Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
simplex_tree_from_cliques_of_graph.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Clément Maria
* Copyright (C) 2014 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <ctime>
#include <string>
#include <utility> // for std::pair
using namespace Gudhi;
typedef int Vertex_handle;
typedef double Filtration_value;
typedef boost::adjacency_list < boost::vecS, boost::vecS, boost::undirectedS,
boost::property < vertex_filtration_t, Filtration_value >,
boost::property < edge_filtration_t, Filtration_value > > Graph_t;
int main(int argc, char * const argv[]) {
if (argc != 3) {
std::cerr << "Usage: " << argv[0]
<< " path_to_file_graph max_dim \n";
return 0;
std::string filegraph = argv[1];
int max_dim = atoi(argv[2]);
clock_t start, end;
// Construct the Simplex Tree
start = clock();
auto g = read_graph<Graph_t, Filtration_value, Vertex_handle>(filegraph);
// insert the graph in the simplex tree as 1-skeleton
st.insert_graph(g);
end = clock();
std::clog << "Insert the 1-skeleton in the simplex tree in "
<< static_cast<double>(end - start) / CLOCKS_PER_SEC << " s. \n";
start = clock();
// expand the 1-skeleton until dimension max_dim
st.expansion(max_dim);
end = clock();
std::clog << "max_dim = " << max_dim << "\n";
std::clog << "Expand the simplex tree in "
std::clog << "Information of the Simplex Tree: " << std::endl;
std::clog << " Number of vertices = " << st.num_vertices() << " ";
std::clog << " Number of simplices = " << st.num_simplices() << std::endl;
std::clog << std::endl << std::endl;
std::clog << "Iterator on vertices: ";
for (auto vertex : st.complex_vertex_range()) {
std::clog << vertex << " ";
std::clog << std::endl;
std::clog << "Iterator on simplices: " << std::endl;
for (auto simplex : st.complex_simplex_range()) {
std::clog << " ";
for (auto vertex : st.simplex_vertex_range(simplex)) {
std::clog << "Iterator on Simplices in the filtration, with [filtration value]:" << std::endl;
for (auto f_simplex : st.filtration_simplex_range()) {
std::clog << " " << "[" << st.filtration(f_simplex) << "] ";
for (auto vertex : st.simplex_vertex_range(f_simplex)) {
std::clog << "Iterator on Simplices in the filtration, and their boundary simplices:" << std::endl;
for (auto b_simplex : st.boundary_simplex_range(f_simplex)) {
std::clog << " " << "[" << st.filtration(b_simplex) << "] ";
for (auto vertex : st.simplex_vertex_range(b_simplex)) {
return 0;
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:338
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:349
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:614
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:651
void expansion(int max_dim)
Expands the Simplex_tree containing only its one skeleton until dimension max_dim.
Definition: Simplex_tree.h:1360
Boundary_simplex_range boundary_simplex_range(SimplexHandle sh)
Returns a range over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:370
size_t num_simplices()
Returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:664
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a 1-skeleton in an empty Simplex_tree.
Definition: Simplex_tree.h:1272
Complex_simplex_range complex_simplex_range()
Returns a range over the simplices of the simplicial complex.
Definition: Simplex_tree.h:304
Complex_vertex_range complex_vertex_range()
Returns a range over the vertices of the simplicial complex. The order is increasing according to < o...
Definition: Simplex_tree.h:293
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
This file includes common file reader for GUDHI.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
