| add_to(index sourceColumnIndex, index targetColumnIndex) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| boundary_type typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| Cell_constructor typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| Column_settings typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| Column_type typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| dimension_type typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| erase_empty_row(index rowIndex) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| Field_element_type typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| Field_operators typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| get_column(index columnIndex, bool inR=true) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| get_column_dimension(index columnIndex) const | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| get_column_with_pivot(index faceIndex) const | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| get_max_dimension() const | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| get_number_of_columns() const | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| get_pivot(index columnIndex) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| get_row(index rowIndex, bool inR=true) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| id_index typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| insert_boundary(const Boundary_type &boundary, dimension_type dim=-1) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| insert_boundary(id_index faceIndex, const Boundary_type &boundary, dimension_type dim=-1) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| is_zero_cell(index columnIndex, index rowIndex, bool inR=true) const | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| is_zero_column(index columnIndex, bool inR=true) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| multiply_source_and_add_to(const Field_element_type &coefficient, index sourceColumnIndex, index targetColumnIndex) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| multiply_target_and_add_to(index sourceColumnIndex, const Field_element_type &coefficient, index targetColumnIndex) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| operator=(const RU_matrix &other) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| pos_index typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| remove_last() | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| remove_maximal_face(index columnIndex) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| reset(Column_settings *colSettings) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| Row_type typedef | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | |
| RU_matrix(Column_settings *colSettings) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| RU_matrix(const std::vector< Boundary_type > &orderedBoundaries, Column_settings *colSettings) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| RU_matrix(unsigned int numberOfColumns, Column_settings *colSettings) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| RU_matrix(const RU_matrix &matrixToCopy, Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| RU_matrix(RU_matrix &&other) noexcept | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
| swap(RU_matrix &matrix1, RU_matrix &matrix2) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | friend |
| zero_cell(index columnIndex, index rowIndex, bool inR=true) | Gudhi::persistence_matrix::RU_matrix< Master_matrix > | inline |
