Contains the Intrusive_set_column class. Also defines the std::hash method for Intrusive_set_column. More...
Go to the source code of this file.
Classes | |
class | Gudhi::persistence_matrix::Intrusive_set_column< Master_matrix > |
Column class following the PersistenceMatrixColumn concept. More... | |
struct | std::hash< Gudhi::persistence_matrix::Intrusive_set_column< Master_matrix > > |
Hash method for Gudhi::persistence_matrix::Intrusive_set_column. More... | |
Namespaces | |
Gudhi | |
Gudhi namespace. | |
Gudhi::persistence_matrix | |
Persistence matrix namespace. | |
