| add_to(Index sourceColumnIndex, Index targetColumnIndex) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Boundary typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Chain_matrix(Column_settings *colSettings) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Chain_matrix(const std::vector< Boundary_range > &orderedBoundaries, Column_settings *colSettings) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Chain_matrix(unsigned int numberOfColumns, Column_settings *colSettings) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Chain_matrix(Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Chain_matrix(const std::vector< Boundary_range > &orderedBoundaries, Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Chain_matrix(unsigned int numberOfColumns, Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Chain_matrix(const Chain_matrix &matrixToCopy, Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Chain_matrix(Chain_matrix &&other) noexcept | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Column typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Column_settings typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Dimension typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Entry typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Entry_constructor typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Entry_representative typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Field_element typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Field_operators typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| get_column(Index columnIndex) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| get_column(Index columnIndex) const | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| get_column_dimension(Index columnIndex) const | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| get_column_with_pivot(ID_index cellID) const | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| get_number_of_columns() const | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| get_pivot(Index columnIndex) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| ID_index typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| Index typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| insert_boundary(const Boundary_range &boundary, Dimension dim=Master_matrix::template get_null_value< Dimension >()) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| insert_boundary(ID_index cellID, const Boundary_range &boundary, Dimension dim=Master_matrix::template get_null_value< Dimension >()) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| is_zero_column(Index columnIndex) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| is_zero_entry(Index columnIndex, ID_index rowIndex) const | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| multiply_source_and_add_to(const Field_element &coefficient, Index sourceColumnIndex, Index targetColumnIndex) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| multiply_target_and_add_to(Index sourceColumnIndex, const Field_element &coefficient, Index targetColumnIndex) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| operator=(const Chain_matrix &other) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Pos_index typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| remove_last() | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| remove_maximal_cell(ID_index cellID) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| remove_maximal_cell(ID_index cellID, const std::vector< ID_index > &columnsToSwap) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| reset(Column_settings *colSettings) | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | inline |
| Row typedef | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | |
| swap | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > | friend |
