103
INS_range incremental_furthest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the furthest neighbors from a query point.
Definition: Kd_tree_search.h:247
KNS_range k_nearest_neighbors(Point const &p, unsigned int k, bool sorted=true, FT eps=FT(0)) const
Search for the k-nearest neighbors from a query point.
Definition: Kd_tree_search.h:175
Kd_tree_search(Point_range const &points)
Constructor.
Definition: Kd_tree_search.h:117
Definition: SimplicialComplexForAlpha.h:14
INS_range incremental_nearest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the nearest neighbors from a query point.
Definition: Kd_tree_search.h:201
KNS_range k_furthest_neighbors(Point const &p, unsigned int k, bool sorted=true, FT eps=FT(0)) const
Search for the k-furthest points from a query point.
Definition: Kd_tree_search.h:221
Traits::FT FT
Number type used for distances.
Definition: Kd_tree_search.h:79
void all_near_neighbors(Point const &p, FT radius, OutputIterator it, FT eps=FT(0)) const
Search for all the neighbors in a ball.
Definition: Kd_tree_search.h:268
Point_range::value_type Point
The point type.
Definition: Kd_tree_search.h:81
Search_traits Traits
The Traits.
Definition: Kd_tree_search.h:77
