Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::Persistence_representations::distance_from_diagonal_scaling Class Reference
Detailed Description
This is one of a scaling functions used to weight points depending on their persistence and/or location in the diagram. The scaling given by this function to a point (b,d) is Euclidean distance of (b,d) from diagonal.
Examples
persistence_heat_maps/create_p_h_m_weighted_by_distance_from_diagonal.cpp.
The documentation for this class was generated from the following file:
