add_to(const Cell_range_or_column_index &sourceColumn, index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Base_matrix(Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Base_matrix(const std::vector< Container_type > &columns, Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Base_matrix(unsigned int numberOfColumns, Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Base_matrix(const Base_matrix &matrixToCopy, Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Base_matrix(Base_matrix &&other) noexcept | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Cell_constructor typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
Column_settings typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
Column_type typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
container_type typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
dimension_type typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
erase_empty_row(index rowIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Field_element_type typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
Field_operators typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
get_column(index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
get_number_of_columns() const | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
get_row(index rowIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
index typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
insert_boundary(const Boundary_type &boundary, dimension_type dim=-1) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
insert_column(const Container_type &column) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
insert_column(const Container_type &column, index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
is_zero_cell(index columnIndex, index rowIndex) const | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
is_zero_column(index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
multiply_source_and_add_to(const Field_element_type &coefficient, const Cell_range_or_column_index &sourceColumn, index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
multiply_target_and_add_to(const Cell_range_or_column_index &sourceColumn, const Field_element_type &coefficient, index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
operator=(const Base_matrix &other) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
remove_column(index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
remove_last() | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
reset(Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
Row_type typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
swap(Base_matrix &matrix1, Base_matrix &matrix2) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | friend |
zero_cell(index columnIndex, index rowIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
