Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
simplex_tree_to_matrix.cpp
Persistence_field
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Hannah Schreiber
* Copyright (C) 2024 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <vector>
#include <gudhi/matrix.h>
#include <gudhi/Simplex_tree.h>
struct RU_options : Default_options<Column_types::INTRUSIVE_LIST, true>
static const bool has_column_pairings = true;
static const bool can_retrieve_representative_cycles = true;
struct Chain_options : Default_options<Column_types::INTRUSIVE_LIST, true>
static const bool is_of_boundary_type = false;
void build_simplex_tree(Simplex_tree<>& st){
std::vector<std::vector<int> > simplices = {
{0},
{1},
{2},
{3},
{4},
{5},
{6},
{2, 3},
{4, 5},
{0, 2},
{0, 1},
{1, 3},
{1, 2},
{1, 2, 3},
{0, 1, 2},
{5, 6},
{2, 4},
{4, 6},
{4, 5, 6},
{3, 6}
//insertion in the simplex tree
for (unsigned int i = 0; i < simplices.size(); ++i){
st.insert_simplex(simplices[i], i);
template <class Column>
void print_column(Column& col, unsigned int num, unsigned int size) {
std::cout << "col " << num << ": ";
if (num < 10) std::cout << " ";
for (const auto& e : col.get_content(size)) {
if (e == 0u)
std::cout << "- ";
else
std::cout << e << " ";
std::cout << "\n";
void print_matrix(Base_matrix& bm, unsigned int size){
std::cout << "Base_matrix:\n";
for (unsigned int i = 0; i < size; ++i) {
print_column(bm.get_column(i), i, size);
std::cout << "\n";
void print_matrix(const Chain_matrix& cm, unsigned int size){
std::cout << "Chain_matrix:\n";
// just note that if some vine swaps or removals occured, this would
// not give us the columns in the order of filtration anymore, but just
// in the order they are stored in the matrix
print_column(cm.get_column(i), i, size);
std::cout << "\n";
void print_matrix(RU_matrix& rum, unsigned int size){
std::cout << "RU_matrix:\n";
std::cout << "R:\n";
print_column(rum.get_column(i), i, size);
std::cout << "\n";
std::cout << "U:\n";
print_column(rum.get_column(i, false), i, size);
std::cout << "\n";
int main() {
build_simplex_tree(st); //could be any other way to build a simplex tree
auto size = st.num_simplices();
//reserving space with `size` is not mandatory but recommended for better performances.
Base_matrix bm(size);
RU_matrix rum(size);
Chain_matrix cm(size);
//filling the matrices with the boundary matrix computed from the simplex tree
unsigned int id = 0;
for (auto sh : st.filtration_simplex_range()){
//identifying the simplex such that the IDs are strictly increasing in the order of filtration.
st.assign_key(sh, id++);
//creating boundary
std::vector<unsigned int> boundary;
for (auto b : st.boundary_simplex_range(sh)){
boundary.push_back(st.key(b));
std::sort(boundary.begin(), boundary.end()); //boundaries have to be ordered
//insertion in the matrices, the id is continuously increasing from 0 so no need to give it as an argument.
bm.insert_boundary(boundary);
rum.insert_boundary(boundary);
cm.insert_boundary(boundary);
//content of the matrices
print_matrix(bm, size);
print_matrix(rum, size);
print_matrix(cm, size);
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:95
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:338
static Simplex_key key(Simplex_handle sh)
Returns the key associated to a simplex.
Definition: Simplex_tree.h:597
std::pair< Simplex_handle, bool > insert_simplex(const InputVertexRange &simplex, Filtration_value filtration=0)
Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex.
Definition: Simplex_tree.h:913
void assign_key(Simplex_handle sh, Simplex_key key)
Assign a value 'key' to the key of the simplex represented by the Simplex_handle 'sh'.
Definition: Simplex_tree.h:1009
Boundary_simplex_range boundary_simplex_range(SimplexHandle sh)
Returns a range over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:370
size_t num_simplices()
Returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:664
Data structure for matrices, and in particular thought for matrices representing filtered complexes i...
Definition: matrix.h:143
returned_column_type & get_column(index columnIndex)
Returns the column at the given MatIdx index. For RU matrices, is equivalent to get_column(columnInde...
Definition: matrix.h:1609
insertion_return_type insert_boundary(const Boundary_type &boundary, dimension_type dim=-1)
Inserts at the end of the matrix a new ordered column corresponding to the given boundary....
Definition: matrix.h:1572
Column_types
List of column types.
Definition: persistence_matrix_options.h:30
Contains Gudhi::persistence_matrix::Matrix class.
Contains the options for the matrix template.
Default option structure for Matrix class. See the PersistenceMatrixOptions concept for a more detail...
Definition: persistence_matrix_options.h:77
