| assign_paired_chain(Index other_col) | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| begin() noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| begin() const noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Chain_column_extra_properties() | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| Chain_column_extra_properties(ID_index pivot) | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| Chain_column_extra_properties(ID_index pivot, Index pair) | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| Chain_column_extra_properties(const Chain_column_extra_properties &col) | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| Chain_column_extra_properties(Chain_column_extra_properties &&col) | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| clear() | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| clear(ID_index rowIndex) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Column_dimension_holder() | Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > | inline |
| Column_dimension_holder(Dimension dim) | Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > | inline |
| Column_dimension_holder(const Column_dimension_holder &col) | Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > | inline |
| Column_dimension_holder(Column_dimension_holder &&col) | Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > | inline |
| Column_settings typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| const_iterator typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| const_reverse_iterator typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Dimension typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| end() noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| end() const noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Entry typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Field_element typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| get_column_index() const | Gudhi::persistence_matrix::Row_access< Master_matrix > | inline |
| get_content(int columnLength=-1) const | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| get_dimension() const | Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > | inline |
| get_paired_chain_index() const | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| get_pivot() | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| get_pivot_value() | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| ID_index typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Index typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| insert_entry(ID_index rowIndex, Matrix_entry *entry) | Gudhi::persistence_matrix::Row_access< Master_matrix > | inline |
| is_empty() | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| is_non_zero(ID_index rowIndex) const | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| is_paired() const | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| Master typedef | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Matrix_entry typedef | Gudhi::persistence_matrix::Row_access< Master_matrix > | |
| multiply_source_and_add(const Entry_range &column, const Field_element &val) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| multiply_target_and_add(const Field_element &val, const Entry_range &column) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| operator*=(const Field_element &val) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| operator+=(const Entry_range &column) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| operator+=(PersistenceMatrixColumn &column) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| operator< | Gudhi::persistence_matrix::PersistenceMatrixColumn | friend |
| operator=(const PersistenceMatrixColumn &other) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Gudhi::persistence_matrix::Column_dimension_holder::operator=(const Column_dimension_holder &other) | Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > | inline |
| Gudhi::persistence_matrix::Chain_column_extra_properties::operator=(const Chain_column_extra_properties &other) | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| operator== | Gudhi::persistence_matrix::PersistenceMatrixColumn | friend |
| PersistenceMatrixColumn(Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| PersistenceMatrixColumn(const Container &nonZeroRowIndices, Column_settings *colSettings) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| PersistenceMatrixColumn(Index columnIndex, const Container &nonZeroRowIndices, Row_container *rowContainer, Column_settings *colSettings) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| PersistenceMatrixColumn(const Container &nonZeroChainRowIndices, Dimension dimension, Column_settings *colSettings) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| PersistenceMatrixColumn(Index columnIndex, const Container &nonZeroChainRowIndices, Dimension dimension, Row_container *rowContainer, Column_settings *colSettings) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| PersistenceMatrixColumn(const PersistenceMatrixColumn &column, Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| PersistenceMatrixColumn(const PersistenceMatrixColumn &column, Index columnIndex, Row_container *rowContainer, Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| PersistenceMatrixColumn(PersistenceMatrixColumn &&column) noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| push_back(const Entry &entry) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| rbegin() noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| rbegin() const noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| rend() noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| rend() const noexcept | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| reorder(const Row_index_map &valueMap, Index columnIndex=Matrix::get_null_value< Index >()) | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| Row_access() | Gudhi::persistence_matrix::Row_access< Master_matrix > | inline |
| Row_access(Index columnIndex, Row_container *rows) | Gudhi::persistence_matrix::Row_access< Master_matrix > | inline |
| Row_access(Row_access &&other) noexcept | Gudhi::persistence_matrix::Row_access< Master_matrix > | inline |
| Row_container typedef | Gudhi::persistence_matrix::Row_access< Master_matrix > | |
| size() const | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
| swap | Gudhi::persistence_matrix::PersistenceMatrixColumn | friend |
| unassign_paired_chain() | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > | inline |
| unlink(Matrix_entry *entry) | Gudhi::persistence_matrix::Row_access< Master_matrix > | inline |
| update_entry(const Matrix_entry &entry) | Gudhi::persistence_matrix::Row_access< Master_matrix > | inline |
| ~PersistenceMatrixColumn() | Gudhi::persistence_matrix::PersistenceMatrixColumn | |
