11 #ifndef FREUDENTHAL_TRIANGULATION_H_
12 #define FREUDENTHAL_TRIANGULATION_H_
20 #include <Eigen/Eigenvalues>
23 #include <gudhi/Permutahedral_representation.h>
24 #include <gudhi/Debug_utils.h>
28 namespace coxeter_triangulation {
44 template <
class Permutahedral_representation_ =
45 Permutahedral_representation<std::vector<int>, std::vector<std::vector<std::size_t> > > >
47 using Matrix = Eigen::MatrixXd;
48 using Vector = Eigen::VectorXd;
62 is_freudenthal_ =
true;
87 colpivhouseholderqr_(matrix_.colPivHouseholderQr()),
88 is_freudenthal_(false) {
89 GUDHI_CHECK(
dimension == offset_.size(), std::invalid_argument(
"Offset must be of size 'dimension'"));
96 const Matrix&
matrix()
const {
return matrix_; }
99 const Vector&
offset()
const {
return offset_; }
106 colpivhouseholderqr_ =
matrix.colPivHouseholderQr();
107 is_freudenthal_ =
false;
115 is_freudenthal_ =
false;
134 template <
class Po
int_d>
137 using Part =
typename Ordered_set_partition::value_type;
138 unsigned d = point.size();
139 GUDHI_CHECK(d == dimension_,
140 std::invalid_argument(
"The point must be of the same dimension as the triangulation"));
143 std::vector<double> z;
144 if (is_freudenthal_) {
145 for (std::size_t i = 0; i < d; i++) {
146 double x_i = scale * point[i];
147 int y_i = std::floor(x_i);
148 output.vertex().push_back(y_i);
149 z.push_back(x_i - y_i);
152 Eigen::VectorXd p_vect(d);
153 for (std::size_t i = 0; i < d; i++) p_vect(i) = point[i];
154 Eigen::VectorXd x_vect = colpivhouseholderqr_.solve(p_vect - offset_);
155 for (std::size_t i = 0; i < d; i++) {
156 double x_i = scale * x_vect(i);
157 int y_i = std::floor(x_i);
158 output.vertex().push_back(y_i);
159 z.push_back(x_i - y_i);
164 std::iota(indices.begin(), indices.end(), 0);
165 std::sort(indices.begin(), indices.end(), [&z](std::size_t i1, std::size_t i2) { return z[i1] > z[i2]; });
167 output.partition().push_back(Part(1, indices[0]));
168 for (std::size_t i = 1; i <= d; ++i)
169 if (z[indices[i - 1]] > z[indices[i]] + error)
170 output.partition().push_back(Part(1, indices[i]));
172 output.partition().back().push_back(indices[i]);
185 Eigen::VectorXd v_vect(dimension_);
186 for (std::size_t j = 0; j < dimension_; j++) v_vect(j) = vertex[j] / scale;
187 return matrix_ * v_vect + offset_;
199 Eigen::VectorXd res_vector(dimension_);
200 res_vector.setZero(dimension_, 1);
201 for (
auto v : simplex.vertex_range()) {
204 return (1. / (simplex.dimension() + 1)) * res_vector;
211 Eigen::ColPivHouseholderQR<Matrix> colpivhouseholderqr_;
212 bool is_freudenthal_;
A class that stores any affine transformation of the Freudenthal-Kuhn triangulation.
Definition: Freudenthal_triangulation.h:46
Freudenthal_triangulation(unsigned dimension, const Matrix &matrix, const Vector &offset)
Constructor of the Freudenthal-Kuhn triangulation of a given dimension under an affine transformation...
Definition: Freudenthal_triangulation.h:83
const Vector & offset() const
Vector that defines the offset of the triangulation.
Definition: Freudenthal_triangulation.h:99
Eigen::VectorXd barycenter(const Simplex_handle &simplex, double scale=1) const
Returns the Cartesian coordinates of the barycenter of a given simplex.
Definition: Freudenthal_triangulation.h:198
Simplex_handle locate_point(const Point_d &point, double scale=1) const
Returns the permutahedral representation of the simplex in the triangulation that contains a given qu...
Definition: Freudenthal_triangulation.h:135
typename Permutahedral_representation_::Vertex Vertex_handle
Type of the vertices in the triangulation.
Definition: Freudenthal_triangulation.h:55
Freudenthal_triangulation(std::size_t dimension)
Constructor of the Freudenthal-Kuhn triangulation of a given dimension.
Definition: Freudenthal_triangulation.h:60
Freudenthal_triangulation(std::size_t dimension, const Matrix &matrix)
Constructor of the Freudenthal-Kuhn triangulation of a given dimension under a linear transformation ...
Definition: Freudenthal_triangulation.h:71
Permutahedral_representation_ Simplex_handle
Type of the simplices in the triangulation.
Definition: Freudenthal_triangulation.h:52
void change_offset(const Eigen::VectorXd &offset)
Change the offset vector to a given value.
Definition: Freudenthal_triangulation.h:113
Eigen::VectorXd cartesian_coordinates(const Vertex_handle &vertex, double scale=1) const
Returns the Cartesian coordinates of the given vertex.
Definition: Freudenthal_triangulation.h:184
const Matrix & matrix() const
Matrix that defines the linear transformation of the triangulation.
Definition: Freudenthal_triangulation.h:96
unsigned dimension() const
Dimension of the triangulation.
Definition: Freudenthal_triangulation.h:93
void change_matrix(const Eigen::MatrixXd &matrix)
Change the linear transformation matrix to a given value.
Definition: Freudenthal_triangulation.h:104
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
Class that represents an ordered set partition of a set {0,...,n-1} in k parts as a pair of an unorde...
Definition: Ordered_set_partition_iterator.h:32
