Contains the Heap_column class. Also defines the std::hash method for Heap_column. More...
Go to the source code of this file.
Classes | |
| class | Gudhi::persistence_matrix::Heap_column< Master_matrix > |
| Column class following the PersistenceMatrixColumn concept. Not compatible with row access. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Heap_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Heap_column. More... | |
Namespaces | |
| Gudhi | |
| Gudhi namespace. | |
| Gudhi::persistence_matrix | |
| Persistence matrix namespace. | |
