Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::Persistence_representations::constant_scaling_function Class Reference
Detailed Description
This is one of a scaling functions used to weight points depending on their persistence and/or location in the diagram. This particular functionality is a function which always assign value 1 to a point in the diagram.
Examples
persistence_heat_maps.cpp, persistence_heat_maps/average_persistence_heat_maps.cpp, persistence_heat_maps/compute_distance_of_persistence_heat_maps.cpp, persistence_heat_maps/compute_scalar_product_of_persistence_heat_maps.cpp, persistence_heat_maps/create_persistence_heat_maps.cpp, and persistence_heat_maps/plot_persistence_heat_map.cpp.
The documentation for this class was generated from the following file:
