Contains the implementation of the Gudhi::zigzag_persistence::Default_filtered_zigzag_options structure and the Gudhi::zigzag_persistence::Filtered_zigzag_persistence_with_storage and Gudhi::zigzag_persistence::Filtered_zigzag_persistence classes. More...
Go to the source code of this file.
Classes | |
| struct | Gudhi::zigzag_persistence::Default_filtered_zigzag_options |
| Default options for Filtered_zigzag_persistence_with_storage and Filtered_zigzag_persistence. More... | |
| class | Gudhi::zigzag_persistence::Filtered_zigzag_persistence_with_storage< FilteredZigzagOptions > |
| Class computing the zigzag persistent homology of a zigzag filtration. Algorithm based on [41]. Even though the insertions and removals are given in a "stream-like" way, the barcode and other values are stored during the whole process and not removed. It is therefore suited for smaller filtrations where the clean ups produce a higher overhead than the memory consumption. More... | |
| class | Gudhi::zigzag_persistence::Filtered_zigzag_persistence< FilteredZigzagOptions > |
| Class computing the zigzag persistent homology of a zigzag filtration. Algorithm based on [41]. More... | |
Namespaces | |
| namespace | Gudhi |
| Gudhi namespace. | |
