Contains the Matrix_max_dimension_holder Matrix_all_dimension_holder classes and the Dummy_matrix_dimension_holder structure. More...
Go to the source code of this file.
Classes | |
| struct | Gudhi::persistence_matrix::Dummy_matrix_dimension_holder |
| Empty structure. Inheritated instead of Matrix_max_dimension_holder or Matrix_all_dimension_holder, when the maximal dimension of a matrix is not stored. More... | |
| class | Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type > |
| Class managing the maximal dimension of a face represented in the inheritating matrix, when the option of face removal is not enabled. More... | |
| class | Gudhi::persistence_matrix::Matrix_all_dimension_holder< dimension_type > |
| Class managing the maximal dimension of a face represented in the inheritating matrix, when the option of face removal is enabled. More... | |
Namespaces | |
| Gudhi | |
| Gudhi namespace. | |
| Gudhi::persistence_matrix | |
| Persistence matrix namespace. | |
