Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
representative_cycles_from_matrix.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Hannah Schreiber
* Copyright (C) 2024 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <iostream>
#include <gudhi/matrix.h>
struct RU_rep_cycles_options : Default_options<Column_types::INTRUSIVE_LIST, true>
static const bool can_retrieve_representative_cycles = true;
struct Chain_rep_cycles_options : Default_options<Column_types::INTRUSIVE_LIST, true>
static const bool is_of_boundary_type = false;
template <class Matrix>
void print_representative_cycles_example()
Matrix mp({ { },
{ 2, 3 },
{ 4, 5 },
{ 0, 2 },
{ 0, 1 },
{ 1, 3 },
{ 1, 2 },
{ 7, 11, 12 },
{ 9, 10, 12 },
{ 5, 6 },
{ 2, 4 },
{ 4, 6 },
{ 8, 15, 17 },
{ 3, 6 }
auto rc = mp.get_representative_cycles();
for (auto cycle : rc) {
// cycle[0] gives the row index of a simplex in the cycle
// because the simplices where indexed from 0 continously, the simplex represented by the row index cycle[0] is
// the same simplex represented by the column at position cycle[0] in RU
// that is why `mp.get_column_dimension(cycle[0])` gives us the dimension of the simplex for RU_matrix
// for the chain matrix, the row index will always represent a simplex ID. So,
// `mp.get_column_dimension(mp.get_column_with_pivot(cycle[0]))` will always work to get the dimension
// of the simplex. But in this particlar case, because of the simplex indexation and the fact that no swap
// occured, mp.get_column_with_pivot(cycle[0]) == cycle[0] and so `mp.get_column_dimension(cycle[0])` also works.
std::cout << mp.get_column_dimension(cycle[0]);
std::cout << "-cycle: ";
for (auto index : cycle) {
std::cout << index << ", ";
std::cout << "\n";
int main() {
std::cout << "RU_matrix:\n";
print_representative_cycles_example<RU_matrix>();
std::cout << "\n";
std::cout << "Chain_matrix:\n";
print_representative_cycles_example<Chain_matrix>();
Data structure for matrices, and in particular thought for matrices representing filtered complexes i...
Definition: matrix.h:143
Column_types
List of column types.
Definition: persistence_matrix_options.h:30
Contains Gudhi::persistence_matrix::Matrix class.
Contains the options for the matrix template.
Default option structure for Matrix class. See the PersistenceMatrixOptions concept for a more detail...
Definition: persistence_matrix_options.h:77
