heap_column.h
Go to the documentation of this file.
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Hannah Schreiber
4  *
5  * Copyright (C) 2022-24 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
17 #ifndef PM_HEAP_COLUMN_H
18 #define PM_HEAP_COLUMN_H
19
20 #include <vector>
21 #include <stdexcept>
22 #include <type_traits>
23 #include <algorithm> //binary_search
24 #include <utility> //std::swap, std::move & std::exchange
25
26 #include <boost/iterator/indirect_iterator.hpp>
27
29
30 namespace Gudhi {
31 namespace persistence_matrix {
32
48 template <class Master_matrix>
50 {
51  public:
52  using Master = Master_matrix;
53  using index = typename Master_matrix::index;
54  using id_index = typename Master_matrix::id_index;
55  using dimension_type = typename Master_matrix::dimension_type;
56  using Field_element_type = typename Master_matrix::element_type;
57  using Cell = typename Master_matrix::Cell_type;
58  using Column_settings = typename Master_matrix::Column_settings;
59
60  private:
61  using Field_operators = typename Master_matrix::Field_operators;
62  using Column_type = std::vector<Cell*>;
63  using Cell_constructor = typename Master_matrix::Cell_constructor;
64
65  public:
66  using iterator = boost::indirect_iterator<typename Column_type::iterator>;
67  using const_iterator = boost::indirect_iterator<typename Column_type::const_iterator>;
68  using reverse_iterator = boost::indirect_iterator<typename Column_type::reverse_iterator>;
69  using const_reverse_iterator = boost::indirect_iterator<typename Column_type::const_reverse_iterator>;
70
71  Heap_column(Column_settings* colSettings = nullptr);
72  template <class Container_type = typename Master_matrix::boundary_type>
73  Heap_column(const Container_type& nonZeroRowIndices, Column_settings* colSettings);
74  template <class Container_type = typename Master_matrix::boundary_type>
75  Heap_column(const Container_type& nonZeroChainRowIndices,
76  dimension_type dimension,
77  Column_settings* colSettings);
78  Heap_column(const Heap_column& column, Column_settings* colSettings = nullptr);
79  Heap_column(Heap_column&& column) noexcept;
80  ~Heap_column();
81
82  // just for the sake of the interface
83  // row containers and column index are ignored as row access is not implemented for heap columns
84  template <class Container_type = typename Master_matrix::boundary_type, class Row_container_type>
85  Heap_column(index columnIndex,
86  const Container_type& nonZeroRowIndices,
87  Row_container_type* rowContainer,
88  Column_settings* colSettings);
89  template <class Container_type = typename Master_matrix::boundary_type, class Row_container_type>
90  Heap_column(index columnIndex,
91  const Container_type& nonZeroChainRowIndices,
92  dimension_type dimension,
93  Row_container_type* rowContainer,
94  Column_settings* colSettings);
95  template <class Row_container_type>
96  Heap_column(const Heap_column& column,
97  index columnIndex,
98  Row_container_type* rowContainer,
99  Column_settings* colSettings = nullptr);
100
101  std::vector<Field_element_type> get_content(int columnLength = -1) const;
102  bool is_non_zero(id_index rowIndex) const;
103  bool is_empty();
104  std::size_t size() const;
105
106  template <class Map_type>
107  void reorder(const Map_type& valueMap, [[maybe_unused]] index columnIndex = -1);
108  void clear();
109  void clear(id_index rowIndex);
110
111  id_index get_pivot();
112  Field_element_type get_pivot_value();
113
114  iterator begin() noexcept;
115  const_iterator begin() const noexcept;
116  iterator end() noexcept;
117  const_iterator end() const noexcept;
118  reverse_iterator rbegin() noexcept;
119  const_reverse_iterator rbegin() const noexcept;
120  reverse_iterator rend() noexcept;
121  const_reverse_iterator rend() const noexcept;
122
123  template <class Cell_range>
124  Heap_column& operator+=(const Cell_range& column);
125  Heap_column& operator+=(Heap_column& column);
126
127  Heap_column& operator*=(unsigned int v);
128
129  // this = v * this + column
130  template <class Cell_range>
131  Heap_column& multiply_target_and_add(const Field_element_type& val, const Cell_range& column);
132  Heap_column& multiply_target_and_add(const Field_element_type& val, Heap_column& column);
133  // this = this + column * v
134  template <class Cell_range>
135  Heap_column& multiply_source_and_add(const Cell_range& column, const Field_element_type& val);
136  Heap_column& multiply_source_and_add(Heap_column& column, const Field_element_type& val);
137
138  std::size_t compute_hash_value();
139
140  friend bool operator==(const Heap_column& c1, const Heap_column& c2) {
141  if (&c1 == &c2) return true;
142
143  Heap_column cc1(c1), cc2(c2);
144  Cell* p1 = cc1._pop_pivot();
145  Cell* p2 = cc2._pop_pivot();
146  while (p1 != nullptr && p2 != nullptr) {
147  if (p1->get_row_index() != p2->get_row_index()) {
148  c1.cellPool_->destroy(p1);
149  c2.cellPool_->destroy(p2);
150  return false;
151  }
152  if constexpr (!Master_matrix::Option_list::is_z2){
153  if (p1->get_element() != p2->get_element()) {
154  c1.cellPool_->destroy(p1);
155  c2.cellPool_->destroy(p2);
156  return false;
157  }
158  }
159  c1.cellPool_->destroy(p1);
160  c2.cellPool_->destroy(p2);
161  p1 = cc1._pop_pivot();
162  p2 = cc2._pop_pivot();
163  }
164
165  if (p1 == nullptr && p2 == nullptr) return true;
166  if (p1 != nullptr) {
167  c1.cellPool_->destroy(p1);
168  return false;
169  }
170  c2.cellPool_->destroy(p2);
171  return false;
172  }
173  friend bool operator<(const Heap_column& c1, const Heap_column& c2) {
174  if (&c1 == &c2) return false;
175
176  //lexicographical order but starting from last value and not first
177  Heap_column cc1(c1), cc2(c2);
178  Cell* p1 = cc1._pop_pivot();
179  Cell* p2 = cc2._pop_pivot();
180  while (p1 != nullptr && p2 != nullptr) {
181  if (p1->get_row_index() > p2->get_row_index()) {
182  c1.cellPool_->destroy(p1);
183  c2.cellPool_->destroy(p2);
184  return false;
185  }
186  if (p1->get_row_index() < p2->get_row_index()) {
187  c1.cellPool_->destroy(p1);
188  c2.cellPool_->destroy(p2);
189  return true;
190  }
191  if constexpr (!Master_matrix::Option_list::is_z2){
192  if (p1->get_element() > p2->get_element()) {
193  c1.cellPool_->destroy(p1);
194  c2.cellPool_->destroy(p2);
195  return false;
196  }
197  if (p1->get_element() < p2->get_element()) {
198  c1.cellPool_->destroy(p1);
199  c2.cellPool_->destroy(p2);
200  return true;
201  }
202  }
203  c1.cellPool_->destroy(p1);
204  c2.cellPool_->destroy(p2);
205  p1 = cc1._pop_pivot();
206  p2 = cc2._pop_pivot();
207  }
208
209  if (p2 == nullptr) {
210  c1.cellPool_->destroy(p1);
211  return false;
212  }
213  c2.cellPool_->destroy(p2);
214  return true;
215  }
216
217  // Disabled with row access.
218  Heap_column& operator=(const Heap_column& other);
219
220  friend void swap(Heap_column& col1, Heap_column& col2) {
221  swap(static_cast<typename Master_matrix::Column_dimension_option&>(col1),
222  static_cast<typename Master_matrix::Column_dimension_option&>(col2));
223  swap(static_cast<typename Master_matrix::Chain_column_option&>(col1),
224  static_cast<typename Master_matrix::Chain_column_option&>(col2));
225  col1.column_.swap(col2.column_);
226  std::swap(col1.insertsSinceLastPrune_, col2.insertsSinceLastPrune_);
227  std::swap(col1.operators_, col2.operators_);
228  std::swap(col1.cellPool_, col2.cellPool_);
229  }
230
231  private:
232  using dim_opt = typename Master_matrix::Column_dimension_option;
233  using chain_opt = typename Master_matrix::Chain_column_option;
234
235  struct {
236  bool operator()(const Cell* c1, const Cell* c2) const { return *c1 < *c2; }
237  } cellPointerComp_;
238
239  Column_type column_;
240  unsigned int insertsSinceLastPrune_;
241  Field_operators* operators_;
242  Cell_constructor* cellPool_;
243
244  void _prune();
245  Cell* _pop_pivot();
246  template <class Cell_range>
247  bool _add(const Cell_range& column);
248  template <class Cell_range>
249  bool _multiply_target_and_add(const Field_element_type& val, const Cell_range& column);
250  template <class Cell_range>
251  bool _multiply_source_and_add(const Cell_range& column, const Field_element_type& val);
252 };
253
254 template <class Master_matrix>
255 inline Heap_column<Master_matrix>::Heap_column(Column_settings* colSettings)
256  : dim_opt(), chain_opt(), insertsSinceLastPrune_(0), operators_(nullptr), cellPool_(colSettings == nullptr ? nullptr : &(colSettings->cellConstructor))
257 {
258  if (colSettings == nullptr) return; //to allow default constructor which gives a dummy column
259  if constexpr (!Master_matrix::Option_list::is_z2){
260  operators_ = &(colSettings->operators);
261  }
262 }
263
264 template <class Master_matrix>
265 template <class Container_type>
266 inline Heap_column<Master_matrix>::Heap_column(const Container_type& nonZeroRowIndices, Column_settings* colSettings)
267  : dim_opt(nonZeroRowIndices.size() == 0 ? 0 : nonZeroRowIndices.size() - 1),
268  chain_opt(),
269  column_(nonZeroRowIndices.size(), nullptr),
270  insertsSinceLastPrune_(0),
271  operators_(nullptr),
272  cellPool_(&(colSettings->cellConstructor))
273 {
274  static_assert(!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type,
275  "Constructor not available for chain columns, please specify the dimension of the chain.");
276
277  if constexpr (!Master_matrix::Option_list::is_z2){
278  operators_ = &(colSettings->operators);
279  }
280
281  index i = 0;
282  if constexpr (Master_matrix::Option_list::is_z2) {
283  for (id_index id : nonZeroRowIndices) {
284  column_[i++] = cellPool_->construct(id);
285  }
286  } else {
287  for (const auto& p : nonZeroRowIndices) {
288  column_[i] = cellPool_->construct(p.first);
289  column_[i++]->set_element(operators_->get_value(p.second));
290  }
291  }
292  std::make_heap(column_.begin(), column_.end(), cellPointerComp_);
293 }
294
295 template <class Master_matrix>
296 template <class Container_type>
297 inline Heap_column<Master_matrix>::Heap_column(const Container_type& nonZeroRowIndices,
298  dimension_type dimension,
299  Column_settings* colSettings)
300  : dim_opt(dimension),
301  chain_opt([&] {
302  if constexpr (Master_matrix::Option_list::is_z2) {
303  return nonZeroRowIndices.begin() == nonZeroRowIndices.end() ? -1 : *std::prev(nonZeroRowIndices.end());
304  } else {
305  return nonZeroRowIndices.begin() == nonZeroRowIndices.end() ? -1 : std::prev(nonZeroRowIndices.end())->first;
306  }
307  }()),
308  column_(nonZeroRowIndices.size(), nullptr),
309  insertsSinceLastPrune_(0),
310  operators_(nullptr),
311  cellPool_(&(colSettings->cellConstructor))
312 {
313  index i = 0;
314  if constexpr (Master_matrix::Option_list::is_z2) {
315  for (id_index id : nonZeroRowIndices) {
316  column_[i++] = cellPool_->construct(id);
317  }
318  } else {
319  operators_ = &(colSettings->operators);
320  for (const auto& p : nonZeroRowIndices) {
321  column_[i] = cellPool_->construct(p.first);
322  column_[i++]->set_element(operators_->get_value(p.second));
323  }
324  }
325  std::make_heap(column_.begin(), column_.end(), cellPointerComp_);
326 }
327
328 template <class Master_matrix>
329 inline Heap_column<Master_matrix>::Heap_column(const Heap_column& column,
330  Column_settings* colSettings)
331  : dim_opt(static_cast<const dim_opt&>(column)),
332  chain_opt(static_cast<const chain_opt&>(column)),
333  column_(column.column_.size(), nullptr),
334  insertsSinceLastPrune_(0),
335  operators_(colSettings == nullptr ? column.operators_ : nullptr),
336  cellPool_(colSettings == nullptr ? column.cellPool_ : &(colSettings->cellConstructor))
337 {
338  static_assert(!Master_matrix::Option_list::has_row_access,
339  "Simple copy constructor not available when row access option enabled. Please specify the new column "
340  "index and the row container.");
341
342  if constexpr (!Master_matrix::Option_list::is_z2){
343  if (colSettings != nullptr) operators_ = &(colSettings->operators);
344  }
345
346  index i = 0;
347  for (const Cell* cell : column.column_) {
348  if constexpr (Master_matrix::Option_list::is_z2) {
349  column_[i++] = cellPool_->construct(cell->get_row_index());
350  } else {
351  column_[i] = cellPool_->construct(cell->get_row_index());
352  column_[i++]->set_element(cell->get_element());
353  }
354  }
355  // column.column_ already ordered as a heap, so no need of make_heap.
356 }
357
358 template <class Master_matrix>
359 inline Heap_column<Master_matrix>::Heap_column(Heap_column&& column) noexcept
360  : dim_opt(std::move(static_cast<dim_opt&>(column))),
361  chain_opt(std::move(static_cast<chain_opt&>(column))),
362  column_(std::move(column.column_)),
363  insertsSinceLastPrune_(std::exchange(column.insertsSinceLastPrune_, 0)),
364  operators_(std::exchange(column.operators_, nullptr)),
365  cellPool_(std::exchange(column.cellPool_, nullptr))
366 {}
367
368 template <class Master_matrix>
369 template <class Container_type, class Row_container_type>
370 inline Heap_column<Master_matrix>::Heap_column(index columnIndex,
371  const Container_type& nonZeroRowIndices,
372  Row_container_type* rowContainer,
373  Column_settings* colSettings)
374  : dim_opt(nonZeroRowIndices.size() == 0 ? 0 : nonZeroRowIndices.size() - 1),
375  chain_opt([&] {
376  if constexpr (Master_matrix::Option_list::is_z2) {
377  return nonZeroRowIndices.begin() == nonZeroRowIndices.end() ? -1 : *std::prev(nonZeroRowIndices.end());
378  } else {
379  return nonZeroRowIndices.begin() == nonZeroRowIndices.end() ? -1 : std::prev(nonZeroRowIndices.end())->first;
380  }
381  }()),
382  column_(nonZeroRowIndices.size(), nullptr),
383  insertsSinceLastPrune_(0),
384  operators_(nullptr),
385  cellPool_(&(colSettings->cellConstructor))
386 {
387  static_assert(!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type,
388  "Constructor not available for chain columns, please specify the dimension of the chain.");
389
390  index i = 0;
391  if constexpr (Master_matrix::Option_list::is_z2) {
392  for (id_index id : nonZeroRowIndices) {
393  column_[i++] = cellPool_->construct(id);
394  }
395  } else {
396  operators_ = &(colSettings->operators);
397  for (const auto& p : nonZeroRowIndices) {
398  column_[i] = cellPool_->construct(p.first);
399  column_[i++]->set_element(operators_->get_value(p.second));
400  }
401  }
402  std::make_heap(column_.begin(), column_.end(), cellPointerComp_);
403 }
404
405 template <class Master_matrix>
406 template <class Container_type, class Row_container_type>
407 inline Heap_column<Master_matrix>::Heap_column(
408  index columnIndex,
409  const Container_type& nonZeroRowIndices,
410  dimension_type dimension,
411  Row_container_type* rowContainer,
412  Column_settings* colSettings)
413  : dim_opt(dimension),
414  chain_opt([&] {
415  if constexpr (Master_matrix::Option_list::is_z2) {
416  return nonZeroRowIndices.begin() == nonZeroRowIndices.end() ? -1 : *std::prev(nonZeroRowIndices.end());
417  } else {
418  return nonZeroRowIndices.begin() == nonZeroRowIndices.end() ? -1 : std::prev(nonZeroRowIndices.end())->first;
419  }
420  }()),
421  column_(nonZeroRowIndices.size(), nullptr),
422  insertsSinceLastPrune_(0),
423  operators_(nullptr),
424  cellPool_(&(colSettings->cellConstructor))
425 {
426  index i = 0;
427  if constexpr (Master_matrix::Option_list::is_z2) {
428  for (id_index id : nonZeroRowIndices) {
429  column_[i++] = cellPool_->construct(id);
430  }
431  } else {
432  operators_ = &(colSettings->operators);
433  for (const auto& p : nonZeroRowIndices) {
434  column_[i] = cellPool_->construct(p.first);
435  column_[i++]->set_element(operators_->get_value(p.second));
436  }
437  }
438  std::make_heap(column_.begin(), column_.end(), cellPointerComp_);
439 }
440
441 template <class Master_matrix>
442 template <class Row_container_type>
443 inline Heap_column<Master_matrix>::Heap_column(const Heap_column& column,
444  index columnIndex,
445  Row_container_type* rowContainer,
446  Column_settings* colSettings)
447  : dim_opt(static_cast<const dim_opt&>(column)),
448  chain_opt(static_cast<const chain_opt&>(column)),
449  column_(column.column_.size(), nullptr),
450  insertsSinceLastPrune_(0),
451  operators_(colSettings == nullptr ? column.operators_ : nullptr),
452  cellPool_(colSettings == nullptr ? column.cellPool_ : &(colSettings->cellConstructor))
453 {
454  if constexpr (!Master_matrix::Option_list::is_z2){
455  if (colSettings != nullptr) operators_ = &(colSettings->operators);
456  }
457
458  index i = 0;
459  for (const Cell* cell : column.column_) {
460  if constexpr (Master_matrix::Option_list::is_z2) {
461  column_[i++] = cellPool_->construct(cell->get_row_index());
462  } else {
463  column_[i] = cellPool_->construct(cell->get_row_index());
464  column_[i++]->set_element(cell->get_element());
465  }
466  }
467  // column.column_ already ordered as a heap, so no need of make_heap.
468 }
469
470 template <class Master_matrix>
471 inline Heap_column<Master_matrix>::~Heap_column()
472 {
473  for (auto* cell : column_) {
474  cellPool_->destroy(cell);
475  }
476 }
477
478 template <class Master_matrix>
479 inline std::vector<typename Heap_column<Master_matrix>::Field_element_type>
480 Heap_column<Master_matrix>::get_content(int columnLength) const
481 {
482  bool pivotLength = (columnLength < 0);
483  if (columnLength < 0 && column_.size() > 0)
484  columnLength = column_.front()->get_row_index() + 1;
485  else if (columnLength < 0)
486  return std::vector<Field_element_type>();
487
488  std::vector<Field_element_type> container(columnLength, 0);
489  for (auto it = column_.begin(); it != column_.end(); ++it) {
490  if ((*it)->get_row_index() < static_cast<id_index>(columnLength)) {
491  if constexpr (Master_matrix::Option_list::is_z2) {
492  container[(*it)->get_row_index()] = !container[(*it)->get_row_index()];
493  } else {
494  operators_->add_inplace(container[(*it)->get_row_index()], (*it)->get_element());
495  }
496  }
497  }
498
499  if (pivotLength) {
500  while (!container.empty() && container.back() == 0u) container.pop_back();
501  }
502
503  return container;
504 }
505
506 template <class Master_matrix>
507 inline bool Heap_column<Master_matrix>::is_non_zero(id_index rowIndex) const
508 {
509  Field_element_type c(0);
510  for (const Cell* cell : column_) {
511  if (cell->get_row_index() == rowIndex) {
512  if constexpr (Master_matrix::Option_list::is_z2) c = !c;
513  else operators_->add_inplace(c, cell->get_element());
514  }
515  }
516  return c != Field_operators::get_additive_identity();
517 }
518
519 template <class Master_matrix>
520 inline bool Heap_column<Master_matrix>::is_empty()
521 {
522  Cell* pivot = _pop_pivot();
523  if (pivot != nullptr) {
524  column_.push_back(pivot);
525  std::push_heap(column_.begin(), column_.end(), cellPointerComp_);
526  return false;
527  }
528  return true;
529 }
530
531 template <class Master_matrix>
532 inline std::size_t Heap_column<Master_matrix>::size() const
533 {
534  return column_.size();
535 }
536
537 template <class Master_matrix>
538 template <class Map_type>
539 inline void Heap_column<Master_matrix>::reorder(const Map_type& valueMap,
540  [[maybe_unused]] index columnIndex)
541 {
542  static_assert(!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type,
543  "Method not available for chain columns.");
544
545  Column_type tempCol;
546  Cell* pivot = _pop_pivot();
547  while (pivot != nullptr) {
548  pivot->set_row_index(valueMap.at(pivot->get_row_index()));
549  tempCol.push_back(pivot);
550  pivot = _pop_pivot();
551  }
552  column_.swap(tempCol);
553  std::make_heap(column_.begin(), column_.end(), cellPointerComp_);
554
555  insertsSinceLastPrune_ = 0;
556 }
557
558 template <class Master_matrix>
559 inline void Heap_column<Master_matrix>::clear()
560 {
561  static_assert(!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type,
562  "Method not available for chain columns as a base element should not be empty.");
563
564  for (auto* cell : column_) {
565  cellPool_->destroy(cell);
566  }
567
568  column_.clear();
569  insertsSinceLastPrune_ = 0;
570 }
571
572 template <class Master_matrix>
573 inline void Heap_column<Master_matrix>::clear(id_index rowIndex)
574 {
575  static_assert(!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type,
576  "Method not available for chain columns.");
577
578  Column_type tempCol;
579  Cell* pivot = _pop_pivot();
580  while (pivot != nullptr) {
581  if (pivot->get_row_index() != rowIndex){
582  tempCol.push_back(pivot);
583  } else {
584  cellPool_->destroy(pivot);
585  }
586  pivot = _pop_pivot();
587  }
588  column_.swap(tempCol);
589
590  insertsSinceLastPrune_ = 0;
591 }
592
593 template <class Master_matrix>
594 inline typename Heap_column<Master_matrix>::id_index
595 Heap_column<Master_matrix>::get_pivot()
596 {
597  static_assert(Master_matrix::isNonBasic,
598  "Method not available for base columns."); // could technically be, but is the notion usefull then?
599
600  if constexpr (Master_matrix::Option_list::is_of_boundary_type) {
601  Cell* pivot = _pop_pivot();
602  if (pivot != nullptr) {
603  column_.push_back(pivot);
604  std::push_heap(column_.begin(), column_.end(), cellPointerComp_);
605  return pivot->get_row_index();
606  }
607  return -1;
608  } else {
609  return chain_opt::get_pivot();
610  }
611 }
612
613 template <class Master_matrix>
614 inline typename Heap_column<Master_matrix>::Field_element_type
615 Heap_column<Master_matrix>::get_pivot_value()
616 {
617  static_assert(Master_matrix::isNonBasic,
618  "Method not available for base columns."); // could technically be, but is the notion usefull then?
619
620  if constexpr (Master_matrix::Option_list::is_z2) {
621  return 1;
622  } else {
623  if constexpr (Master_matrix::Option_list::is_of_boundary_type) {
624  Cell* pivot = _pop_pivot();
625  if (pivot != nullptr) {
626  column_.push_back(pivot);
627  std::push_heap(column_.begin(), column_.end(), cellPointerComp_);
628  return pivot->get_element();
629  }
630  return 0;
631  } else {
632  Field_element_type sum(0);
633  if (chain_opt::get_pivot() == static_cast<id_index>(-1)) return sum;
634  for (const Cell* cell : column_) {
635  if (cell->get_row_index() == chain_opt::get_pivot()) operators_->add_inplace(sum, cell->get_element());
636  }
637  return sum; // should not be 0 if properly used.
638  }
639  }
640 }
641
642 template <class Master_matrix>
643 inline typename Heap_column<Master_matrix>::iterator
644 Heap_column<Master_matrix>::begin() noexcept
645 {
646  return column_.begin();
647 }
648
649 template <class Master_matrix>
650 inline typename Heap_column<Master_matrix>::const_iterator
651 Heap_column<Master_matrix>::begin() const noexcept
652 {
653  return column_.begin();
654 }
655
656 template <class Master_matrix>
657 inline typename Heap_column<Master_matrix>::iterator
658 Heap_column<Master_matrix>::end() noexcept
659 {
660  return column_.end();
661 }
662
663 template <class Master_matrix>
664 inline typename Heap_column<Master_matrix>::const_iterator
665 Heap_column<Master_matrix>::end() const noexcept
666 {
667  return column_.end();
668 }
669
670 template <class Master_matrix>
671 inline typename Heap_column<Master_matrix>::reverse_iterator
672 Heap_column<Master_matrix>::rbegin() noexcept
673 {
674  return column_.rbegin();
675 }
676
677 template <class Master_matrix>
678 inline typename Heap_column<Master_matrix>::const_reverse_iterator
679 Heap_column<Master_matrix>::rbegin() const noexcept
680 {
681  return column_.rbegin();
682 }
683
684 template <class Master_matrix>
685 inline typename Heap_column<Master_matrix>::reverse_iterator
686 Heap_column<Master_matrix>::rend() noexcept
687 {
688  return column_.rend();
689 }
690
691 template <class Master_matrix>
692 inline typename Heap_column<Master_matrix>::const_reverse_iterator
693 Heap_column<Master_matrix>::rend() const noexcept
694 {
695  return column_.rend();
696 }
697
698 template <class Master_matrix>
699 template <class Cell_range>
700 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::operator+=(const Cell_range& column)
701 {
702  static_assert((!Master_matrix::isNonBasic || std::is_same_v<Cell_range, Heap_column>),
703  "For boundary columns, the range has to be a column of same type to help ensure the validity of the "
704  "base element."); // could be removed, if we give the responsability to the user.
705  static_assert((!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type),
706  "For chain columns, the given column cannot be constant.");
707
708  _add(column);
709
710  return *this;
711 }
712
713 template <class Master_matrix>
714 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::operator+=(Heap_column& column)
715 {
716  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
717  // assumes that the addition never zeros out this column.
718  if (_add(column)) {
719  chain_opt::swap_pivots(column);
720  dim_opt::swap_dimension(column);
721  }
722  } else {
723  _add(column);
724  }
725
726  return *this;
727 }
728
729 template <class Master_matrix>
730 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::operator*=(unsigned int v)
731 {
732  if constexpr (Master_matrix::Option_list::is_z2) {
733  if (v % 2 == 0) {
734  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
735  throw std::invalid_argument("A chain column should not be multiplied by 0.");
736  } else {
737  clear();
738  }
739  }
740  } else {
741  Field_element_type val = operators_->get_value(v);
742
743  if (val == Field_operators::get_additive_identity()) {
744  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
745  throw std::invalid_argument("A chain column should not be multiplied by 0.");
746  } else {
747  clear();
748  }
749  return *this;
750  }
751
752  if (val == Field_operators::get_multiplicative_identity()) return *this;
753
754  for (Cell* cell : column_) {
755  operators_->multiply_inplace(cell->get_element(), val);
756  }
757  }
758
759  return *this;
760 }
761
762 template <class Master_matrix>
763 template <class Cell_range>
764 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::multiply_target_and_add(
765  const Field_element_type& val, const Cell_range& column)
766 {
767  static_assert((!Master_matrix::isNonBasic || std::is_same_v<Cell_range, Heap_column>),
768  "For boundary columns, the range has to be a column of same type to help ensure the validity of the "
769  "base element."); // could be removed, if we give the responsability to the user.
770  static_assert((!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type),
771  "For chain columns, the given column cannot be constant.");
772
773  if constexpr (Master_matrix::Option_list::is_z2) {
774  if (val) {
775  _add(column);
776  } else {
777  clear();
778  _add(column);
779  }
780  } else {
781  _multiply_target_and_add(val, column);
782  }
783
784  return *this;
785 }
786
787 template <class Master_matrix>
788 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::multiply_target_and_add(
789  const Field_element_type& val, Heap_column& column)
790 {
791  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
792  // assumes that the addition never zeros out this column.
793  if constexpr (Master_matrix::Option_list::is_z2) {
794  if (val) {
795  if (_add(column)) {
796  chain_opt::swap_pivots(column);
797  dim_opt::swap_dimension(column);
798  }
799  } else {
800  throw std::invalid_argument("A chain column should not be multiplied by 0.");
801  }
802  } else {
803  if (_multiply_target_and_add(val, column)) {
804  chain_opt::swap_pivots(column);
805  dim_opt::swap_dimension(column);
806  }
807  }
808  } else {
809  if constexpr (Master_matrix::Option_list::is_z2) {
810  if (val) {
811  _add(column);
812  } else {
813  clear();
814  _add(column);
815  }
816  } else {
817  _multiply_target_and_add(val, column);
818  }
819  }
820
821  return *this;
822 }
823
824 template <class Master_matrix>
825 template <class Cell_range>
826 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::multiply_source_and_add(
827  const Cell_range& column, const Field_element_type& val)
828 {
829  static_assert((!Master_matrix::isNonBasic || std::is_same_v<Cell_range, Heap_column>),
830  "For boundary columns, the range has to be a column of same type to help ensure the validity of the "
831  "base element."); // could be removed, if we give the responsability to the user.
832  static_assert((!Master_matrix::isNonBasic || Master_matrix::Option_list::is_of_boundary_type),
833  "For chain columns, the given column cannot be constant.");
834
835  if constexpr (Master_matrix::Option_list::is_z2) {
836  if (val) {
837  _add(column);
838  }
839  } else {
840  _multiply_source_and_add(column, val);
841  }
842
843  return *this;
844 }
845
846 template <class Master_matrix>
847 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::multiply_source_and_add(
848  Heap_column& column, const Field_element_type& val)
849 {
850  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
851  // assumes that the addition never zeros out this column.
852  if constexpr (Master_matrix::Option_list::is_z2) {
853  if (val) {
854  if (_add(column)) {
855  chain_opt::swap_pivots(column);
856  dim_opt::swap_dimension(column);
857  }
858  }
859  } else {
860  if (_multiply_source_and_add(column, val)) {
861  chain_opt::swap_pivots(column);
862  dim_opt::swap_dimension(column);
863  }
864  }
865  } else {
866  if constexpr (Master_matrix::Option_list::is_z2) {
867  if (val) {
868  _add(column);
869  }
870  } else {
871  _multiply_source_and_add(column, val);
872  }
873  }
874
875  return *this;
876 }
877
878 template <class Master_matrix>
879 inline Heap_column<Master_matrix>& Heap_column<Master_matrix>::operator=(const Heap_column& other)
880 {
881  static_assert(!Master_matrix::Option_list::has_row_access, "= assignement not enabled with row access option.");
882
883  dim_opt::operator=(other);
884  chain_opt::operator=(other);
885
886  while (column_.size() > other.column_.size()) {
887  if (column_.back() != nullptr) cellPool_->destroy(column_.back());
888  column_.pop_back();
889  }
890
891  column_.resize(other.column_.size(), nullptr);
892  index i = 0;
893  for (const Cell* cell : other.column_) {
894  if (column_[i] != nullptr) {
895  cellPool_->destroy(column_[i]);
896  }
897  column_[i] = other.cellPool_->construct(cell->get_row_index());
898  if constexpr (!Master_matrix::Option_list::is_z2) {
899  column_[i]->set_element(cell->get_element());
900  }
901  ++i;
902  }
903  insertsSinceLastPrune_ = other.insertsSinceLastPrune_;
904  operators_ = other.operators_;
905  cellPool_ = other.cellPool_;
906
907  return *this;
908 }
909
910 template <class Master_matrix>
911 inline std::size_t Heap_column<Master_matrix>::compute_hash_value()
912 {
913  _prune();
914  return hash_column(*this);
915 }
916
917 template <class Master_matrix>
918 inline void Heap_column<Master_matrix>::_prune()
919 {
920  if (insertsSinceLastPrune_ == 0) return;
921
922  Column_type tempCol;
923  Cell* pivot = _pop_pivot();
924  while (pivot != nullptr) {
925  tempCol.push_back(pivot);
926  pivot = _pop_pivot();
927  }
928  column_.swap(tempCol);
929
930  insertsSinceLastPrune_ = 0;
931 }
932
933 template <class Master_matrix>
934 inline typename Heap_column<Master_matrix>::Cell*
935 Heap_column<Master_matrix>::_pop_pivot()
936 {
937  if (column_.empty()) {
938  return nullptr;
939  }
940
941  Cell* pivot = column_.front();
942  std::pop_heap(column_.begin(), column_.end(), cellPointerComp_);
943  column_.pop_back();
944  if constexpr (Master_matrix::Option_list::is_z2) {
945  while (!column_.empty() && column_.front()->get_row_index() == pivot->get_row_index()) {
946  std::pop_heap(column_.begin(), column_.end(), cellPointerComp_);
947  cellPool_->destroy(column_.back());
948  column_.pop_back();
949
950  cellPool_->destroy(pivot);
951  if (column_.empty()) {
952  return nullptr;
953  }
954  pivot = column_.front();
955  std::pop_heap(column_.begin(), column_.end(), cellPointerComp_);
956  column_.pop_back();
957  }
958  } else {
959  while (!column_.empty() && column_.front()->get_row_index() == pivot->get_row_index()) {
960  operators_->add_inplace(pivot->get_element(), column_.front()->get_element());
961  std::pop_heap(column_.begin(), column_.end(), cellPointerComp_);
962  cellPool_->destroy(column_.back());
963  column_.pop_back();
964  }
965
966  if (pivot->get_element() == Field_operators::get_additive_identity()) {
967  cellPool_->destroy(pivot);
968  return _pop_pivot();
969  }
970  }
971
972  return pivot;
973 }
974
975 template <class Master_matrix>
976 template <class Cell_range>
977 inline bool Heap_column<Master_matrix>::_add(const Cell_range& column)
978 {
979  if (column.begin() == column.end()) return false;
980  if (column_.empty()) { // chain should never enter here.
981  column_.resize(column.size());
982  index i = 0;
983  for (const Cell& cell : column) {
984  column_[i] = cellPool_->construct(cell.get_row_index());
985  if constexpr (!Master_matrix::Option_list::is_z2) {
986  column_[i]->set_element(cell.get_element());
987  }
988  ++i;
989  }
990  insertsSinceLastPrune_ = column_.size();
991  return true;
992  }
993
994  Field_element_type pivotVal(1);
995
996  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type)
997  pivotVal = get_pivot_value();
998
999  for (const Cell& cell : column) {
1000  ++insertsSinceLastPrune_;
1001  if constexpr (Master_matrix::Option_list::is_z2) {
1002  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
1003  if (cell.get_row_index() == chain_opt::get_pivot()) pivotVal = !pivotVal;
1004  }
1005  column_.push_back(cellPool_->construct(cell.get_row_index()));
1006  } else {
1007  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
1008  if (cell.get_row_index() == chain_opt::get_pivot()) operators_->add_inplace(pivotVal, cell.get_element());
1009  }
1010  column_.push_back(cellPool_->construct(cell.get_row_index()));
1011  column_.back()->set_element(cell.get_element());
1012  }
1013  std::push_heap(column_.begin(), column_.end(), cellPointerComp_);
1014  }
1015
1016  if (2 * insertsSinceLastPrune_ > column_.size()) _prune();
1017
1018  if constexpr (Master_matrix::Option_list::is_z2)
1019  return !pivotVal;
1020  else
1021  return pivotVal == Field_operators::get_additive_identity();
1022 }
1023
1024 template <class Master_matrix>
1025 template <class Cell_range>
1026 inline bool Heap_column<Master_matrix>::_multiply_target_and_add(const Field_element_type& val,
1027  const Cell_range& column)
1028 {
1029  if (val == 0u) {
1030  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
1031  throw std::invalid_argument("A chain column should not be multiplied by 0.");
1032  // this would not only mess up the base, but also the pivots stored.
1033  } else {
1034  clear();
1035  }
1036  }
1037  if (column_.empty()) { // chain should never enter here.
1038  column_.resize(column.size());
1039  index i = 0;
1040  for (const Cell& cell : column) {
1041  column_[i] = cellPool_->construct(cell.get_row_index());
1042  column_[i++]->set_element(cell.get_element());
1043  }
1044  insertsSinceLastPrune_ = column_.size();
1045  return true;
1046  }
1047
1048  Field_element_type pivotVal(0);
1049
1050  for (Cell* cell : column_) {
1051  operators_->multiply_inplace(cell->get_element(), val);
1052  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
1053  if (cell->get_row_index() == chain_opt::get_pivot()) operators_->add_inplace(pivotVal, cell->get_element());
1054  }
1055  }
1056
1057  for (const Cell& cell : column) {
1058  ++insertsSinceLastPrune_;
1059  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
1060  if (cell.get_row_index() == chain_opt::get_pivot()) operators_->add_inplace(pivotVal, cell.get_element());
1061  }
1062  column_.push_back(cellPool_->construct(cell.get_row_index()));
1063  column_.back()->set_element(cell.get_element());
1064  std::push_heap(column_.begin(), column_.end(), cellPointerComp_);
1065  }
1066
1067  if (2 * insertsSinceLastPrune_ > column_.size()) _prune();
1068
1069  if constexpr (Master_matrix::Option_list::is_z2)
1070  return !pivotVal;
1071  else
1072  return pivotVal == Field_operators::get_additive_identity();
1073 }
1074
1075 template <class Master_matrix>
1076 template <class Cell_range>
1077 inline bool Heap_column<Master_matrix>::_multiply_source_and_add(const Cell_range& column,
1078  const Field_element_type& val)
1079 {
1080  if (val == 0u || column.begin() == column.end()) {
1081  return false;
1082  }
1083  if (column_.empty()) { // chain should never enter here.
1084  column_.resize(column.size());
1085  index i = 0;
1086  for (const Cell& cell : column) {
1087  column_[i] = cellPool_->construct(cell.get_row_index());
1088  column_[i++]->set_element(cell.get_element());
1089  }
1090  insertsSinceLastPrune_ = column_.size();
1091  return true;
1092  }
1093
1094  Field_element_type pivotVal(1);
1095
1096  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type)
1097  pivotVal = get_pivot_value();
1098
1099  for (const Cell& cell : column) {
1100  ++insertsSinceLastPrune_;
1101  column_.push_back(cellPool_->construct(cell.get_row_index()));
1102  column_.back()->set_element(cell.get_element());
1103  operators_->multiply_inplace(column_.back()->get_element(), val);
1104  if constexpr (Master_matrix::isNonBasic && !Master_matrix::Option_list::is_of_boundary_type) {
1105  if (cell.get_row_index() == chain_opt::get_pivot()){
1106  operators_->add_inplace(pivotVal, column_.back()->get_element());
1107  }
1108  }
1109  std::push_heap(column_.begin(), column_.end(), cellPointerComp_);
1110  }
1111
1112  if (2 * insertsSinceLastPrune_ > column_.size()) _prune();
1113
1114  return pivotVal == 0u;
1115 }
1116
1117 } // namespace persistence_matrix
1118 } // namespace Gudhi
1119
1128 template <class Master_matrix>
1129 struct std::hash<Gudhi::persistence_matrix::Heap_column<Master_matrix> >
1130 {
1131  size_t operator()(Gudhi::persistence_matrix::Heap_column<Master_matrix>& column) const {
1132  return column.compute_hash_value();
1133  }
1134 };
1135
1136 #endif // PM_HEAP_COLUMN_H
Contains the New_cell_constructor and Pool_cell_constructor structures.
Column class following the PersistenceMatrixColumn concept. Not compatible with row access.
Definition: heap_column.h:50
Chain_column_extra_properties Chain_column_option
If PersistenceMatrixOptions::is_of_boundary_type is false, and, PersistenceMatrixOptions::has_column_...
Definition: PersistenceMatrixColumn.h:45
Column_dimension_holder Column_dimension_option
If PersistenceMatrixOptions::has_column_pairings or PersistenceMatrixOptions::has_vine_update or Pers...
Definition: PersistenceMatrixColumn.h:36
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
