| add_to(Integer_index sourceColumnIndex, Integer_index targetColumnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| add_to(const Entry_range &sourceColumn, Index targetColumnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Bar typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| Barcode typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| Column typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| Cycle typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| defaultEntryConstructor | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inlinestatic |
| Dimension typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| Element typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| Entry_constructor typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| Entry_representative typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| erase_empty_row(ID_index rowIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Field_operators typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| get_column(Index columnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_column(Index columnIndex) const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_column(Index columnIndex, bool inR) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_column_dimension(Index columnIndex) const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_column_with_pivot(ID_index cellIndex) const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_current_barcode() | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_current_barcode() const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_max_dimension() const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_null_value() | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inlinestatic |
| get_number_of_columns() const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_pivot(Index columnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_representative_cycle(const Bar &bar) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_representative_cycles() | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_row(ID_index rowIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_row(ID_index rowIndex) const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| get_row(ID_index rowIndex, bool inR) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| ID_index typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| Index typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| insert_boundary(const Boundary_range &boundary, Dimension dim=Matrix::get_null_value< Dimension >()) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| insert_boundary(ID_index cellIndex, const Boundary_range &boundary, Dimension dim=Matrix::get_null_value< Dimension >()) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| insert_column(const Container &column) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| insert_column(const Container &column, Index columnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| is_zero_column(Index columnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| is_zero_column(Index columnIndex, bool inR) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| is_zero_entry(Index columnIndex, ID_index rowIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| is_zero_entry(Index columnIndex, ID_index rowIndex, bool inR) const | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix() | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix(const std::vector< Container > &columns, Characteristic characteristic=11) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix(unsigned int numberOfColumns, Characteristic characteristic=Matrix::get_null_value< Characteristic >()) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix(const std::function< bool(Pos_index, Pos_index)> &birthComparator, const std::function< bool(Pos_index, Pos_index)> &deathComparator) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix(const std::vector< Boundary_range > &orderedBoundaries, const std::function< bool(Pos_index, Pos_index)> &birthComparator, const std::function< bool(Pos_index, Pos_index)> &deathComparator, Characteristic characteristic=11) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix(unsigned int numberOfColumns, const std::function< bool(Pos_index, Pos_index)> &birthComparator, const std::function< bool(Pos_index, Pos_index)> &deathComparator, Characteristic characteristic=Matrix::get_null_value< Characteristic >()) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix(const Matrix &matrixToCopy) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix(Matrix &&other) noexcept | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Matrix_entry typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| multiply_source_and_add_to(int coefficient, Integer_index sourceColumnIndex, Integer_index targetColumnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| multiply_source_and_add_to(int coefficient, const Entry_range &sourceColumn, Index targetColumnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| multiply_target_and_add_to(Integer_index sourceColumnIndex, int coefficient, Integer_index targetColumnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| multiply_target_and_add_to(const Entry_range &sourceColumn, int coefficient, Index targetColumnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| operator=(Matrix other) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Pos_index typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| remove_column(Index columnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| remove_last() | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| remove_maximal_cell(Index columnIndex) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| remove_maximal_cell(ID_index cellIndex, const std::vector< ID_index > &columnsToSwap) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| Row typedef | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | |
| set_characteristic(Characteristic characteristic) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| swap | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | friend |
| swap_columns(Index columnIndex1, Index columnIndex2) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| swap_rows(Index rowIndex1, Index rowIndex2) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| update_representative_cycles() | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| vine_swap(Pos_index index) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| vine_swap(Index columnIndex1, Index columnIndex2) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| vine_swap_with_z_eq_1_case(Pos_index index) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| vine_swap_with_z_eq_1_case(Index columnIndex1, Index columnIndex2) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
| zero_entry(Index columnIndex, ID_index rowIndex, bool inR) | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > | inline |
