Contains the implementation of the Gudhi::zigzag_persistence::Zigzag_persistence class. More...
Go to the source code of this file.
Classes | |
| struct | Gudhi::zigzag_persistence::Zigzag_matrix_options< column_type > |
| Options for the internal matrix of Zigzag_persistence. More... | |
| struct | Gudhi::zigzag_persistence::Default_zigzag_options |
| Default options for Zigzag_persistence. More... | |
| class | Gudhi::zigzag_persistence::Zigzag_persistence< ZigzagOptions > |
| Class computing the zigzag persistent homology of a zigzag sequence. Algorithm based on [41]. More... | |
Namespaces | |
| namespace | Gudhi |
| Gudhi namespace. | |
