base_matrix.h
Go to the documentation of this file.
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Hannah Schreiber
4  *
5  * Copyright (C) 2022-24 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
17 #ifndef PM_BASE_MATRIX_H
18 #define PM_BASE_MATRIX_H
19
20 #include <iostream> //print() only
21 #include <vector>
22 #include <utility> //std::swap, std::move & std::exchange
23
24 namespace Gudhi {
25 namespace persistence_matrix {
26
36 template <class Master_matrix>
37 class Base_matrix : public Master_matrix::template Base_swap_option<Base_matrix<Master_matrix> >,
38  protected Master_matrix::Matrix_row_access_option
39 {
40  public:
41  using index = typename Master_matrix::index;
42  using dimension_type = typename Master_matrix::dimension_type;
46  using Field_operators = typename Master_matrix::Field_operators;
47  using Field_element_type = typename Master_matrix::element_type;
48  using Column_type = typename Master_matrix::Column_type;
49  using container_type = typename Master_matrix::boundary_type;
50  using Row_type = typename Master_matrix::Row_type;
52  using Cell_constructor = typename Master_matrix::Cell_constructor;
53  using Column_settings = typename Master_matrix::Column_settings;
62  Base_matrix(Column_settings* colSettings);
73  template <class Container_type = container_type>
74  Base_matrix(const std::vector<Container_type>& columns,
75  Column_settings* colSettings);
83  Base_matrix(unsigned int numberOfColumns, Column_settings* colSettings);
93  Base_matrix(const Base_matrix& matrixToCopy,
94  Column_settings* colSettings = nullptr);
100  Base_matrix(Base_matrix&& other) noexcept;
101
110  template <class Container_type = container_type>
111  void insert_column(const Container_type& column);
123  template <class Container_type = container_type>
124  void insert_column(const Container_type& column, index columnIndex);
133  template <class Boundary_type>
134  void insert_boundary(const Boundary_type& boundary, dimension_type dim = -1);
146  Column_type& get_column(index columnIndex);
159  Row_type& get_row(index rowIndex);
173  void remove_column(index columnIndex);
190  void remove_last();
206  void erase_empty_row(index rowIndex);
207
214
223  template <class Cell_range_or_column_index>
224  void add_to(const Cell_range_or_column_index& sourceColumn, index targetColumnIndex);
235  template <class Cell_range_or_column_index>
236  void multiply_target_and_add_to(const Cell_range_or_column_index& sourceColumn,
237  const Field_element_type& coefficient,
238  index targetColumnIndex);
249  template <class Cell_range_or_column_index>
250  void multiply_source_and_add_to(const Field_element_type& coefficient,
251  const Cell_range_or_column_index& sourceColumn,
252  index targetColumnIndex);
253
260  void zero_cell(index columnIndex, index rowIndex);
266  void zero_column(index columnIndex);
275  bool is_zero_cell(index columnIndex, index rowIndex) const;
283  bool is_zero_column(index columnIndex);
284
291  void reset(Column_settings* colSettings) {
292  matrix_.clear();
293  nextInsertIndex_ = 0;
294  colSettings_ = colSettings;
295  }
296
300  Base_matrix& operator=(const Base_matrix& other);
304  friend void swap(Base_matrix& matrix1, Base_matrix& matrix2) {
305  swap(static_cast<typename Master_matrix::template Base_swap_option<Base_matrix<Master_matrix> >&>(matrix1),
306  static_cast<typename Master_matrix::template Base_swap_option<Base_matrix<Master_matrix> >&>(matrix2));
307  matrix1.matrix_.swap(matrix2.matrix_);
308  std::swap(matrix1.nextInsertIndex_, matrix2.nextInsertIndex_);
309  std::swap(matrix1.colSettings_, matrix2.colSettings_);
310
312  swap(static_cast<typename Master_matrix::Matrix_row_access_option&>(matrix1),
313  static_cast<typename Master_matrix::Matrix_row_access_option&>(matrix2));
314  }
315  }
316
317  void print(); // for debug
318
319  private:
320  using swap_opt = typename Master_matrix::template Base_swap_option<Base_matrix<Master_matrix> >;
321  using ra_opt = typename Master_matrix::Matrix_row_access_option;
322  using matrix_type = typename Master_matrix::column_container_type;
323  using cell_rep_type =
324  typename std::conditional<Master_matrix::Option_list::is_z2,
325  index,
326  std::pair<index, Field_element_type>
327  >::type;
328
329  friend swap_opt; // direct access to matrix_ to avoid row reorder.
330
331  matrix_type matrix_;
332  index nextInsertIndex_;
333  Column_settings* colSettings_;
335  template <class Container_type = container_type>
336  void _insert(const Container_type& column, index columnIndex, dimension_type dim);
337  void _orderRowsIfNecessary();
338  const Column_type& _get_column(index columnIndex) const;
339  Column_type& _get_column(index columnIndex);
340  index _get_real_row_index(index rowIndex) const;
341  template <class Container_type>
342  void _container_insert(const Container_type& column, index pos, dimension_type dim);
343  void _container_insert(const Column_type& column, [[maybe_unused]] index pos = 0);
344 };
345
346 template <class Master_matrix>
348  : swap_opt(), ra_opt(), nextInsertIndex_(0), colSettings_(colSettings)
349 {}
350
351 template <class Master_matrix>
352 template <class Container_type>
353 inline Base_matrix<Master_matrix>::Base_matrix(const std::vector<Container_type>& columns,
354  Column_settings* colSettings)
355  : swap_opt(columns.size()),
356  // not ideal if max row index is much smaller than max column index, does that happen often?
357  ra_opt(columns.size()),
358  matrix_(!Master_matrix::Option_list::has_map_column_container && Master_matrix::Option_list::has_row_access
359  ? 0
360  : columns.size()),
361  nextInsertIndex_(columns.size()),
362  colSettings_(colSettings)
363 {
365  matrix_.reserve(columns.size());
366
367  for (index i = 0; i < columns.size(); i++) {
368  _container_insert(columns[i], i, columns[i].size() == 0 ? 0 : columns[i].size() - 1);
369  }
370 }
371
372 template <class Master_matrix>
373 inline Base_matrix<Master_matrix>::Base_matrix(unsigned int numberOfColumns,
374  Column_settings* colSettings)
375  : swap_opt(numberOfColumns),
376  ra_opt(numberOfColumns),
377  matrix_(!Master_matrix::Option_list::has_map_column_container && Master_matrix::Option_list::has_row_access
378  ? 0
379  : numberOfColumns),
380  nextInsertIndex_(0),
381  colSettings_(colSettings)
382 {
384  matrix_.reserve(numberOfColumns);
385 }
386
387 template <class Master_matrix>
389  Column_settings* colSettings)
390  : swap_opt(static_cast<const swap_opt&>(matrixToCopy)),
391  ra_opt(static_cast<const ra_opt&>(matrixToCopy)),
392  nextInsertIndex_(matrixToCopy.nextInsertIndex_),
393  colSettings_(colSettings == nullptr ? matrixToCopy.colSettings_ : colSettings)
394 {
395  matrix_.reserve(matrixToCopy.matrix_.size());
396  for (const auto& cont : matrixToCopy.matrix_){
398  _container_insert(cont.second, cont.first);
399  } else {
400  _container_insert(cont);
401  }
402  }
403 }
404
405 template <class Master_matrix>
407  : swap_opt(std::move(static_cast<swap_opt&>(other))),
408  ra_opt(std::move(static_cast<ra_opt&>(other))),
409  matrix_(std::move(other.matrix_)),
410  nextInsertIndex_(std::exchange(other.nextInsertIndex_, 0)),
411  colSettings_(std::exchange(other.colSettings_, nullptr))
412 {}
413
414 template <class Master_matrix>
415 template <class Container_type>
416 inline void Base_matrix<Master_matrix>::insert_column(const Container_type& column)
417 {
418  //TODO: dim not actually stored right now, so either get rid of it or store it again
419  _insert(column, nextInsertIndex_, column.size() == 0 ? 0 : column.size() - 1);
420  ++nextInsertIndex_;
421 }
422
423 template <class Master_matrix>
424 template <class Container_type>
425 inline void Base_matrix<Master_matrix>::insert_column(const Container_type& column, index columnIndex)
426 {
427  static_assert(!Master_matrix::Option_list::has_row_access,
428  "Columns have to be inserted at the end of the matrix when row access is enabled.");
429
430  if (columnIndex >= nextInsertIndex_) nextInsertIndex_ = columnIndex + 1;
431  //TODO: dim not actually stored right now, so either get rid of it or store it again
432  _insert(column, columnIndex, column.size() == 0 ? 0 : column.size() - 1);
433 }
434
435 template <class Master_matrix>
436 template <class Boundary_type>
437 inline void Base_matrix<Master_matrix>::insert_boundary(const Boundary_type& boundary, dimension_type dim)
438 {
439  if (dim == -1) dim = boundary.size() == 0 ? 0 : boundary.size() - 1;
440  //TODO: dim not actually stored right now, so either get rid of it or store it again
441  _insert(boundary, nextInsertIndex_++, dim);
442 }
443
444 template <class Master_matrix>
446 {
447  _orderRowsIfNecessary();
448  return _get_column(columnIndex);
449 }
450
451 template <class Master_matrix>
453 {
454  static_assert(Master_matrix::Option_list::has_row_access, "Row access has to be enabled for this method.");
455
456  _orderRowsIfNecessary();
457  return ra_opt::get_row(rowIndex);
458 }
459
460 template <class Master_matrix>
462 {
463  static_assert(Master_matrix::Option_list::has_map_column_container,
464  "'remove_column' is not implemented for the chosen options.");
465
466  // assumes that eventual "holes" left at unused indices are considered as empty columns.
467  if (columnIndex == nextInsertIndex_ - 1) --nextInsertIndex_;
468
469  matrix_.erase(columnIndex);
470 }
471
472 template <class Master_matrix>
474 {
475  if (nextInsertIndex_ == 0) return; //empty matrix
476  --nextInsertIndex_; // assumes that eventual "holes" left at unused indices are considered as empty columns.
477
478  if constexpr (Master_matrix::Option_list::has_map_column_container) {
479  matrix_.erase(nextInsertIndex_);
480  } else {
481  if constexpr (Master_matrix::Option_list::has_row_access) {
482  GUDHI_CHECK(nextInsertIndex_ == matrix_.size() - 1,
483  std::logic_error("Base_matrix::remove_last - Indexation problem."));
484  matrix_.pop_back();
485  } else {
486  matrix_[nextInsertIndex_].clear();
487  }
488  }
489 }
490
491 template <class Master_matrix>
493 {
494  if constexpr (Master_matrix::Option_list::has_row_access && Master_matrix::Option_list::has_removable_rows) {
495  ra_opt::erase_empty_row(_get_real_row_index(rowIndex));
496  }
497  if constexpr ((Master_matrix::Option_list::has_column_and_row_swaps || Master_matrix::Option_list::has_vine_update) &&
498  Master_matrix::Option_list::has_map_column_container) {
499  auto it = swap_opt::indexToRow_.find(rowIndex);
500  swap_opt::rowToIndex_.erase(it->second);
501  swap_opt::indexToRow_.erase(it);
502  }
503 }
504
505 template <class Master_matrix>
507 {
508  if constexpr (Master_matrix::Option_list::has_map_column_container) {
509  return matrix_.size();
510  } else {
511  return nextInsertIndex_; // matrix could have been resized much bigger while insert
512  }
513 }
514
515 template <class Master_matrix>
516 template <class Cell_range_or_column_index>
517 inline void Base_matrix<Master_matrix>::add_to(const Cell_range_or_column_index& sourceColumn,
518  index targetColumnIndex)
519 {
520  if constexpr (std::is_integral_v<Cell_range_or_column_index>) {
521  _get_column(targetColumnIndex) += _get_column(sourceColumn);
522  } else {
523  _get_column(targetColumnIndex) += sourceColumn;
524  }
525 }
526
527 template <class Master_matrix>
528 template <class Cell_range_or_column_index>
529 inline void Base_matrix<Master_matrix>::multiply_target_and_add_to(const Cell_range_or_column_index& sourceColumn,
530  const Field_element_type& coefficient,
531  index targetColumnIndex)
532 {
533  if constexpr (std::is_integral_v<Cell_range_or_column_index>) {
534  _get_column(targetColumnIndex).multiply_target_and_add(coefficient, _get_column(sourceColumn));
535  } else {
536  _get_column(targetColumnIndex).multiply_target_and_add(coefficient, sourceColumn);
537  }
538 }
539
540 template <class Master_matrix>
541 template <class Cell_range_or_column_index>
543  const Cell_range_or_column_index& sourceColumn,
544  index targetColumnIndex)
545 {
546  if constexpr (std::is_integral_v<Cell_range_or_column_index>) {
547  _get_column(targetColumnIndex).multiply_source_and_add(_get_column(sourceColumn), coefficient);
548  } else {
549  _get_column(targetColumnIndex).multiply_source_and_add(sourceColumn, coefficient);
550  }
551 }
552
553 template <class Master_matrix>
554 inline void Base_matrix<Master_matrix>::zero_cell(index columnIndex, index rowIndex)
555 {
556  _get_column(columnIndex).clear(_get_real_row_index(rowIndex));
557 }
558
559 template <class Master_matrix>
561  _get_column(columnIndex).clear();
562 }
563
564 template <class Master_matrix>
565 inline bool Base_matrix<Master_matrix>::is_zero_cell(index columnIndex, index rowIndex) const
566 {
567  return !(_get_column(columnIndex).is_non_zero(_get_real_row_index(rowIndex)));
568 }
569
570 template <class Master_matrix>
572 {
573  return _get_column(columnIndex).is_empty();
574 }
575
576 template <class Master_matrix>
578 {
579  swap_opt::operator=(other);
580  ra_opt::operator=(other);
581  matrix_.clear();
582  nextInsertIndex_ = other.nextInsertIndex_;
583  colSettings_ = other.colSettings_;
584
585  matrix_.reserve(other.matrix_.size());
586  for (const auto& cont : other.matrix_){
587  if constexpr (Master_matrix::Option_list::has_map_column_container){
588  _container_insert(cont.second, cont.first);
589  } else {
590  _container_insert(cont);
591  }
592  }
593
594  return *this;
595 }
596
597 template <class Master_matrix>
599 {
600  _orderRowsIfNecessary();
601  std::cout << "Base_matrix:\n";
602  for (index i = 0; i < nextInsertIndex_; ++i) {
603  const Column_type& col = matrix_[i];
604  for (const auto& e : col.get_content(nextInsertIndex_)) {
605  if (e == 0u)
606  std::cout << "- ";
607  else
608  std::cout << e << " ";
609  }
610  std::cout << "\n";
611  }
612  std::cout << "\n";
613  if constexpr (Master_matrix::Option_list::has_row_access) {
614  std::cout << "Row Matrix:\n";
615  for (index i = 0; i < nextInsertIndex_; ++i) {
616  const auto& row = ra_opt::rows_[i];
617  for (const auto& cell : row) {
618  std::cout << cell.get_column_index() << " ";
619  }
620  std::cout << "(" << i << ")\n";
621  }
622  std::cout << "\n";
623  }
624 }
625
626 template <class Master_matrix>
627 template <class Container_type>
628 inline void Base_matrix<Master_matrix>::_insert(const Container_type& column, index columnIndex, dimension_type dim)
629 {
630  _orderRowsIfNecessary();
631
632  //resize of containers when necessary:
633  index pivot = 0;
634  if (column.begin() != column.end()) {
635  //first, compute pivot of `column`
636  if constexpr (Master_matrix::Option_list::is_z2) {
637  pivot = *std::prev(column.end());
638  } else {
639  pivot = std::prev(column.end())->first;
640  }
641  //row container
642  if constexpr (Master_matrix::Option_list::has_row_access && !Master_matrix::Option_list::has_removable_rows)
643  if (ra_opt::rows_->size() <= pivot) ra_opt::rows_->resize(pivot + 1);
644  }
645
646  //row swap map containers
647  if constexpr (Master_matrix::Option_list::has_map_column_container) {
648  if constexpr (Master_matrix::Option_list::has_column_and_row_swaps || Master_matrix::Option_list::has_vine_update) {
649  for (auto id : column) {
650  index idx;
651  if constexpr (Master_matrix::Option_list::is_z2) {
652  idx = id;
653  } else {
654  idx = id.first;
655  }
656  swap_opt::indexToRow_[idx] = idx;
657  swap_opt::rowToIndex_[idx] = idx;
658  }
659  }
660  } else {
661  if constexpr (Master_matrix::Option_list::has_column_and_row_swaps || Master_matrix::Option_list::has_vine_update) {
662  index size = swap_opt::indexToRow_.size();
663  if (size <= pivot) {
664  for (index i = size; i <= pivot; i++) {
665  swap_opt::indexToRow_.push_back(i);
666  swap_opt::rowToIndex_.push_back(i);
667  }
668  }
669  }
670  //column container
671  if constexpr (!Master_matrix::Option_list::has_row_access) {
672  if (matrix_.size() <= columnIndex) {
673  matrix_.resize(columnIndex + 1);
674  }
675  }
676  }
677
678  _container_insert(column, columnIndex, dim);
679 }
680
681 template <class Master_matrix>
683 {
684  if constexpr (Master_matrix::Option_list::has_column_and_row_swaps || Master_matrix::Option_list::has_vine_update) {
685  if (swap_opt::rowSwapped_) swap_opt::_orderRows();
686  }
687 }
688
689 template <class Master_matrix>
691  index columnIndex) const
692 {
693  if constexpr (Master_matrix::Option_list::has_map_column_container) {
694  return matrix_.at(columnIndex);
695  } else {
696  return matrix_[columnIndex];
697  }
698 }
699
700 template <class Master_matrix>
702 {
703  if constexpr (Master_matrix::Option_list::has_map_column_container) {
704  return matrix_.at(columnIndex);
705  } else {
706  return matrix_[columnIndex];
707  }
708 }
709
710 template <class Master_matrix>
712 {
713  if constexpr (Master_matrix::Option_list::has_column_and_row_swaps || Master_matrix::Option_list::has_vine_update) {
714  if constexpr (Master_matrix::Option_list::has_map_column_container) {
715  return swap_opt::indexToRow_.at(rowIndex);
716  } else {
717  return swap_opt::indexToRow_[rowIndex];
718  }
719  } else {
720  return rowIndex;
721  }
722 }
723
724 template <class Master_matrix>
725 template <class Container_type>
726 inline void Base_matrix<Master_matrix>::_container_insert(const Container_type& column, index pos, dimension_type dim){
727  if constexpr (Master_matrix::Option_list::has_map_column_container) {
728  if constexpr (Master_matrix::Option_list::has_row_access) {
729  matrix_.try_emplace(pos, Column_type(pos, column, dim, ra_opt::rows_, colSettings_));
730  } else {
731  matrix_.try_emplace(pos, Column_type(column, dim, colSettings_));
732  }
733  } else {
734  if constexpr (Master_matrix::Option_list::has_row_access) {
735  matrix_.emplace_back(pos, column, dim, ra_opt::rows_, colSettings_);
736  } else {
737  matrix_[pos] = Column_type(column, dim, colSettings_);
738  }
739  }
740 }
741
742 template <class Master_matrix>
743 inline void Base_matrix<Master_matrix>::_container_insert(const Column_type& column, [[maybe_unused]] index pos){
744  if constexpr (Master_matrix::Option_list::has_map_column_container) {
745  if constexpr (Master_matrix::Option_list::has_row_access) {
746  matrix_.try_emplace(pos, Column_type(column, column.get_column_index(), ra_opt::rows_, colSettings_));
747  } else {
748  matrix_.try_emplace(pos, Column_type(column, colSettings_));
749  }
750  } else {
751  if constexpr (Master_matrix::Option_list::has_row_access) {
752  matrix_.emplace_back(column, column.get_column_index(), ra_opt::rows_, colSettings_);
753  } else {
754  matrix_.emplace_back(column, colSettings_);
755  }
756  }
757 }
758
759 } // namespace persistence_matrix
760 } // namespace Gudhi
761
762 #endif // PM_BASE_MATRIX_H
A basic matrix structure allowing to easily manipulate and access entire columns and rows,...
Definition: base_matrix.h:39
void insert_column(const Container_type &column)
Inserts a new ordered column at the end of the matrix by copying the given range of Matrix::cell_rep_...
Definition: base_matrix.h:416
void add_to(const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
Adds column represented by sourceColumn onto the column at targetColumnIndex in the matrix.
Definition: base_matrix.h:517
friend void swap(Base_matrix &matrix1, Base_matrix &matrix2)
Swap operator.
Definition: base_matrix.h:304
typename Master_matrix::dimension_type dimension_type
Definition: base_matrix.h:42
Row_type & get_row(index rowIndex)
Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row ...
Definition: base_matrix.h:452
Indicates if the column at given index has value zero.
Definition: base_matrix.h:571
Only available if PersistenceMatrixOptions::has_map_column_container is true. Otherwise,...
Definition: base_matrix.h:461
void reset(Column_settings *colSettings)
Resets the matrix to an empty matrix.
Definition: base_matrix.h:291
index get_number_of_columns() const
Returns the current number of columns in the matrix.
Definition: base_matrix.h:506
Base_matrix & operator=(const Base_matrix &other)
Assign operator.
Definition: base_matrix.h:577
typename Master_matrix::Field_operators Field_operators
Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false.
typename Master_matrix::index index
void remove_last()
Removes the last column from the matrix. The last column is at index , where:
Definition: base_matrix.h:473
typename Master_matrix::Column_settings Column_settings
Definition: base_matrix.h:54
typename Master_matrix::boundary_type container_type
Definition: base_matrix.h:49
void multiply_target_and_add_to(const Cell_range_or_column_index &sourceColumn, const Field_element_type &coefficient, index targetColumnIndex)
Multiplies the target column with the coefficiant and then adds the source column to it....
Definition: base_matrix.h:529
void insert_boundary(const Boundary_type &boundary, dimension_type dim=-1)
Same as insert_column, only for interface purposes. The given dimension is ignored and not stored.
Definition: base_matrix.h:437
If PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true...
Definition: base_matrix.h:492
typename Master_matrix::Row_type Row_type
Base_matrix(Column_settings *colSettings)
Constructs an empty matrix.
Definition: base_matrix.h:347
Zeroes the cell at the given coordinates.
Definition: base_matrix.h:554
Zeroes the column at the given index.
Definition: base_matrix.h:560
Column_type & get_column(index columnIndex)
Returns the column at the given MatIdx index. The type of the column depends on the choosen options,...
Definition: base_matrix.h:445
void multiply_source_and_add_to(const Field_element_type &coefficient, const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
Multiplies the source column with the coefficiant before adding it to the target column....
Definition: base_matrix.h:542
typename Master_matrix::Column_type Column_type
Definition: base_matrix.h:48
Indicates if the cell at given coordinates has value zero.
Definition: base_matrix.h:565
typename Master_matrix::Cell_constructor Cell_constructor
typename Master_matrix::element_type Field_element_type
Data structure for matrices, and in particular thought for matrices representing filtered complexes i...
Definition: matrix.h:143
typename std::conditional< PersistenceMatrixOptions::has_intrusive_rows, boost::intrusive::list< Cell_type, boost::intrusive::constant_time_size< false >, boost::intrusive::base_hook< base_hook_matrix_row > >, std::set< Cell_type, RowCellComp > >::type Row_type
Type of the rows stored in the matrix. Is either an intrusive list of Cell_type (not ordered) if Pers...
Definition: matrix.h:281
typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::HEAP, Heap_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::LIST, List_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::SET, Set_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::UNORDERED_SET, Unordered_set_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::VECTOR, Vector_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::INTRUSIVE_LIST, Intrusive_list_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::NAIVE_VECTOR, Naive_vector_column_type, Intrusive_set_column_type >::type >::type >::type >::type >::type >::type >::type Column_type
Type of the columns stored in the matrix. The type depends on the value of PersistenceMatrixOptions::...
Definition: matrix.h:370
typename PersistenceMatrixOptions::index_type index
Definition: matrix.h:146
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
static const bool has_map_column_container
If set to true, the underlying container containing the matrix columns is an std::unordered_map....
Definition: PersistenceMatrixOptions.h:101
static const bool has_row_access
If set to true, enables the method Matrix::get_row.
Definition: PersistenceMatrixOptions.h:111
static const bool is_z2
If true, indicates that the values contained in the matrix are in and can therefore be treated like ...
Definition: PersistenceMatrixOptions.h:56
