Chain_matrix.h File Reference
Contains the Gudhi::persistence_matrix::Chain_matrix class. More...
Go to the source code of this file.
Classes
class  Gudhi::persistence_matrix::Chain_matrix< Master_matrix >
 Matrix structure storing a compatible base of a filtered chain complex. See [41]. The base is constructed from the boundaries of the cells in the complex. Allows the persistent homology to be computed, as well as representative cycles. Supports vineyards (see [21]) and the removal of maximal cells while maintaining a valid barcode. Provides an access to its columns and rows. More...
Namespaces
namespace  Gudhi
 Gudhi namespace.
namespace  Gudhi::persistence_matrix
 Persistence matrix namespace.
Detailed Description
Author
Hannah Schreiber
