Contains the Gudhi::persistence_matrix::RU_pairing class and Gudhi::persistence_matrix::Dummy_ru_pairing structure. More...
Go to the source code of this file.
Classes | |
| struct | Gudhi::persistence_matrix::Dummy_ru_pairing |
| Empty structure. Inherited instead of RU_pairing, when the computation of the barcode was not enabled or if the pairing is already managed by the vine update classes. More... | |
| class | Gudhi::persistence_matrix::RU_pairing< Master_matrix > |
| Class managing the barcode for RU_matrix if the option was enabled. More... | |
Namespaces | |
| namespace | Gudhi |
| Gudhi namespace. | |
| namespace | Gudhi::persistence_matrix |
| Persistence matrix namespace. | |
